Looks like Miles will give you both check valves for $25. They are located under the 3/4 inch nut on top of the MC. When you remove the check valves, keep track of which came from the front and rear section of the MC. If your MC is original, the two check valves should be slightly different.....looking at the top you will
see one which has a small notch. Under each check valve, you will find two holes in the body....a very small hole and a larger hole.
Check the very small hole is clear and not plugged..... this was one of the problems I had with my MC. Also remove the low brake pressure senders (2 of them) and clean out those passages.
For the MC to work properly, it needs to be very clean inside.
Looking for a car that's sporty, fun and fits in your budget?> Miles, Thanks for
> the info. Going to try one more thing and if that don't > work
> I'll be ordering some parts. Really believe I can get by
> without re-sleeving as it
> looked good and smooth to me. On the check valves {is
> that the 3/4 inch deals on top of MC?} is that each or pair.
> I'll be back in touch if this maneuver
> fails.
Read reviews on AOL Autos .
