I am on a tight budget on this '72 sedan I have, and haven't got the
cake to afford new pistons. My cylinder is O.K., and the second piston
is like new. Does anyone out there have a used standard or oversize
piston with rings, to help a poor guy out ? I do have some used parts
to trade if needed.Thanks, Skip XXX-XXX-XXXX
Piston needed
Re: Piston needed
If you put one oversize piston in you will have to rebore that side,
but I guess you know that. Then your engine will be out of balance.
I sold my used piston collection a couple years ago, aprox 35 pistons
on eBay. I think Steven Michelsen bought them?
Re: Piston needed
Yes I still have most of them, but I don't think I have any rings. Rings can be gotten new from Hastings . I will write Stephen offlist about some sort of trade.
www.honda600coupe.com
> Wednesday, October 29, 2008 3:09
> [2cylinderhondas] Re: Piston
> needed
> "Stephen V. Weaver Jr."
> cake to afford new pistons. My cylinder is O.K., and the second > piston
> XXX-XXX-XXXX
> Checked by AVG -
> http://www.avg.com
> Version: 8.0.175 / Virus Database: 270.8.4/1752 -
> Release Date: 10/28/2008 10:04 AM
Re: Piston needed
I usually weigh the pistons anyhow. I've done this on motorcycles for
years !!!! Still need piston w/rings. Have had good response for just
piston. I'm going to make this a runner, then rebuild a second
engine, properly.
engine, properly.
side,
pistons
, "Stephen V. Weaver Jr."
the
> piston
oversize
parts
Re: Piston needed
Stephen;
Hastings has the rings, and they work well. I have used .25 over rings to rering a standard piston/bore (had to file them down to make a good fit) but as long as the land was in good shape whey worked very well.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Stephen V. Weaver Jr.
> Monday, November 03, 2008
> 8:29 PM
> [2cylinderhondas] Re: Piston needed
> piston. I'm going to make this a runner, then rebuild a second > engine, > properly.
> "Miles" wrote:
> > If you put one
> side,
> > but I guess
> > I
> sold my used piston collection a couple years ago, aprox 35 > pistons
> > > I am on a tight budget on this '72 sedan I have, and haven't > got > the > > > cake to afford new pistons. My cylinder is O.K., and > the second > > piston > > > is like new. Does anyone out there > have a used standard or > oversize > > > piston with rings, to help > a poor guy out ? I do have some used > parts > > > to trade if > needed.Thanks, Skip XXX-XXX-XXXX
Re: Piston needed
That's a lost art, filing rings for proper end gap. I bored a Whizzer
engine once for a guy, he said he could assemble it. He sent it back
because it failed.......didn't check ring gap. Suffered bind when
hot. Of course it wasn't HIS fault......thanks for the tips.
, wrote:
> Stephen;
over rings
good fit)
]On Behalf Of Stephen V.
Weaver Jr.
> Sent: Monday, November 03, 2008 8:29 PM
> Subject: [2cylinderhondas] Re: Piston needed
for
just
> engine, properly.
> side,
balance.
> pistons
> > Miles
got
> the
second
> > piston
> oversize
used
> parts
