If the OD is too large you will have to get your primary cover
machined to fit. The seal metal will be too thin to grind down unless
it's just a couple thous. If the seal loosens and falls out you will
quickly lube up your clutch.
can't find seal
lshonda310
Re: found seal
the OD is only .5mm bigger, so I think it will fit. The width of the
seal is 11 mm, while the original width is 8 mm. The seal I found has
a sort of splash gaurd that can be taken off to make the width less.
I am going to take the clutch drum and put it against the primary
drive (off of the car) and see how much space there is to work with
for the seal.
for the seal.
unless
will
, "lshonda310"
> > I actually havn't put it in yet, and I think I will have to trim
it
> > down a bit because it is wider than the original seal. But it is
> > metal on the outside, so it will be easy to trim, but need to
have
> > sealant put on before install. When I am for sure it will work I
> > will post it here.
, "Miles" wrote:
> > > Can you tell us the seal dimensions? so the next person can
> benefit
> > > or the part number from the box and manufacturer?
> > > Miles
, "lshonda310"
> > > wrote:
> > > > I took it apart last night and I have the larger rectangular
> > > rubbers,
> > > > but only 4 out of 8 were there- the setting plate came apart
> and
> > > let
> > > > 4 of them fall out and get ground up!!! I have all the
debris
> > > > cleaned out and bought another primary drive setup with
> > rectangular
> > > > rubbers. I did find a seal that will work, we crossed the
> metric
> > > > seal over to US size and found one that will work.
> > > > My '71 N600 has about 70,000 miles on it.
> > > > --- In
, goinhm@ wrote:
> > > > > Sounds like you are working on the primary drive area.
When
> > you
> > > > take the
> > > > > cover off the sprocket, check the cushions. They are a
rubber-
> > > type
> > > > material.
> > > > > The early style were round and the later style were
> > > rectangular.
> > > > If you have
> > > > > the round style, you do not want to re-use them. You
want
> > the
> > > > drive with
> > > > > the rectangular cushions.
> > > > > good luck,
> > > > > Dale
> > > > > PS I am referring to the sprocket behind the clutch.....not
> the
> > > one
> > > > on the
> > > > > crankshaft.
> > > > > the shaft is tight and spins freely, but I will take the
> side
> > > > cover
> > > > > off and the sprockets and inspect everything, I have to
> remove
> > > the
> > > > > cover and remove the debris anyways.
> > > > > **************Get the scoop on last night's hottest shows
and
> > the
> > > > live music
> > > > > scene in your area - Check out TourTracker.com!
http://www.tourtracker.com?NCID=aolmus00050000000112)
lshonda310
Re: found seal
I was able to get the seal to work, I have driven the car over 100
miles so far, and no leak! The seal is a Timken seal, and the part
number is 451143. The dimensions are 2.625 x 3.251 x .437, I did
remove the "splash gaurd", which was the metal OD doubled, so I
removed half of the strength of the seal, but I put loctite on the OD
and RTV on the outside with seal in place. When driving the seal in
it is best to do if the side cover is off of the car.
