Head Gasket
Re: Oiling and cooler (was Bonneville Honda)
I see that.  The main bearing at the alternator side gets its oil via a gravity feed from the oil in the cam housing.  Anyone rebuilding these engines needs to make sure they put this bearing and the gasket on correctly or the bearing will not receive sufficient oil.
thanks,
> I think
> only 3 out of 4 are fed directly from the pump - I think one might be fed from > what pours down from the head. There's a funnel up top that catches oil. (Not > 100% sure . . . but that's what I seem to remember.) > --- In > 2cylinderhondas@yahoogroups.com > , > goinhm@... wrote:
> > The crank main bearings are fed oil from the
> pump ..... they are not splash
> > fed. Some of the advantages of a
> roller bearing engine over a sleeve
> > bearing are (a) less friction and
> (b) the ability to withstand short periods of
> > oil starvation. The
> main bearings do want to see lots of oil but if they
> > don't get any
> oil for several rotations, no big deal.
jpro8071
Post by jpro8071 »
Another problem I've seen on engines I've taken apart is that some people use way too much gasket sealer. It doesn't take much to get squeezed into the area where oil returns back down (or goes up) and slow down the feed.
> thanks,
> I think only 3 out of 4 are fed directly from the pump - I think one might
> be fed from what pours down from the head. There's a funnel up top that
> catches oil. (Not 100% sure . . . but that's what I seem to remember.)
_2cylinderhondas@yahoogroups.com
_
> (mailto:
) , goinhm@ wrote:
> > The crank main bearings are fed oil from the pump ..... they are not
> splash
> > fed. Some of the advantages of a roller bearing engine over a sleeve
> > bearing are (a) less friction and (b) the ability to withstand short
> periods of
> > oil starvation. The main bearings do want to see lots of oil but if they
> > don't get any oil for several rotations, no big deal.
> > Dale
