Brake Booster
rveggie
Brake Booster
Post by rveggie »
Need help to find good used late model brake booster or good
rebuilder
1972 Az600
Ray
Re: Brake Booster
Post by feltonminicycle »
All USA coupe boosters are same
> rebuilder
> 1972 Az600
> Thanks
> Ray
Ryan Powell
Brake Booster
Post by Ryan Powell »
How do you get part number 4 out? the relay piston assy. Mine is frozen.
Schematic attahced
Re: [anzhonda600owners] Brake Booster [1 Attachment]
Post by Eric Geiger »
I used a small drill bit and was able to drill it out to the point where it became unfrozen then just used a new one.   Miles used to make new ones otherwise u can probably get one used somewhere.
PRG-Nocturne
Egeiger@...
On Dec 14, 2014, at 5:13 PM, Ryan Powell
ryanpowell96@...
[anzhonda600owners] How do you get part number 4 out? the relay piston assy. Mine is frozen.
> Schematic attahced
Let me clear that up I used a drill bit/easy out to yank it out.  I didn't drill it out to the point where the drill bit touched the wall of the brake booster cylinder.
PRG-Nocturne
Egeiger@...
On Dec 14, 2014, at 5:17 PM, Eric Geiger
[2cylinderhondas] I used a small drill bit and was able to drill it out to the point where it became unfrozen then just used a new one.   Miles used to make new ones otherwise u can probably get one used somewhere.
> Eric Geiger
> PRG-Nocturne
> XXX-XXX-XXXX
> Egeiger@...
> ryanpowell96@...
> [anzhonda600owners] anzhonda600owners@yahoogroups.com
> > Schematic attahced
David Brink
Post by David Brink »
I have had success boiling master cylinders in water. Brake fluid is water soluble and there is the heat expanding things a bit.
On Sun, Dec 14, 2014 at 3:19 PM, Eric Geiger
[2cylinderhondas]
> Let me clear that up I used a drill bit/easy out to yank it out.� I didn't drill it out to the point where the drill bit touched the wall of the brake booster cylinder.�
> Eric Geiger
> PRG-Nocturne
> XXX-XXX-XXXX
> Egeiger@...
> egeiger@...
> [2cylinderhondas] 2cylinderhondas@yahoogroups.com
> > I used a small drill bit and was able to drill it out to the point where it became unfrozen then just used a new one. � Miles used to make new ones otherwise u can probably get one used somewhere.�
> > Eric Geiger
> > PRG-Nocturne
> > XXX-XXX-XXXX
> > Egeiger@...
> > ryanpowell96@...
> > [anzhonda600owners] > anzhonda600owners@yahoogroups.com
> > > Schematic attahced
ryanpowell96
Re: Brake Booster
Post by ryanpowell96 »
Does anyone have part number 4 for sale?
Sent from my Samsung Galaxy Note� II
-------- Original message --------
Date:12/14/2014 5:13 PM (GMT-06:00)
To: 2cylinderhondas@yahoogroups.com, anzhonda600owners@yahoogroups.com
Subject: Brake Booster
Schematic attahced
Re: [anzhonda600owners] RE: Brake Booster
I'm sure I have one but again everything of mine is in storage so it'll probably be a week before I could look
PRG-Nocturne
Egeiger@...
On Dec 14, 2014, at 7:35 PM, ryanpowell96
ryanpowell96@...
[anzhonda600owners] Does anyone have part number 4 for sale?
> Sent from my Samsung Galaxy Note® II
> From: Ryan Powell
> Schematic attahced
I found the booster part 4 that I had originally pulled out before replacing it with a new one.  It's got a tiny hole in the top from the easy out but if u want it it's yours for free just cover shipping.  Email me direct.
PRG-Nocturne
Egeiger@...
> Eric Geiger
> PRG-Nocturne
> XXX-XXX-XXXX
> Egeiger@...
> ryanpowell96@...
> > Schematic attahced
shdunnnm
Brake Booster
Post by shdunnnm »
Does anyone have replacement diaphragms for the power chamber (big chamber) of a mid-series 5F5 Booster?
Skip
