Tach for your Honda 600 Sedan
The attached picture shows how it mounts to the pocket to the left of the instrument gauges which was easy to fit.
The tach is all electronic (see info below) and allows for a two cylinder engine.
The attached picture also shows that the engine is running at idle with a smooth needle through all ranges.
Legendary 60's styling reproduced with modern electronics inside and retro looks outside 3-3/8 inch diameter 90 degree sweep face 0-8000 RPM range and 360 degree lighting
Internal settings
for 1,2,4,6,8,and 10 cylinder engines
All metal tach housing with removable chrome metal cup and includes two mounting brackets for either steering column or dash mount
Vibration proof air core meter design with 360 degree lighting that avoids uneven spots for better night visibility
http://www.amazon.com/Sunpro-SST802R-Re ... ENZGXDHRCH
pete kneedler
Re: Tach for your Honda 600 Sedan [1 Attachment]
Post by pete kneedler »
Desar Honda Friends: Would you please remove my name and address from
your address list? Thanks, Pete
On 3/13/15, 'Bill' billmyong@... [anzhonda600owners]
> instrument gauges which was easy to fit. The tach is all electronic (see
> info below) and allows for a two cylinder engine. The attached picture
> also
> ranges.
> Internal settings for 1,2,4,6,8,and 10 cylinder engines All
> mounting
> brackets for either steering column or dash mount Vibration proof air core
> night visibility
> ef=pd_sim_sbs_auto_1?ie=UTF8&refRID=0E0FTABZXVENZGXDHRCH>
http://www.amazon.com/Sunpro-SST802R-Re ... 30MTCY0/re
