motor is in getting worked on.
Well i took my motor to B and B auto in Washington state to get it
worked on and found it needs some lower end work to. I dont know all
the work that needs to be done becuse they went on vaction untill the
27th but they did say labor was going to be around $1,600 or so plus
parts which some can be used from my other motor. Seems a bit high in
the labor cost. What do you all think? If i have to spend $2500 to
3000 i may just part out the car and try to recoupe some of my lost on
the car do to the fact the guy that sold it to be said he rebuilt it.
Thanks for any info...
tom
tom
Re: motor is in getting worked on.
I wonder what they meant by lower end work? The only things I can think of in the lower end are;
1) cam chain tensioner (trivial and can be done external to engine)
2) cam chain guide / roller system (crankcase needs to be split)
3) crankshaft problem (major expense)
If the crankshaft is being removed or worked on, you might as well go through the entire engine and check/repair it. The $1600 price may not be too out of line if their labor rate is $100 / hr. Does that price include machine shop labor? 16 hours is about the time needed to disassemble the 600 engine, clean it, inspect the parts, make up a parts list, deliver the cylinder head, pistons, and barrel to a shop for machine work, pick up the parts from shop, reassemble the engine, and then time it. If B & B is not needing to split the crankcase and you delivered the engine to them already out of the car, then $1600 sounds like it is on the high side.
You might also check with Dan Hall Automotive XXX-XXX-XXXX) in NE Portland or Dale Maslen Machine XXX-XXX-XXXX) in Forest Grove, Oregon. Both are full machine shops and have experience in Honda motors. And if you need any work done on your camshaft, check with Oregon Cam Grinding XXX-XXX-XXXX) in Vancouver, WA.
Watch "Cooking with Tyler Florence" on AOL Food .
Get trade secrets for amazing burgers.> Well i
> took my motor to B and B auto in Washington state to get it > worked on and > found it needs some lower end work to. I dont know all > the work that needs > to be done becuse they went on vaction untill the > 27th but they did say > labor was going to be around $1,600 or so plus > parts which some can be > used from my other motor.
buy the complete rebuilt one off bill c on ebay
tdthies1 wrote:
tdthies1 wrote:
> Well i took my motor to B and B auto in Washington state to get it > worked on and found it needs some lower end work to. I dont know all > the work that needs to be done becuse they went on vaction untill the > 27th but they did say labor was going to be around $1,600 or so plus > parts which some can be used from my other motor. Seems a bit high in > the labor cost. What do you all think? If i have to spend $2500 to > 3000 i may just part out > the car and try to recoupe some of my lost on > the car do to the fact the guy that sold it to be said he rebuilt it.
> tom
Kris
I have seen one for sale before but cant find it now...do you have the
link for it...
thanks i may have to go that route.
link for it...
B auto in Washington state to get it> buy the complete rebuilt one off bill c on ebay
> tdthies1 wrote: Well i took my motor to B and
> tom
Well picked up the motor from B&B automotive in washington state and
finely got it put in yesterday. Hooked it all up and took it for a
test drive....sounds goooooood.. Now it is time to get some driving
in. And yes the shrounds are in. Thanks for all the help.
tom
tom
Tom;
That is Great News!!
Are you posting pictures?
> tdthies1
> Wednesday, July 16, 2008 8:24 PM
> [anzhonda600owners] motor
> help.
> tom
I guess we cannot post pics here but it no one minds i do have some
photos here
http://autos.ph.groups.yahoo.com/group/ ... s/browse/7
540
I am going to try to taks some more this weekend and put them on..
Hey by the way for gas what it the best way to go..Reg or prem. not
going to be using this car for a everyday driver, just the weekend
drive around car..
thanks all
tom
photos here
540
drive around car..
thanks all
tom
, wrote:
> Tom;
]On Behalf Of tdthies1
> Sent: Wednesday, July 16, 2008 8:24 PM
> Subject: [anzhonda600owners] motor is in getting worked on.
and
driving
> tom
--- In anzhonda600owners@yahoogroups.com, "tdthies1"
green or blue car seems to be invisible to most other drivers, but not
ol' John Law!
Mine is a bright yellow as it needs to be for the blind drivers to
miss with their mighty big Oklahoma crude gulpers. Middle America,
what can I say...
Mark Coffin
What a great color for a Z coupe! Unfortunately around here a dark> I guess we cannot post pics here but it no one minds i do have some
> photos here
> 540
ol' John Law!
what can I say...
Mark Coffin
Hi Tom,
When B & B rebuilt your engine, did they install a "hot" cam in your engine? The cam in his coupe had some performance........ I was wondering if he installed a similar cam in your engine.
Sign up for FanHouse Fantasy Football today .
Get fantasy football with free live scoring.> Well
> picked up the motor from B&B automotive in washington state and > finely > got it put in yesterday. Hooked it all up and took it for a > test > drive....sounds goooooood.. Now it is time to get some driving > in. And yes > the shrounds are in. Thanks for all the > help.
> tom
I do believe it all ready had the better cam in it and was in good condition. I had to replace the crank (which I had a spare engine that had a good crank) One piston, rings and some other parts in the motor and tranny..
tom
tom
> goinhm@...
> Sunday, July 20, 2008 12:07
> Re: [anzhonda600owners] motor is
> Hi Tom,
> did they install a "hot" cam in your engine? The cam in his coupe had > some performance. ....... I was wondering if he installed a similar cam in > your engine.
> > Well
> > help.
> > tom
