good luck. i had to use three adapters from a braided brake line set> Hi all,
> This message is for all those who have bypassed their remote booster.
> What is the part # and Manufacturer of the "T" that you are using. As
> best I can tell I have a M10X1.5 inverted flare on the brake lines. I
> have tried several local parts places but none have the T that I need.
> Some have adaptors from standard to this pattern, but none the other
> way.
> I really do not want to replace all the brake lines from the MCyl to
> the ruberized lines with a standard line and use these adaptors, but it
> is looking like that is what is going to happen.
> Anyway, I appreciate any and all help.
> KC and the Z
into a steel block that i machined with three holes to accept the
adapters it sits where the booster used to
