new shocks and air filters
Re: new shocks and air filters
Post by feltonminicycle »
Looks like a used stock shock. Do you have a picture of the repro shock?
, Kevin Keough wrote:
> heres a photo of the air filter and shock the filter is washable Kevin
> --- On Sat, 9/19/09, dean m wrote:
> From: dean m
> Subject: Re: [2cylinderhondas] new shocks and air filters
> Date: Saturday, September 19, 2009, 5:12 PM
> Im in for the shocks , send a pic thanks Dean �
> --- On Sat, 9/19/09, Kevin wrote:
> From: Kevin
> Subject: [2cylinderhondas] new shocks and air filters
> Date: Saturday, September 19, 2009, 9:52 AM
> the shocks will be available at the end of the month there will be 100 of them I have the proto type air filter done. email me a i can send a photo and more info Kevin
Re: Help: Rear Brake Stuck
I like to use a 5 pound sledge ! With the wheel on (stock steel wheel) hub cap off, a steady blow to the wheel at the strongest point between the lug nuts will usually allow the wheel to turn.
A 71 Honda is the split year where the adjusters are either inside the drum or on the back side. If you have the stainless side trim you should have the adjuster on the back side of the brake plate. Easy to adjust if on the back. If adjuster is inside the drum you will have to rotate and look in drum with a penlight. Go Lefty-Loosey on the screw adjuster.
, John Ledford wrote:
> 71 N600 rear drum is stuck, will not turn.� It seems like its the emergency brake that is stuck on. The cable is free and has slack.� The drum will not move?� Any advice would be great. Thanks, John
> From: dean m
> Date: Saturday, September 19, 2009, 1:12 PM
> From: Kevin
TOM THIES
Post by TOM THIES »
I am in for most likely two sets.  four shocks..
tdthies1@...
     Oregon
> Dave
> Sunday, September 20, 2009 4:54
> [2cylinderhondas] Re: new shocks
> and air filters
> "Kevin" wrote:
> > the shocks will
> be available at the end of the month there will be 100 of them I have the > proto type air filter done. email me a i can send a photo and more info > Kevin
> I'm in for at least one set of shocks maybe two because
> my friend may also take a set. Are the air filter the washable type by any > chance? You can email me a pic at > nydyna88@yahoo. com > .
> Thanx
> Dave Kohn
> Long Island,NY
misterpoopoohead
Post by misterpoopoohead »
I'm in for two sets of shocks. Thanks!
Kevin Lister Sent from my Verizon Wireless BlackBerry
Date: Mon, 21 Sep 2009 15:32:04 -0700
Subject: Re: [2cylinderhondas] Re: new shocks and air filters
tdthies1@msn. com      Oregon
> Dave
> Sunday, September 20, 2009 4:54 AM
> I'm in for at least one set of shocks maybe two because my friend may also take a set. Are the air filter the washable type by any chance? You can email me a pic at > nydyna88@yahoo. com > . Thanx > Dave Kohn > Long Island,NY
Mike
Post by Mike »
Please put me down for a set as well! (if there are any left!)
Mike
> I'm in for at least one set of shocks maybe two because my friend may also take a set. Are the air filter the washable type by any chance? You can email me a pic at nydyna88@.... Thanx
> Dave Kohn
> Long Island,NY
TOM THIES
Post by TOM THIES »
Kevin.  have you got those shocks in yet?
> Dave
> and air filters
> "Kevin" wrote:
> > the shocks will
> Thanx
> Dave Kohn
> Long Island,NY
