Re: [2cylinderhondas] Ignition coil
HI Mike;
If you go to the photo section of the ANZhondagroup site, there is a How To
change out the lines on your coil. This is often what is causing the
problem, and the directions are simple. Also, I have only found 1 coil that
was Bad.
