I have like 3 or 4 13/16 I will look tomorrow
Scott
--- cotton wrote:
----------------------------------------------------------> Scott, I have the 3/4 in. Reckon I need
> one for sure now as I experimented on this one.
> Ha... Didn't work. If you have one, send me your
> mailing address and I'll send you a MO.
> From: scott lesniak
> Sent: Saturday, May 03, 2008 9:11 PM
> Subject: Re: [2cylinderhondas] Brakes yet
> Ok .
> The last one I shipped was like nine bucks to
> ship.
> I will check tomorrow and see..
> What size is yours again ?3/4 or 13/16?
> Scott
> --- cotton wrote:
> > Scott, check and see. If so give me a price
> > with s/h to N. Central TX. 76481.
> > From: scott lesniak
> > Sent: Saturday, May 03, 2008 7:50 PM
> > They just hold the second piston from coming
> back
> > oonto the first.
> > I may have a good used master lying around
> > Let me know if you want me to check?
> > Scott
> > --- cotton wrote:
> > > Right, I had them out and like Bruce said I
> > > whopped with a 2x4 and a brass hammer and it
> > came
> > > out. Everything cleaned up good and rubber
> cups
> > > looked good and pliable. But after getting it
> > back
> > > together it is leaking at the push rod end. I
> > did
> > > lose the washer under the circlip but replaced
> > it
> > > with one that looks to be equal but I wouldn't
> > think
> > > the washer
> > > would have anything to do with the leak huh?
> > > Reckon I'll take it apart one more time and
> > check it
> > > out and if that don't solve it I'll have to
> get
> > a
> > > kit or another one. Thanks for tip.
> > > I wondered what was the purpose of those two
> > > bolts.
> > > From: scott lesniak
> > > Sent: Saturday, May 03, 2008 2:26 PM
> > > Hey Cotton did you take the two ten MM bolts
> out
> > > of
> > > the end of the master?
> > > They retail the second piston.
> > > Scott
> > > --- cotton wrote:
> > > > Thanks a bunch Bruce. Will give it a try.
> > > > From: Bruce Dewing
> > > > To:
> > > > Sent: Saturday, May 03, 2008 12:42 PM
> > > > Sounds like the secondary piston is still
> > stuck
> > > in
> > > > the bore. Get a piece of wood, and slam the
> > m/c
> > > > into it like it's a hammer. Inertia will
> > usually
> > > > bump it out. If that doesn't work,
> seriously,
> > > buy a
> > > > rebuilt unit from Miles C. and be done with
> > it.
> > > > Bruce D.
> > > > Santa Clara, CA
> > > > From: cotton > > > To:
> > > > Sent: Saturday, May 3, 2008 7:06:43 AM
> > > > Subject: [2cylinderhondas] Brakes yet
> > > > Thanks to you guys I got the rear cylinders
> > off,
> > > > cleaned, and back on in
> > > > good shape I think.
> > > > The master cylinder was a real bear that got
> > > > blessed a few times and my
> > > > hands are small.
> > > > I got the first plunger out after pinching
> my
> > > > fingers numerous times with
> > > > those funny looking pliers before giving up
> > and
> > > > finding someone else to do
> > > > it. Soaked in water for a night and half a
> day
> > > > but cannot get rear plunger out. I have used
> > > more
> > > > brake fluid to slick it
> > > > up and did a lot of tapping which worked on
> > the
> > > > first one but not the
> > > > second. Put air pressure to it with no luck.
> > > > So once more HELP. Would prefer to get it
> out
> > in
> > > > one piece with no damage
> > > > as what I can finger the sleeve feels smooth
> > and
> > > > would like to keep expenses
> > > > down till I know for sure it's going be a
> > > driver.
> > > > Thanks for your
> > > > help........ ...
> > > > cotteni@brazosnet. com
----------------------------------------------------------> > > > No virus found in this incoming message.
> > > > Checked by AVG.
> > > > Version: 7.5.524 / Virus Database:
> > 269.23.8/1412
> > > > Release Date: 5/2/2008 4:34 PM
> > > Be a better friend, newshound, and
> > > know-it-all with Yahoo! Mobile. Try it now.
> http://mobile.yahoo.com/;_ylt=Ahu06i62s ... o8Wcj9tAcJ
=== message truncated ===> > > No virus found in this incoming message.
> > > Checked by AVG.
> 269.23.8/1412
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62s ... o8Wcj9tAcJ
