conversion of honda 600 to electric
Tom Rapini
Re: conversion of honda 600 to electric
Post by Tom Rapini »
What Dale has put here in regard to the sedan I converted to electric is accurate.
http://www.evalbum. com/325.html
The wife drove it 3 miles to work and back today as she has almost every day for the last 16 years.
In deference to those who think we should be preserving these cars, the last body I got was just a shell, stripped of all parts of value.  Seems to me its the engine parts that are precious.   From this newsgroup I get the impression that out west its not hard to come across a rust-free body, but hard to find an engine worth rebuilding.
Regarding the 600 running "...cheaper than any electric car", it costs about 2.6 cents per mile to run mine on electric.  Of course the sun makes most of my electricity, so cost is relative...  relative as in what's the "true" cost of running your 600 on gasoline that we fight wars for, clean up massive spills from, and can partly blame for global climate change that will probably forever change our children's future.
Sorry, a bit political, but I couldn't let it go unsaid.
Anyone serious about doing the conversion I would be glad to offer some advice, photos, and sketches, but as I said to Dale, I think there are better choices for a conversion these days than the old 600's.
Tom
> goinhm@...
> Monday, May 31, 2010 3:40 PM
> Re: [2cylinderhondas] conversion
> Hi Paula,
>     Check with Tom in Ohio (
> tom@...
> ).  He monitors this
> newsgroup and has converted his Honda 600 sedan to electric.  Here is > what he told me;
> That's my converted Honda at
> The $2000 cost is parts only, my
> hundreds of hours of labor were free, I guess.
> Low cost listed there
> is due to:
> 1) surplus electric traction
> motor found for only around $300
> 2) lead acid batteries costing only
> about $70 each when I did it
> 3) controller costing only about
> $800 when I did it
> 4) all other mechanical and
> electrical parts being made by me
> The 600 was a good choice when I
> first made this conversion in 1993.  Very small and light with a > sturdy chassis that seems to handle the battery weight OK.
> 16,000 miles (and two bodies) later we still use the car almost every > day.  However, with parts becoming more scarce, plus the lighter, safer > designed vehicles available today, I think I would start with a different > vehicle for the conversion if I were starting now.
> Tom
>      Converting your car to electric could become a
> major undertaking and it depends on how you want to use the car.  If you > goal is to have a car you drive in your local neighborhood and your top speed > is going to be 25 mph,  you could do the conversion by obtaining > a used golf cart and putting its drive system into your car.
> If you are interested in a car which can be driven on the freeway and has a > range of 100 miles before recharge, you would be better off buying an > electric car instead of converting your Honda.   For more > information on converting your car to electric, check out one of the electric > car groups (e.g.
> http://www.diyelectriccar.com/
>       If you are interested in a car which runs
> on an alternative energy source,  you might consider converting your > Honda car to run on alcohol or propane.  Propane  fuel has about the > same energy content as gasoline and the conversion involves replacing the > carb, fuel tank, and adjusting the timing.  The fuel system for the car > can be 2 of those propane tanks used on a propane grill.  You fill them > up just like you do for your grill.
> Converting your car to alcohol (which has about half the energy content > as gas) would involve rejetting the carb, changing out the fuel system from > the gas tank to the carb (replacing all the "rubber" parts which used to > handle gasoline including the gaskets and o-rings in the carb and at the > intake manifold).  The timing would also need to be > readjusted.   The downside of a car running on alcohol (and you > might want to run it on E85 instead of pure alcohol) is that alcohol absorbs > moisture very readily and if you are not using your car frequently,  the > fuel may become spoiled from the moisture found in the air (i.e.
> humidity variations).  The upside of alcohol is that you could > make the alcohol yourself out of newspaper,  junk mail, > yard debris,  food scraps,   wood scraps,  anything which > is organic.  You are pretty much becoming a moonshiner to produce > alcohol fuel for your car.
