But some vintage cams need to be welded and reground, that can cost $1,000+.
I would say $125-$200 with your good core, is about the range.
I will get a price from Cam Techniques for a Honda cam next week.
http://www.camtechniques.com/
Oh, I have a Haas machining center, yes it's fun to play in the shop.
http://tru-craft.com/
, "CHEYENNE FLETCHER" wrote:
> Wat does it cost to have a custom grind done??
> From: lyletrudell
Sent: Friday, July 30, 2010 11:41 AM
> Subject: [2cylinderhondas] Re: Cam grind specs?
> Thanks Jpro, I couldn't find it in the coupe or haines manual.
> Your race background will be helpful in designing a good hot street cam.
> Not sure if the Hawaiian cam is our best cam design or not.
> It sounds like it moves the power band up in rpm.
> Not sure what it does for low end torque.
> I have a great cam grind shop just south of me. He has ground cams for me in the past. Dave is the owner, nice guy and quality work.
http://www.camtechniques.com/ I emailed him about the Honda cam yesterday.
> I will look at my notes on cam design and see what I can find.
> Cam design is a balancing game between high rpm power and drivability. I want my coupe to be a little better than stock.
> Lyle
, "jpro8071" wrote:
> > Page 4-1 of the blue manual "Honda 360/400/600 Sedan & Van" shows the following for the 600:
> > Valve timing (at 1mm, 0.039in. cam lift)
> > 1969 1970
> > Inlet valve open btdc 0 5
> > Inlet valve close abdc 40 20
> > Intake Duration (calc) 220 205
> > Exhaust valve open bbdc 40 40
> > Exhaust valve close atdc 0 10
> > Exhaust Duration (calc) 220 230
> > Overlap (calc) 0 15
> > ("calc" entries made using
http://www.rbracing-rsr.com/camshaft.html )
> > I don't think there is any difference in lift, since page 4-25 step 4 does not differentiate for the two cams for lobe height. Note that all of this is from the manual - I haven't checked the numbers myself.
> > Besides differences in duration, pay attention to overlap . . .
> > I've got a spreadsheet somewhere of other race cam specs, will try to dig it up.
, "lyletrudell" wrote:
> > > Bill, I don't have a sedan shop manual.
> > > Can you scan it?
> > > Or send me a copy with the window seals I ordered from you.
> > > Are these numbers like a cam grind sheet?
> > > Like Duration, lift, intake open 0 degree's BTDC at 1mm lift?
> > > I want to buy a hotter cam or get one of my cams ground and then degree the cam.
> > > Thanks
> > > Lyle
, wrote:
> > > > Hi Lyle;
> > > > Yes, it is in the Sedan shop manual. First section.
> > > > Bill
> > > > -----Original Message-----
> > > > From:
> > > > [mailto:
]On Behalf Of lyletrudell
> > > > Sent: Wednesday, July 28, 2010 1:38 PM
> > > > To:
> > > > Subject: [2cylinderhondas] Cam grind specs?
> > > > Does anyone know where I can find the cam grind specs for the stock and Hawaiian cam?
> > > > I want to build one stock and one slightly hotter engine.
> > > > This would also be good info for degreeing the cam.
> > > > Thanks
> > > > Lyle
> > > > �l
