Battery?
Re: Seats
Hi Jason;
    1st the sedan seats do not fit the coupe.  But pull your seats and check out the damage it may be repairable.
2nd, I will attach a diagram of the Coupe with dimensions, there is not dimensions from the bumper to the fire wall, but if you can use this picture and indicate where you want it measured and I will do my best.
> jason
> hambelton
> 2cylinderhondas
> Wednesday, January 15, 2003 5:12
> [2cylinderhondas] Seats
> I need to replace the seats in my Z.  Some how they were bent where > the back rest attaches to the bottom of the seat.  I have not tried to > bend them back into shape yet, nor do I think that they will look right if I > try. It looks as if a very very large person tried to sit in them both at > the same time.  But that's how they were when I got the  car.
> I have a N as well and would like to know if the base of the seats are the > same in both cars?  It will take some work for me to get the seats out of > the N so I thought I would ask here before I start on it.  My guess is > that the bolt pattern is the same.
> Also, if any one knows what the measurement on the 600Z, from the > rear of the hood latch mount to the fire wall is?  I have had to do some > major body work on the front end and can't tell if I have the section between > the headlight in line.
> Thanks, Jason
> Do you Yahoo!?
> Yahoo! Mail
> Plus
> - Powerful. Affordable.
> Sign up
> now
> To
> to:
> Your
> Yahoo! Terms of Service
Re: Seats
Now that is a deal. and the seat upholstery is for both front and back +
the emergency brake cover for $225.00. All ready to go on.
J.D.Long
Re: Seats
Post by J.D.Long »
Thanks for the diagram, I was looking for something just like it.  It has all the info that I need.  I thought the only way that I could find out was to measure anothe coupe and compare.  Unfortunately this appears to be the second front end repair that has been done to the car.  As I have found weld marks and slide hammer holes in the same area of the front end.  If I had not goten the car so cheap, I would have never put this much work into it, lol.  But I had a extra subframe and the rest I used hydrolics to staighten with. But the rest of the car is so clean (except for the seats) that I had to get it back out on the road.
Thanks for the help,
Jason
william colford wrote:
> Hi Jason;
> > jason hambelton
> > 2cylinderhondas
> > Wednesday, January 15, 2003 5:12 PM
> > I need to replace the seats in my Z.  Some how they were bent where the back rest attaches to the bottom of the seat.  I have not tried to bend them back into shape yet, nor do I think that they will look right if I try. It looks as if a very very large person tried to sit in them both at the same time.  But that's how they were when I got the  car.  I have a N as well and would like to know if the base of the seats are the same in both cars?  It will take some work for me to get the seats out of the N so I thought I would ask here before I start on it.  My guess is that the bolt pattern is the same.
> > Also, if any one knows what the measurement on the 600Z, from the rear of the hood latch mount to the fire wall is?  I have had to do some major body work on the front end and can't tell if I have the section between the headlight in line.
> > Thanks, Jason
> > Do you Yahoo!?
> > Yahoo! Mail Plus
> > Sign up now
> > Your use of Yahoo! Groups is subject to the
> > ATTACHMENT part 2 application/octet-stream name=c-ch08.jpg
Do you Yahoo!?
Yahoo! Mail Plus
Sign up now
