My airbox is getting "filled" with oil from the valve cover vent.
I am not doing a lot of engine breaking...What causes this?
Pete
Oil from Valve Cover Vent
Re: Oil from Valve Cover Vent
Hi Pete;
broken rings.
broken rings.
> bitsurfer001
> Wednesday, January 25, 2012 12:04
> [anzhonda600owners] Oil from Valve Cover Vent
> I am
> this?
> Pete
ronny lucassen
blown headgasket !
, wrote:
> Hi Pete;
> broken rings.
]On Behalf Of bitsurfer001
> Sent: Wednesday, January 25, 2012 12:04 PM
> Subject: [anzhonda600owners] Oil from Valve Cover Vent
> Pete
bitsurfer001
Either way...looks like I'm taking it apart.
Will report back.
Pete
Will report back.
Pete
, "ronny lucassen" wrote:
> blown headgasket !
, wrote:
> > Hi Pete;
> > broken rings.
> > [mailto:
> > Pete
blake neilson
It sounds like your rings are worn which allows a lot of "blowby" past the rings into the crankcase. That flow is vented into the air cleaner box. In an extreme case you might have a hole in a piston.
bitsurfer001 To:
Wednesday, January 25, 2012 3:04 PM Subject:
Pete
bitsurfer001 To:
Pete
A little oil in the airbox is normal as it is collecting oil vapors. But an excessive amount could be a indication of too much blow-by, possibly bad rings or piston. The other possibility is sludge build up in the baffle plate in the valve cover. You might pull valve cover off and clean out the baffle in the top of the cover and see if that helps.Then do a compression check and a leak down test to determine if it is a ring problem. I hope this helps you out a little. Brad (Classic Auto Service Dallas) From:
bitsurfer001 To:
Wed, January 25, 2012 2:04:01 PM Subject:
Pete
bitsurfer001 To:
Pete
ronny lucassen
I had the same only at my car the headgasket was broken between the 2e cylinder and the chain side, so all the compression came into the oilchambers.
> From: bitsurfer001
> Sent: Wednesday, January 25, 2012 3:04 PM
> Pete
David Coyle
Hi Ronny, I was looking to join the yahoo group as I am a fan of Honda 600 and am looking to get one soon. I think you responded to someone else's question to my e-mail by mistake. Please allow me to join your group if you are the one that does it.
Dave Coyle
ronny lucassen
Monday, February 6, 2012 2:10 AM
[anzhonda600owners] Re: Oil from Valve Cover Vent
Dave Coyle
ronny lucassen
> It sounds like your rings are worn which allows a lot of "blowby" past the rings into the crankcase.� That flow is vented into the air cleaner box. In an extreme case you might have a hole in a piston.
> From: bitsurfer001
> Pete
