Couple parts needed
davepdouglass
Couple parts needed
Post by davepdouglass »
Good Morning gang, wondering if anyone has a set of bolts rubber and washers for the two side shields that direct air around the engine. If so let me know and how much.
Thanks Dave
TOM THIES
Re: Couple parts needed
Post by TOM THIES »
I went to my local Napa store and got mine..  took a little time but they all worked.  I took the shield with me and knowing the size of blots that are used it all worked out
Tom T
> davepdouglass
> Thursday, February 25, 2010 5:29
> [2cylinderhondas] Couple parts
> needed
> Good Morning gang, wondering if anyone has a set of bolts rubber and > washers for the two side shields that direct air around the engine. If so let > me know and how much.
> Thanks Dave
mterrens
Post by mterrens »
Do you have the NAPA part numbers that worked for you?
> TOM THIES
> Thursday, February 25, 2010 11:04
> Re: [2cylinderhondas] Couple
> parts needed
> I went to my local Napa store and got mine..  took a little time but > they all worked.  I took the shield with me and knowing the size of blots > that are used it all worked out
> Tom T
> > davepdouglass
> > AM
> > needed
> > Good Morning gang, wondering if anyone has a set of bolts rubber and > > washers for the two side shields that direct air around the engine. If so > > let me know and how much.
> > Thanks Dave
davepdouglass
Tom t how about the rubbers and the cup shaped washers did they have those as well?
Dave
> Tom T
> From: davepdouglass
Sent: Thursday, February 25, 2010 5:29 AM
> Subject: [2cylinderhondas] Couple parts needed
> Thanks Dave
TOM THIES
Post by TOM THIES »
I had the washers that I needed but not the rubber part.  The place I went to NAPA auto parts helped me find the size I needed because I took the shield in with me and I had the sizes of the bolts.  I think there was one that was not perfect but close, think the inner hole was to big but cant remember.
hope this helps
Tom T
> davepdouglass
> Thursday, February 25, 2010 1:36
> [2cylinderhondas] Re: Couple
> parts needed
> Tom t how about the rubbers and the cup shaped washers did they have those > as well?
> Dave
> "TOM THIES" wrote:
> > I went to my
> local Napa store and got mine.. took a little time but they all worked. I took > the shield with me and knowing the size of blots that are used it all worked > out > > Tom T > > ----- Original Message ----- > > From:
> davepdouglass
> > Good
> Morning gang, wondering if anyone has a set of bolts rubber and washers for > the two side shields that direct air around the engine. If so let me know and > how much.
> > Thanks Dave
TOM THIES
Post by TOM THIES »
Sorry I don�t.  I am sure I have the receipt someplace I have no idea where it would be.
Tom T.
> Steven
> Michelsen
> Thursday, February 25, 2010 8:49
> parts needed
> you?
> > TOM THIES
> > AM
> > parts needed
> > I went to my local Napa store and got mine..  took a little time > > but they all worked.  I took the shield with me and knowing the size of > > blots that are used it all worked out
> > Tom T
> > > davepdouglass
> > > Sent:
> > > 5:29 AM
> > > parts needed
> > > Good Morning gang, wondering if anyone has a set of bolts rubber and > > > washers for the two side shields that direct air around the engine. If so > > > let me know and how much.
> > > Thanks Dave
