Re: [2cylinderhondas] Re: Cleaning Carburetors [1 Attachment]
Post by Eric Geiger »
Awesome thanks for the tips.
Next time I'll have to give the boil a try
PRG-Nocturne
Egeiger@...
On Mar 6, 2014, at 2:24 AM, "Bill" wrote:
Eric;
We used to boil our carb's on the stove with lemon Koolaid. The
solution varied but nothing as corrosive as some of the cleaners on the
shelf today. The boiling action in the pan caused most of the stuff on the
carb to come off and compressed air got the rest. Almost any solution will
be corrosive but the outside (body) of the carb had a bronze color to it
from the factory, which corroded off the carb over time. Eastwood products
http://www.eastwood.com/review/product/ ... egory/200/
http://www.eastwood.com/review/product/ ... egory/200/ has a
nice carb renew product that gives your carb that OEM new look. These days I
use one of the dental root canal wire drills to open the passages and a can
of carb cleaner along with the stiff brush and compressed air.
_____
] On Behalf Of Eric Geiger
Sent: Wednesday, March 05, 2014 10:27 PM
To: <
Cc:
Subject: Re: [2cylinderhondas] Re: Cleaning Carburetors
Doesn't simple green oxidize aluminum? Or is it safe to use in the
ultrasonic?
PRG-Nocturne
Egeiger@...
On Mar 5, 2014, at 9:57 PM, "Dr.Whiting" <
theenginebuilder@...
A word of warning! Don't use a tumbler on any carburetors with small
passages. They will be clogged with fine dirt from the cleaning process and
not work as they should.
The ultrasonic works great. When left in long enough old fuel and corrosion
solidified inside will be "shaken" loose and can be flushed out with
carburetor spray cleaner.
Bart Schile
Post by Bart Schile »
We use on ultra sonic cleaner on all of our carbs.  Just a cap full in a gallon of water.  We run it around 100 degrees for about 30 mins.  May have to do it twice if real bad.  We have not seen any corrosive effects from the ultra sonic cleaner.  Thanks Bart
