Fw: Unable to deliver your message
Eddie Velasquez
Re: Lewis has found a Coupe in New Mexico
Post by Eddie Velasquez »
send me a picture and a price
Wed, 12/17/08, David Ackerman
> From: David Ackerman
> Subject: [2cylinderhondas] Re:Lewis has found a Coupe in New Mexico > To: 2cylinderhondas@yahoogroups.com > Date: Wednesday, December 17, 2008, 8:04 PM
> if anyone is looking to buy a 600, I have a complete '72 coupe that sorta runs, and a '70 sedan that has an excellent body and good paint but needs engine finished.  The coupe has a little rust but does run. Brakes need to be done on both. Started to rebuild sedans > brake system > , but never finished.  I dont have title on these, but can do a lein sale if someone is interested.  Bought from a friend a few years back, but he never put them in his name and lost the titles.  Located in > southern Oregon > .
Re: Fw: Unable to deliver your message
--- In 2cylinderhondas@yahoogroups.com, wrote:
>Excellent tips! Thanks bill! riceburner006
> Don't stop there, I have had intake clamps fail to seal, Intake manifold O
> rings not seal and any of the 4 clamps to the booster fail to seal properly.
> And, don't forget the puppet valve on the booster, the seal on the piston
> seems to shrink with age. I have use a small O ring under the seal to make
> it seal. Then there is the two nylon seals on the carb throttle shaft. The
> Gasohol we are forced to use these days really eats that stuff up. And a
> hot engine can cause the alcohol to boil away after sitting for a few hours
> if the shrouds and cooling fan are not properly connected. So, there is a
> bunch of things that can cause your Honda 600 power plant not to start every
> time.
> Two things can help to reduce the Alcohol problems, 1 use high test (you're
> not buying that much you can afford it) 2 make sure all the fuel lines are
> tight and that you let your fuel pump run until it stops before starting.
]On Behalf Of cotton
> Sent: Sunday, December 14, 2008 9:48 AM
> Subject: Re: [2cylinderhondas] Fw: Unable to deliver your message
> I gotta remember that.
> I had the same problem and found I was sucking air at the [intake?]
> where the rubber from the carb end comes to the intake. Got that trued up
> and clamped
> and problem solved. If one don't work check out the other. Good luck.
> To: Sent: Sunday, December 14, 2008 9:57 AM
> > hi this is dean. try removing the brake booster and plugging the hose. i
> > found my brake booster to be leaking and causing it not to idle. it's a
> > easy try and it was what was wrong on my honda 600.
> > TOP Chart Ringtones
> > Get top ringtones on your cell phone. Click here now!
> http://thirdpartyoffers.netzero.net/TGL ... 8uvBfziT82
Xqj0M3
> BurcmPERZ3ZkOfpC8zHFv919/
> Checked by AVG -
http://www.avg.com
> Version: 8.0.176 / Virus Database: 270.9.18/1848 - Release Date: 12/14/2008
> 12:28 PM
All
Lewis is not on the group, so you will have to e-mail him.
solewshuns@...
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Stephen V. Weaver Jr.
> Thursday, December 18,
> 2008 8:18 AM
> Mexico
> How much ?
> David Ackerman
> > if
> anyone is looking to buy a 600, I have a complete '72 coupe that > sorta > runs, and a '70 sedan that has an excellent body and good > paint but > needs engine finished.  The coupe has a little rust but does > run.
> Brakes need to be done on both. Started to rebuild sedans brake > system, > but never finished.  I dont have title on these, but can do a > lein > sale if someone is interested.  Bought from a friend a few years
> in southern Oregon.