> good luck,
> > hey
> > was wondering if anyone knows about converting a honda 600 to electric...i > > have four of the little jewels just sitting here going to waste and thought > > maybe conversion is the answer...any help will be > > appreciated. ..paula
Post by lyletrudell »
Tom, don't want to argue about cost gas/electric or get into politics, not the place for it.
One thing I agree with is that there are better choices for an electric conversion than a Honda 600.
On the east coast engines are available, west coast good body shells, lets get them together.
I need a good body shell, have a good drivetrain.
See we can get along!
http://www.evalbum.com/325.html
> Tom
> From: goinhm@...
> Sent: Monday, May 31, 2010 3:40 PM
> Subject: Re: [2cylinderhondas] conversion of honda 600 to electric
> Hi Paula,
> Check with Tom in Ohio (tom@...). He monitors this newsgroup and has converted his Honda 600 sedan to electric. Here is what he told me;
> The $2000 cost is parts only, my hundreds of hours of labor were free, I guess.
> Low cost listed there is due to:
> 1) surplus electric traction motor found for only around $300
> 2) lead acid batteries costing only about $70 each when I did it
> 3) controller costing only about $800 when I did it
> 4) all other mechanical and electrical parts being made by me
> The 600 was a good choice when I first made this conversion in 1993. Very small and light with a sturdy chassis that seems to handle the battery weight OK. 16,000 miles (and two bodies) later we still use the car almost every day. However, with parts becoming more scarce, plus the lighter, safer designed vehicles available today, I think I would start with a different vehicle for the conversion if I were starting now.
> Tom
> Converting your car to electric could become a major undertaking and it depends on how you want to use the car. If you goal is to have a car you drive in your local neighborhood and your top speed is going to be 25 mph, you could do the conversion by obtaining a used golf cart and putting its drive system into your car. If you are interested in a car which can be driven on the freeway and has a range of 100 miles before recharge, you would be better off buying an electric car instead of converting your Honda. For more information on converting your car to electric, check out one of the electric car groups (e.g.
http://www.diyelectriccar.com/)
> If you are interested in a car which runs on an alternative energy source, you might consider converting your Honda car to run on alcohol or propane. Propane fuel has about the same energy content as gasoline and the conversion involves replacing the carb, fuel tank, and adjusting the timing. The fuel system for the car can be 2 of those propane tanks used on a propane grill. You fill them up just like you do for your grill.
> Converting your car to alcohol (which has about half the energy content as gas) would involve rejetting the carb, changing out the fuel system from the gas tank to the carb (replacing all the "rubber" parts which used to handle gasoline including the gaskets and o-rings in the carb and at the intake manifold). The timing would also need to be readjusted. The downside of a car running on alcohol (and you might want to run it on E85 instead of pure alcohol) is that alcohol absorbs moisture very readily and if you are not using your car frequently, the fuel may become spoiled from the moisture found in the air (i.e. humidity variations). The upside of alcohol is that you could make the alcohol yourself out of newspaper, junk mail, yard debris, food scraps, wood scraps, anything which is organic. You are pretty much becoming a moonshiner to produce alcohol fuel for your car.
> good luck,
> hey was wondering if anyone knows about converting a honda 600 to electric...i have four of the little jewels just sitting here going to waste and thought maybe conversion is the answer...any help will be appreciated...paula
lostideas
Post by lostideas »
this guy is doing a really nice ev conversion but its not done yet.. he went above and beyond. should look really nice when finished http://hectorschopshop.com/7401.html
> Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox.
> http://www.windowslive.com/campaign/the ... P:042010_1
Jerry A
Post by Jerry A »
sorry bad hyper link first time around  .. http://hectorschopshop.com/7401.html
Wed, 6/2/10, lostideas
> From: lostideas
> Subject: [2cylinderhondas] Re: conversion of honda 600 to electric > To: 2cylinderhondas@yahoogroups.com > Date: Wednesday, June 2, 2010, 1:01 AM
> this guy is doing a really nice ev conversion but its not done yet.. he went above and beyond. should look really nice when finished > http://hectorschops hop.com/7401. html
> --- In 2cylinderhondas@ yahoogroups. com, Allen Brown wrote:
> > hey was wondering if anyone knows about converting a honda 600 to electric...i have four of the little jewels just sitting here going to waste and thought maybe conversion is the answer...any help will be appreciated. ..paula
> > ____________ _________ _________ _________ _________ _________ ________ > > Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox.
