Heater and ventilation
Post by lyletrudell »
I removed the ventilation system from under the dash.
The foam was all falling apart so I used Home Depot sponge rubber weather stripping with adhesive backing. Cut with scissors and stuck in place, worked out great.
The inlet box seal #5 and the ventilator case seal #34 is hard and cracked.
What should I use as a seal replacement?
I am sure the original seal is not available.
Re: Heater and ventilation
Post by feltonminicycle »
sedan or coupe? Did you try ordering the original seal? doesn't seem like something under the dash would be a part many people would have replaced.
> Thanks
Heater ventilation seals
I have a 1972 Coupe, Honda doesn't have any old stock. I was looking for seals as replacements. These foam rubber seals could work with some modifications:
http://www.mcmaster.com/#bulb-seals/=b8suhx
> > Thanks
> > Lyle
