MY 600 won't idle
elliasnassif
MY 600 won't idle
Post by elliasnassif »
the car turns on but won't stay on. i adjusted the idle control screw but it is fully compressed and I've been messing with the piolt screw. i managed to keep her on but she is idling higher than i want and with no rpm gauge its hard. also at the way i have it set up as soon as i start driving her it sounds like she's almost going to cut out. i can take her to a carb tech. but if its an easy fix id rather do it myself I'm great at these types of things but i have to know the process first
thanks, sincerely   new and exited 600 owner
rstevens19
Re: MY 600 won't idle
Post by rstevens19 »
Welcome New Owner,
Your problem appears to be the Fuel Stop Solenoid is non-functional. It is mounted on the drivers side of the carb with a single screw. and has two wires coming out, one grounded to the intake manifold/head and the other to the wiring harness near the air cleaner. This solenoid should activate when the ignition is turned on, easily tested by either listening carefully when turning on ignition or removing and connecting across the battery terminals. Note: since the carburetor is connected through rubber on both ends, the solenoid MUST be grounded to function. When I owned a 600 from 1972-1978 the only mechanical failure I ever had was the Fuel Stop Solenoid. The solenoid cuts fuel flow from the low speed circuit to prevent shut-off dieseling.  When failed, the car will not idle.
Hope this helps,
Richard
elliasnassif@...
[anzhonda600owners]
Sunday, March 11, 2018 4:34 AM
[anzhonda600owners] MY 600 won't idle
Virus-free.
www.avast.com
SArya2000
Post by SArya2000 »
........or maybe the throttle shaft seals.
https://groups.yahoo.com/neo/groups/2cy ... earch=true
Ellias Nassif
Post by Ellias Nassif »
http://www.honda600coupe.com/Honda_600_ ... hap_14.pdf 14-15 is that what youre talking about? from my iPhone
On Mar 11, 2018, at 5:24 AM,
rstevens19@...
[anzhonda600owners] wrote:
Welcome New Owner,
Hope this helps,
Richard
elliasnassif@...
[anzhonda600owners]
Virus-free.
www.avast.com
Harry Connors
Post by Harry Connors »
How long has the fuel been in the tank? I had a problem with one of my Old-timers doing the same thing; it would start and run but after a couple of minutes it would stop. It took me several days to check everything twice and decided to drain the tank and put new fuel in. This corn mixture fell we get is only good for two to three months before it deteriorates. With new fuel in the vehicle and doing nothing else it runs like it is supposed to.
Harry
> On Mar 11, 2018, at 11:49 AM, Ellias Nassif
> elliasnassif@...
> [anzhonda600owners] anzhonda600owners@yahoogroups.com
> http://www.honda600coupe.com/Honda_600_ ... hap_14.pdf >  14-15 is that what youre talking about? from my iPhone > On Mar 11, 2018, at 5:24 AM, > rstevens19@...
> > Welcome New Owner,
> > Your problem appears to be the Fuel Stop Solenoid is non-functional. It is > > mounted on the drivers side of the carb with a single screw. and has two wires > > coming out, one grounded to the intake manifold/head and the other to the wiring > > harness near the air cleaner. This solenoid should activate when the ignition is > > turned on, easily tested by either listening carefully when turning on ignition > > or removing and connecting across the battery terminals. Note: since the > > carburetor is connected through rubber on both ends, the solenoid MUST be > > grounded to function. When I owned a 600 from 1972-1978 the only mechanical > > failure I ever had was the Fuel Stop Solenoid. The solenoid cuts fuel flow from > > the low speed circuit to prevent shut-off dieseling.  When failed, the car > > will not idle.
> > Hope this helps,
> > Richard
> > elliasnassif@...
> > [anzhonda600owners]
> > the car turns on but won't stay on. i adjusted the idle control screw but it > > is fully compressed and I've been messing with the piolt screw. i managed to > > keep her on but she is idling higher than i want and with no rpm gauge its hard.
> > also at the way i have it set up as soon as i start driving her it sounds like > > she's almost going to cut out. i can take her to a carb tech. but if its an easy > > fix id rather do it myself I'm great at these types of things but i have to know > > the process first
> > Virus-free.
> > www.avast.com
rstevens19
Yes
Ellias Nassif elliasnassif@...
[anzhonda600owners]
Sunday, March 11, 2018 2:49 PM
Re: [anzhonda600owners] MY 600 won't idle
On Mar 11, 2018, at 5:24 AM, rstevens19@...
[anzhonda600owners] Welcome New Owner,
> Your problem appears to be the Fuel Stop Solenoid is non-functional. It > is mounted on the drivers side of the carb with a single screw. and has two > wires coming out, one grounded to the intake manifold/head and the other to > the wiring harness near the air cleaner. This solenoid should activate when > the ignition is turned on, easily tested by either listening carefully when > turning on ignition or removing and connecting across the battery terminals.
> Note: since the carburetor is connected through rubber on both ends, the > solenoid MUST be grounded to function. When I owned a 600 from 1972-1978 the > only mechanical failure I ever had was the Fuel Stop Solenoid. The solenoid > cuts fuel flow from the low speed circuit to prevent shut-off dieseling.
> Hope this helps,
> Richard
> elliasnassif@...
> [anzhonda600owners]
> the car turns on but won't stay on. i adjusted the idle control screw but > it is fully compressed and I've been messing with the piolt screw. i managed > to keep her on but she is idling higher than i want and with no rpm gauge its > hard. also at the way i have it set up as soon as i start driving her it > sounds like she's almost going to cut out. i can take her to a carb tech. but > if its an easy fix id rather do it myself I'm great at these types of things > but i have to know the process first
> Virus-free.
> www.avast.com
