Just curious: Are replacement cylinders not possible to find anymore? What about taking you brake cylinders to a professional rebuilder? Would they have better tools and parts for a rebuild?
I haven't had brake problems on my coupe yet(knock and wood), but I recently started driving it more regularly. It was in storage with the previous owners for a long time and I wouldn't be surprised if I get a little fluid leak some time this summer.
Although on a Honda 600, the brakes don't really have to do a whole lot of work. The car barely weighs over 1000 pounds, if that.
, "Lyle" wrote:
> Hi Marty, yep, like Dale said it's a big concern. Not just loosing rear brake pressure, but the brake fluid will get on the rear shoes and destroy them also.
> If the bores are OK then a light hone will work. If they are bad the cylinder will have to be replaced or sleeved.
> Bill knows of a place that sleeves them.
> If the bores are good and 3/4" dia then I have NOS pistons and seals if you need them, cheap.
> Also, switch to silicone brake fluid, see "Files" Bill has a good artical about it. I run it in all my old cars.
, goinhm@ wrote:
> > Hi Marty,
> > Your rear brake problem is a definite concern. If you suspect the
> > brake cylinders on rear brakes are about the same age, you want to take them
> > both off, take them apart, and inspect them. You want to do an inspection
> > which involves removing the two pistons contained in each piston cylinder.
> > The dust cover (the black "rubber" part you see on the outside) is the
> > least important but it does need to be without holes, rips, or tears. When
> > you remove the piston, you will see the very important seal on the piston
> > ....... this is where your leaking is occurring. You can also inspect the
> > piston cylinder bores which should be very clean, smooth, and shiny looking
> > in the area where the piston moves. Measure the bore to see if is still
> > within spec.
> > Now for the best part ....... you can still get parts for this brake
> > item. Miles sells a rear brake rebuild kit and I think Mike O'Connor does,
> > too. Also, if the cylinder says 3/4 inches, it uses the same rebuild kit
> > as the 1973 Honda Civic. Check with Lyle ...... he had some brake repair
> > parts he was selling a year ago.
> > Also, I think Miles may have posted some YouTube videos about the
> > rear brake cylinder. The biggest problems I have seen with the rear brake
> > cylinders are;
> > 1. the brake fluid has crystallized and it forms little particles which
> > feel like sand which has been made of rubber cement.
> > 2. the seal is no longer pliable enough to seal off the bore
> > 3. the piston bores become excessively pitted and/or corroded.
> > good luck,
> > Dale
> > Thanks guys,
> > Again, I only see a bit of fluid that is leaking from the seal. When the
> > wheel was off I did step on the the brakes to see if the pistons would move.
> > They did move but not at the same time. It seemed that the top one
> > (right) engaged first, followed by the other (bottom).
> > I probably know the answer to this question because it is regarding the
> > brake system, but how serious is this? Can I get away with driving on it
> > lightly or is it a "do not get behind the wheel" situation.
> > Thanks
> > Marty
