72 honda coupe brake booster rebuild kit or brake booster
Jerry
Re: booster on ebay
Post by Jerry »
Anyone ever think of using the british remote mount boosters? Looks like you would just need to change a few fitting at the booster its self but they are available brand new and readily available.
Sent: Thursday, August 26, 2010 3:28 AM
Subject: [2cylinderhondas] Re: booster on ebay
I send my brake boosters to Karps in California to be rebuilt, not cheap for a rebuild however. Not sure if he could offer a kit as there are three different styles of boosters for the N600 and one for the Z600. Intenal parts could be interchangeable between the boosters also, Miles will know the answer to that question.
, dean m wrote:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... OTORS:1123
> --- On Wed, 8/25/10, lyletrudell wrote:
> From: lyletrudell
> Subject: [2cylinderhondas] brake booster parts and restoring a Honda!
> Date: Wednesday, August 25, 2010, 6:23 PM
> It's only our braking system!
> Nothing to worry about.
[The entire original message is not included]
Brake booster rebuild
Post by lyletrudell »
Jerry that is a thought.
I really would like to keep the car stock if possible, because they are getting so rare.
I have one diaphram that is in good condition and should be able to get one good unit from the 3 I have.
I have found O-rings for the booster.
We need:
*piston seal
*diaphram
*Relay piston parts.
OK, let's say we can't get booster parts.
Do we need power assited front brakes?
What about bypassing the booster and use a proportioning valve so we can adjust front to rear brake bias?
http://www.jegs.com/c/Brakes-Drivetrain ... 5/10002/-1
Simple, cheap and they work great!
> From: honda600wiz
> > From: lyletrudell
This proportioning valve would work perfect!
http://www.jegs.com/i/JEGS/555/63020/10002/-1
Mount on the firewall and run the rear line to the valve and then to the back as original.
Then re-route the front lines direct from the master cylinder to the front calipers.
Keep the booster for the "stock" look!
I can't believe the pedal pressure is to great without the booster.
> We need:
> *piston seal
> *diaphram
> Lyle
> > From: honda600wiz
> > > From: lyletrudell
Re: booster on ebay
Post by feltonminicycle »
Probably wont work because a Honda 600 draws such a low vacuum less than 10 a real car pulls like 30 ?
> From: honda600wiz
> > From: lyletrudell
proprotioning valve
Honda 600 already has a proportioning valve.
The brake booster only operates the front brakes.
Without the booster you need to plan ahead for stops, a booster that works correct works excellently, one that is weak - you can push through the boost til it gets hard again. A proper working booster causes the brake pedal to act a bit spongy.
Honda says the test is to press on the brake pedal and then start the car. If the pedal drops down a bit more then the booster is working.
> Lyle
> > We need:
> > *piston seal
> > *diaphram
> > Lyle
> > > From: honda600wiz
> > > > From: lyletrudell
> > > > To:
honda600wiz
Re: Cost of PBB rebuild
Post by honda600wiz »
Booster rebuild at Karps runs 300 to 450 dollars, depends on if you want to resleeve the booster which is a two step process and what other parts it might take to complete the rebuild, not cheap but if you are going to keep your car its a worthy investment.
Jerry
Re: booster on ebay
Post by Jerry »
Idle readings on most modern cars is 16-20 from what I've seen. The mini was only 850cc so it should be pretty close to our readings. Ill ask a few old british mechanics I know and see if they can get me an actual number.
Sent: Thursday, August 26, 2010 9:27 PM
> From: honda600wiz
, dean m wrote:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... item=33046
Amtech
Re: booster on ebay
Post by Amtech »
A "real" car? Thought that's what these were!! �;)
dean m
Post by dean m »
have a number or address to karps?? thank you
Fri, 8/27/10, honda600wiz
> From: honda600wiz
> Subject: [2cylinderhondas] Re: Cost of PBB rebuild
> Date: Friday, August 27, 2010, 3:49 AM
CHEYENNE FLETCHER
Re: booster on ebay
Post by CHEYENNE FLETCHER »
What do you mean "a real car" LOL
> feltonminicycle
> ebay
> Probably wont work because a Honda 600 draws such a low vacuum less than 10 > a real car pulls like 30 ?
> the british remote mount boosters? Looks like you would just need to change a > few fitting at the booster its self but they are available brand new and > readily available.
> honda600wiz
> > I
> send my brake boosters to Karps in California to be rebuilt, not cheap for a > rebuild however. Not sure if he could offer a kit as there are three different > styles of boosters for the N600 and one for the Z600. Intenal parts could be > interchangeable between the boosters also, Miles will know the answer to that > question.
> > > From: lyletrudell
> > [The
