CORRECTION... one piston frozen in cylinder, need advice
I need to make a slight correction to my statement below......  I did not get my cylinder barrels "resleeved".
The original barrels were part of a casting (as Bill has mentioned).
The machine shop I used would break out the damaged barrel and replace it with a cylinder sleeve.  It can be done if you find the right person and can find the sleeve.
> I have had sleeves inserted into at least 6 cylinder barrels for the 71 > and 72 Honda 600s.  I never had a problem with them.  The machinist > who did them for me specialized in resleeving cylinders.  He would break > out the old liner and machine the top and bottom of the barrel to accept his > sleeve.  It had a small flange on the top of the new liner and a ring > which held the bottom section secure.  He also used to rebuild > crankshafts for me ...... I would take him 2 cranks (each with a usable side) > and he would give me back one and a box of pieces.   He closed up > shop years ago, unfortunately.
> What I had done with the 71 and 72 cylinders may not be possible with the > 1970 barrel.  Someone who used to get their barrels resleeved told me the > ribbing of the 70 barrel caused a problem.
> that is what I know,
> > Richard;  You
> > are correct, but its not sleeved, its part of the casting.  As such, > > it cant be re-sleeved.
