I just went out to look at what you are talking about. I couldn't
understand how I put this window in sooo easy with the Isetta rubber.
First off, the reason I did it in the first place is someone had
messed up the rubber. It's the only one I've done. I looked at the
back window of my other car, and the molding is different. After
looking it over, the window in the one I did sits back in farther.
Someone took the original window and must have took it to a glass
shop and had the outside perimeter ground off to fit a normal seal. I
guess. So, I see exactly what you mean now. I'll need to get the
correct seal for my other car. The Isetta seal will not work on a
stock piece of glass.
Greg
, wrote:
> From: billmyong@... [mailto:billmyong@...]
> Sent: Tuesday, November 27, 2007 12:25 AM
> To: Anzhonda600owners;
> Cc: isettas@...
> Subject: RE: [2cylinderhondas] Re: Windshield rubber
> Bill Greg;
> When was the last time you put an Isetta windshield seal in a
Honda
> 600? My problem with people that insist on making statements they
can't
> back up, causing others to destroy original parts to what end I
don't know
> is really puzzling. And, what is the $55.00 for the Isetta seal
but make
> sure you purchase more so that you will have enough? So it's not
$55.00 for
> the seal, it's more because the seal for the Iseta rear window is
much
> smaller than a Honda 600 rear window and even smaller yet for the
Front
> windshield.
> With this kind of lunacy it's a wonder we aren't using Ribbon
Sealer
> from 3M. You can pick up a box for about $40.00 bucks (Part number
08612).
> Oh by the way, 3M stopped selling it to Just anyone because of the
problems
> they were having with Do-It-yourselfer's. Trying to make it do
things it
> wasn't designed for.
> Greg, a great idea, but you have to try them out first.
]On Behalf Of Greg Hahs
> Sent: Monday, November 26, 2007 4:09 PM
> Subject: [2cylinderhondas] Re: Windshield rubber
> Isettas-r-us
> Werner Schwark he's in Georgia. isettas@... make sure you
> ask for the correct length, they are cut short on the Isetta
and you
> need to make sure you get them longer.
> Greg
, brucerb@ wrote:
> > where do i find these seals? BMW dealer? thanks, bruce
> > -------------- Original message --------------
> > From: "Greg Hahs"
> > You must have this seal confused with something else. The
Isetta
> does
> > not have a narrow inner lip, (I've installed over a hundred)
the
> ones
> > with those are designed to go onto the glass first and then
sat in
> > the window opening with a cord in the outer channel that pulls
> > the "NARROW" section around the metal. The Isetta is exactly
like
> the
> > Honda with a locking strip. It goes into the opening first
and the
> > glass sat into the bottom channel and the rest pulled over the
> glass
> > with the curved tool. (real easy) Then the locking strip goes
in
> with
> > the special locking strip installation tool that can be
bought at
> any
> > auto parts store. The cross section of the Isetta seal is so
close
> to
> > the cross section of the Honda that you can't measure the
> difference
> > with a set of calipers. These come with a locking strip for
right
> > around $55.00. Come to think of it, I have never seen a
locking
> strip
> > seal with a narrow inner lip, but that doesn't mean there
aren't
> any.
> > Greg
, wrote:
> > > Greg;
> > > The Isetta seal has a narrow inner lip wich makes it very
hard
> > to put
> > > into a Honda to the extent that windshields have been broken
> while
> > trying to
> > > put them in. And, the narrow inner lip can let go with a
good
> > bump.
> > > There are a couple of seals that are close, but have you
tried
> > them? After
> > > a couple of broken windshields I have gone to making my own.
> > > Bill
> > > [mailto:
]On Behalf Of Greg
Hahs
> > > Sent: Sunday, November 25, 2007 8:45 AM
> > > Subject: [2cylinderhondas] Windshield rubber
> > > I restore Isettas, and have found that the rubber for the
> > windshields
> > > and rear window are nearly a perfect match with the ones on
the
> > Honda.
> > > Around $55.00 each including the locking strip.
> > > Greg