> > http://www.windowsl ive.com/campaign /thenewbusy? ocid=PID28326: :T:WLMTAGL: ON:WL:en- US:WM_HMP: 042010_1
misterpoopoohead
Post by misterpoopoohead »
Hi Bill,
I don't think any of us are actually telling her not to do it. Just pointing out pros and cons and including our opinions. Its just that there are fewer of these cars on the road each year that are in stock condition. I suppose some of us are a bit too purist. ;o)
Kev Sent from my Verizon Wireless BlackBerry
william esker
Date:
Tue, 1 Jun 2010 19:55:03 -0700 (PDT)
don't listen to all these guys, i converted one of my two 600's to electric after talking to tom. the other one i'm restoring. go ahead and do it. i got all my parts fromEVA, great guys. if i deceide  to i could back convert the car with little difficulty, the crank was shot anyway!   Bill
Mon, 5/31/10, Allen Brown
> From: Allen Brown
> Subject: [2cylinderhondas] conversion of honda 600 to electric > To: "electric conversion" , "Honda600 group" > Date: Monday, May 31, 2010, 5:48 AM
> Learn more.
promoter213
Post by promoter213 »
wow what a wonderful and overwhelming series of responses...smile...thanks to all of you who commented...i guess i am just frustrated...i bought all five of these in 2006 with all the hope and enthusiasm of any proud new parent...but alas my dreams took a sad down turn in a series of unfortunate events with the loss of my dad, my mother moving in with me, the closing of my beloved bbq business and my own little tiny heart attack (ie:"it was barely bad enough to call it a real heart attack ms. allen")...ha...lets see what he says when he gets kicked awake by a donkey throwing fits in his chest...but i digress...anyway i still love my little cars i am just so ready to do something with them and my money has all evaporated but not my love for the cars...after that guy took my best one apart and then left it abandoned in someone else's garage it kinda took the wind out of my sails - especially since i had advanced him a good deal of money...(picture me here kicking my own butt)...when i graduated from high school in 1973 this was THE car to have (well that or a 1966 mustang if you could afford it) and i guess i have never given up the dream no matter how tarnished or dim it might have grown...thanks again to all of you who responded...you have given me much to think about...meanwhile 3 of my little darlings languish out in a field and the 4th is in pieces in a garage while i try to recoup and devise a plan...i am only hoping that the 5th one i had is being taken care of by the guy i sold it to...again thanks and peace out...paula
Date: Tue, 1 Jun 2010 17:05:37 +0000
It has been done.
Here's the first one I'd seen from a while back:
Only goes 45 or 50 mph, but it is older technology.
Another on evalbum:
http://www.evalbum.com/1238
Look half way down on this page:
http://mind-temple.com/600/humor.htm
72hp motor to be installed later? Believe me - 70+ horsepower is fun in these little cars.
The one thing I would say though - please try to save as many parts as you can when you do the conversion. Keep the motors dry, don't let water into them. Someone on the list can use the parts!
The New Busy is not the too busy. Combine all your e-mail accounts with Hotmail.
Get busy.
promoter213
i had even considered a trade whereby i give someone 3 of the cars in exchange for them fixing up the 4th for me...i also have a small array of spare parts and an extra windshield, back glass and door windows as well as a whole set of new tires to be used as needed...the problem is i am in central texas (waco) and no one around here knows enough to even consider the trade idea...
It has been done.
Another on evalbum:
The New Busy is not the old busy. Search, chat and e-mail from your inbox.
Get started.
promoter213
and there you have touched on another reason for my wanting to convert to electric...my feeling that soon we will be hurting more than we are now for fossil fuels as they use these more and more for political pressure...i also am trying to use the wind and sun to power everything that i have as i look to moving out to my 6 acre piece of heaven so electric makes sense to me even though i can't help but want to have at least one of these running as an original...i would even consider trading one or two of them for an already running electric vehicle of any kind and keep the other two to fix up...thanks for your comments and perspective...
