Muffler
Re: Muffler
Here's the part number of the muffler I used last time I built one
from scratch. It's the correct length, but slightly fatter. The
original muffler is only 5" in diameter. All the USA sold cans I
found were 6".
After I bought the muffler, I bought some various bends to achieve
what was like stock. The main can is 6" round with 1 1/2" inlet and
outlet, just like original and is 12" length. The part is IMCO brand,
aluminized for longer life, part # CM-43. A cross reference to Walker
would be #17871.
found were 6".
would be #17871.
verylucky134some
Re: Muffler
So some poor New Zealand muffler maker goes with out lunch this week
and a huge whole has now been placed in the New Zealand export drive.
Hey Im just haveing fun no offence intented... Cheers Kiwi Wayne
> found were 6".
brand,
Walker
> would be #17871.
, "verylucky134some"
> > Hi Linda
> > Well Ive done the measure up and the muffler is
12inches
> > long and 16inchces round with off set intake and output.
> > Sorry I could not find any numbers any where. But if this will do
> the
> > job Im happy to hunt it down at the muffler shop for you.
> > When I had mine done I see that they took the bracket on the side
> and
> > welded it to the new muffler to meet up with the mounting point
on
> > the chassis.
> > Cheers and let me know Kiwi Wayne.
, "Linda Classon" > accidents@> wrote:
> > > Thanks!!!
> > > Linda
> > > On 20 Aug 2007 at 6:19, verylucky134some wrote:
> > > > Hi Linda Heres what I will do, I will measure mine up and
you
> > can
> > > > tell me if thats the size you need. They make universal
> mufflers
> > down
> > > > here in New Zealand mine cost around $110.00 NZ dollars about
> $80
> > USD
> > > > right now I think. If it s what you need I will get the model
> > number
> > > > and the shop to contact and you can deal with them direct.
> > > > Its not a genuine part but will do the job as mine did,
better
> > than a
> > > > tin can anyway. Cheers Kiwi Wayne Auckland New Zealand
> > > > --- In
, "Linda Classon"
> > > accidents@> wrote:
> > > > > It's the round one.
> > > > > On 18 Aug 2007 at 22:37, wayne roberts wrote:
> > > > > > Ok Is it the the long flat one or the round one at the
> > > > > > back that you are looking for ?
> > > > > > I have just been down this track for my LN360 and
> > > > > > managed to find one that fitted at the rear.
> > > > > > If its the longflat One up front I cant help.
> > > > > > Cheers Kiwi Wayne
> > > > > > I assume that the LN360 and the 600n are the same in
> > > > > > the exhaust department.
> > > > > > --- wheee_1 wrote:
> > > > > > > My '71 600N is finally up and running again but
> > > > > > > needs a new muffler.
> > > > > > > At the moment it's a soup can held on with a couple
> > > > > > > of clamps, which
> > > > > > > actually seems to work pretty well. Any
> > > > > > > recommendations on where to
> > > > > > > get a replacement muffler?
> > > > ______________
> > > > > > Boardwalk for $500? In 2007? Ha! Play Monopoly Here and
Now
> > (it's
> > > > updated for today's economy) at Yahoo! Games.
http://get.games.yahoo.com/proddesc?
> gamekey=monopolyherenow
Linda Classon
Re: Muffler s in New Zealand.
Hi Kiwi Wayne,
Thanks for measuring the muffler but now I'm confused. I think
mine may be slightly different because it's definitely 13 inches
(vs. 12) long. If I use the 12" replacement muffler I'll probably
have to get new pipes too (?). I'll check into the one Miles
mentioned and see what they cost around here (best price
wins).
Thanks for all your help. I may yet save the New Zealand
economy from ruin!
Linda
wins).
economy from ruin!
Linda
On 26 Aug 2007 at 6:59, verylucky134some wrote:
> Hi Linda
> Well Ive done the measure up and the muffler is 12inches
> Sorry I could not find any numbers any where. But if this will do the
> When I had mine done I see that they took the bracket on the side and
> welded it to the new muffler to meet up with the mounting point on
> the chassis.
, "Linda Classon" accidents@...> wrote:
> > Thanks!!!
> > Linda
> > > Hi Linda Heres what I will do, I will measure mine up and you
> can
> > > tell me if thats the size you need. They make universal mufflers
> down
> > > here in New Zealand mine cost around $110.00 NZ dollars about $80
> USD
> number
> > > Its not a genuine part but will do the job as mine did, better
> than a
, "Linda Classon" > > accidents@> wrote:
> > > > It's the round one.
> > > > > Cheers Kiwi Wayne
> > > > > > of clamps, which
> > > ______________
> > > > > Boardwalk for $500? In 2007? Ha! Play Monopoly Here and Now
> (it's
http://get.games.yahoo.com/proddesc?gam ... olyherenow
verylucky134some
Well they say everything is bigger in the U.S.A just as well your not
from Texas. It may be a long time between lunches for these guys.
Just let me know and if I can help I will Cheers Kiwi Wayne
Linda Classon
Re: Muffler
I contacted the closest IMCO to me (New Jersey) and they were able to send
me the muffler. Thanks for pointing me in the right direction.
Linda
Linda
> found were 6".
> would be #17871.
> > Hi Linda
> the
> and
> > the chassis.
> > > Thanks!!!
> > > Linda
> > can
> mufflers
> > down
> $80
> > USD
> > number
> > than a
> > > > --- In
, "Linda Classon" > > > accidents@> wrote:
> > > > > It's the round one.
> > > > > > Cheers Kiwi Wayne
> > > > > > > of clamps, which
> > > > ______________
> > (it's
Kevin Gailey
Muffler
Has anyone tried a muffler for a Polaris? This looks like it will work.
Kevin Gailey
Kevin Gailey
Re: Muffler
What model? Do you have a link we can use?
John Graf
John Graf
> Kevin Gailey
Kevin Gailey
Re: Muffler
Polaris xlt 600, there are 3 on eBay as well as a a few others that have the inlet mounted on side of canister.
Kevin Gailey Sent from my iPhones
John Graf
> Kevin Gailey
Re: Muffler
You can buy a stainless steel muffler from Peter Rose/Sherwood Garage in Birmingham England. It will be the last muffler you need. Coupe muffler is $400 + shipping. (I'm too cheap, I just make my own)
http://www.ebay.com/itm/18307-623-671-H ... 23128b88d2
> Kevin Gailey
> > John Graf
> >> Kevin Gailey
Kevin Gailey
Re: Muffler
Seriously? $ 400.00? It better add 50 h.p. and make woman irresistible to my charms.
Kevin From:
feltonminicycle To:
Sunday, October 30, 2011 5:13 PM Subject:
[2cylinderhondas] Re: Muffler
Kevin From:
feltonminicycle To:
> Kevin Gailey
> > John Graf
> >> Kevin Gailey
