Hi Marshall;
The simple fix is to locate a new switch for the back side of the ignition key assembly. It is the same for either Sedan or Coupe. Often they either ground out or the return spring jams or brakes causing the starter to stay engaged.
About once a season I need to clean all the exterior bulb carriers, and often the battery terminals come lose or the connections become corroded enough to insulate the contact. Normally its an easy cleaning. But to start adding this or that toggle switch often leads to more problems.
Unwrap your wire harness in the engine compt and make sure nothing is melted. If it is, replace it by cutting out the wire and soldering in a new wire in its place.
Re: [2cylinderhondas] Re: Car won't turn over-How to bench test sta