Date: Tue, 1 Jun 2010 23:04:46 -0400
Tom
> goinhm@...
> Hi Paula,
> tom@tingsys. com
> ).  He monitors this
> is due to:
> $800 when I did it
> Tom
> http://www.diyelect riccar.com/
> good luck,
> > hey
Get started.
CHEYENNE FLETCHER
Post by CHEYENNE FLETCHER »
Hey. do you have any tail lights with lenses??
> Allen Brown
> Honda600 group
> Wednesday, June 02, 2010 4:52
> RE: [2cylinderhondas] Re:
> i had even considered a trade whereby i give someone 3 of the cars in > exchange for them fixing up the 4th for me...i also have a small array of > spare parts and an extra windshield, back glass and door windows as well as a > whole set of new tires to be used as needed...the problem is i am in central > texas (waco) and no one around here knows enough to even consider the trade > idea...
> jpro8071@yahoo. com
> electric
> It has been done.
> while back:
> Only
> Another on
> evalbum:
> http://www.evalbum. com/1238
> Look
> http://mind- temple.com/ 600/humor. htm
> 72hp
> motor to be installed later? Believe me - 70+ horsepower is fun in these > little cars.
> many parts as you can when you do the conversion. Keep the motors dry, don't > let water into them. Someone on the list can use the parts!
> Allen Brown wrote:
> > hey
> was wondering if anyone knows about converting a honda 600 to electric...i > have four of the little jewels just sitting here going to waste and thought > maybe conversion is the answer...any help will be > appreciated. ..paula
> Hotmail has tools for the New Busy. Search, chat and e-mail from your > inbox.
> Get started.
CHEYENNE FLETCHER
Hey Allen. Get a service manual and re-assemble you car. They are simple to work on. 1 person can drop the motor in a few hours. Or you can rebuild the top end with it in the car. I trust you have recovered all the parts. It sucks that people are so flakey . What are the types of Hondas you have ? All N600 or are they Z coups??These things are like kittens to me I can't help but save every one I find. 3 so far. I have my eyes on 2 more I found during a Harley excursion I took a few weeks back. Arizona cars with pristine bodys.
> Allen Brown
> Honda600 group
> Wednesday, June 02, 2010 4:46
> responses... smile...thanks to all of you who commented... i guess i > am just frustrated.. .i bought all five of these in 2006 with all the hope > and enthusiasm of any proud new parent...but alas my dreams took a sad down > turn in a series of unfortunate events with the loss of my dad, my mother > moving in with me, the closing of my beloved bbq business and my own little > tiny heart attack (ie:"it was barely bad enough to call it a real heart attack > ms. allen")...ha. ..lets see what he says when he gets kicked awake by a > donkey throwing fits in his chest...but i digress...anyway i still love my > little cars i am just so ready to do something with them and my money has all > evaporated but not my love for the cars...after that guy took my best one > apart and then left it abandoned in someone else's garage it kinda took the > wind out of my sails - especially since i had advanced him a good deal of > money...(picture me here kicking my own butt)...when i graduated from high > school in 1973 this was THE car to have (well that or a 1966 mustang if you > could afford it) and i guess i have never given up the dream no matter how > tarnished or dim it might have grown...thanks again to all of you who > responded... you have given me much to think about...meanwhile 3 of my > little darlings languish out in a field and the 4th is in pieces in a garage > while i try to recoup and devise a plan...i am only hoping that the 5th one i > had is being taken care of by the guy i sold it to...again thanks and peace > out...paula
> jpro8071@yahoo. com
> electric
> It has been done.
> while back:
> Only
> Another on
> evalbum:
> Look
> 72hp
> Allen Brown wrote:
> > hey
> The New Busy is not the too busy. Combine all your e-mail accounts with > Hotmail.
> Get busy.
