NOS parts
richmccolman
Re: Coker Tires
Post by richmccolman »
I ended up buying the Falkens that Eric pointed out were listed on ebay - thanks again, Eric!
Another quick tire question: I see that the Yokohama A008 165 70r10 is still available (at $100+ each). Also, I see on the Yokohama site that the 165 70r10 is recommended for a 4.5 to 5.5 width rim. Does anyone have those mounted on a stock 600 rim? The stock rims appear to me to be only about 3.5 inches wide. My guess is that wider aftermarket rims are required for the Yokohamas. (Sorry if I'm asking an old question, guys.)
Just looking to the future when my new Falkens eventually wear out...
Thanks - Richard
, "richmccolman" wrote:
> Thanks, Eric!
> Richard
, Eric Geiger wrote:
> > go to ebay they still have falkens
http://www.ebay.com/sch/i.html?_nkw=fal ... &_osacat=0
> > Eric J. Geiger
> > PRG Nocturne
> > XXX-XXX-XXXX phone
> > XXX-XXX-XXXX fax
> > XXX-XXX-XXXX mobile
> > egeiger@
> > www.prgnocturne.com > On Aug 12, 2012, at 5:01 PM, richmccolman wrote:
> > Interesting - I just looked at the Coker Tires site and they appear to have no listing for this. Is the Vrebestein 145r10 too new to Coker to have made it onto their web site, I wonder?
> > It also appears that Falken's 145r10 is no longer available. Does someone know differently? (I should have bought a set of Falkens a few months ago when I had the chance.)
> > I have fabric showing on the inside of my tires (!), so I need to replace ASAP. (It appears that a previous owner must have had a fair amount of negative camber set in during a front-end alignment, resulting in excessive wear on the inside tire treads. I'll need to readjust the camber setting as well!)
> > I'd prefer not to spend gobs and gobs by buying the Dunlops, etc. Any suggestions?
> > Richard
, bottom cop wrote:
> > > Just talked with Coker tires. They have 145r10 radial tire that is manufactured by a Dutch company called Vrebestein. Tires are $87.00 each plus shipping. There is also a 145s10 radial Firestone Tire in the planning stages and it will be available the first part of next year for $79.00 plus shipping. Coker Tire can be reached at XXX-XXX-XXXX. They travel to several automotive events around the country and can deliver your purchases to that event site for less than the normal shipping cost. I was quoted $10.00 per tire to Springfield, Ohio on pre-paid orders. Maybe more, maybe les for other parts of the country.
Nobutoshi Hayashi
Re: Coker Tires
Post by Nobutoshi Hayashi »
You can see on pictures I listed in photo section. Black & Blue Z600. Yokohama on black z600 on stock rim. With Yokohama, it will not fit into spare tire compartment.
> Thanks - Richard
> > Thanks, Eric!
> > Richard
> > > Eric J. Geiger
> > > PRG Nocturne
> XXX-XXX-XXXX
> phone
> XXX-XXX-XXXX
> fax
> XXX-XXX-XXXX
> mobile
> > > egeiger@ egeiger@
> www.prgnocturne.com
> http://www.prgnocturne.com/
> > > Richard
> 2cylinderhondas%40yahoogroups.com
> >, bottom cop wrote:
> > > > Just talked with Coker tires. They have 145r10 radial tire that is manufactured by a Dutch company called Vrebestein. Tires are $87.00 each plus shipping. There is also a 145s10 radial Firestone Tire in the planning stages and it will be available the first part of next year for $79.00 plus shipping. Coker Tire can be reached at > XXX-XXX-XXXX > . They travel to several automotive events around the country and can deliver your purchases to that event site for less than the normal shipping cost. I was quoted $10.00 per tire to Springfield, Ohio on pre-paid orders. Maybe more, maybe les for other parts of the country.
Re: Coker Tires
Post by Eric Geiger »
i have a set of the Yokohamas and Kumhos, each set on factory wheels. i can take a picture tomorrow for the comparison .  i personally like the look of the narrower tires though as it keeps the look more original.
they are both great looking and it will come to personal preference, mine just happens to be the Kumhos.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX  phone
XXX-XXX-XXXX  fax
XXX-XXX-XXXX  mobile
egeiger@...
www.prgnocturne.com
> Another quick tire question: I see that the Yokohama A008 165 70r10 is still available (at $100+ each). Also, I see on the Yokohama site that the 165 70r10 is recommended for a 4.5 to 5.5 width rim. Does anyone have those mounted on a stock 600 rim? The stock > rims appear to me to be only about 3.5 inches wide. My guess is that wider aftermarket rims are required for the Yokohamas. (Sorry if I'm asking an old question, guys.)
> Thanks - Richard
> > Thanks, Eric!
> > Richard
> > > Eric J. Geiger
> > > PRG Nocturne
> > > XXX-XXX-XXXX phone
> > > XXX-XXX-XXXX fax
> > > XXX-XXX-XXXX mobile
> > > egeiger@
> www.prgnocturne.com
> > > Richard
> , bottom cop wrote:
> > > > Just talked with Coker tires. They have 145r10 radial tire that is manufactured by a Dutch company called Vrebestein. Tires are $87.00 each plus shipping. There is also a 145s10 radial Firestone Tire in the planning stages and it will be available the > first part of next year for $79.00 plus shipping. Coker Tire can be reached at XXX-XXX-XXXX. They travel to several automotive events around the country and can deliver your purchases to that event site for less than the normal shipping cost. I was quoted > $10.00 per tire to Springfield, Ohio on pre-paid orders. Maybe more, maybe les for other parts of the country.
David Baer
Re: Coker Tires
Post by David Baer »
see if www.minimania.com/ has any, I got 4 last month for all around, had a good one for spare.
On Sun, Aug 12, 2012 at 3:01 PM, richmccolman
> Richard
> , bottom cop wrote:
> > Just talked with Coker tires.� They have 145r10 radial tire that is manufactured by a Dutch company called Vrebestein.� Tires are $87.00 each plus shipping.� There is also a 145s10 radial Firestone Tire in the planning stages�and it�will be available the first part of next year for $79.00 plus shipping.� Coker Tire can be reached at > XXX-XXX-XXXX > .� They travel to several automotive events around the country and can deliver your purchases to that event site for less than the normal shipping cost.� I was quoted $10.00 per tire to Springfield, Ohio on pre-paid orders.� Maybe more, maybe les for other parts of the country.
David F. Baer
469 Ena Rd., Apt. #1311
Honolulu, HI 96815
Cell:� XXX-XXX-XXXX
richmccolman
Re: Coker Tires
Thanks to all of you who responded to my tire questions!
I've gotten the new Falkens on my z600 now. Now I just need to get the front-end alignment done so the front tires will wear evenly. (As best as I can tell, the front wheels appear to have a slight negative camber, whereas the coupe service manual indicates that a 1-degree positive camber is required.)
Richard
> good one for spare.
> > well!)
> > suggestions?
> > Richard
> David F. Baer
> Honolulu, HI 96815
> Cell: XXX-XXX-XXXX
honda600wiz
NOS parts
Post by honda600wiz »
I have a NOS crankshaft kit for sale, one of the few if not the last one around, also a rebuilt sedan engine, a nice sedan trunk latch and coupe hatch latch also. NOS Sedan trunk weather stripping and NOS side window weatherstripping for a Sedan. I made my sedan into a truck and I do not need the weatherstripping anymore.
all parts located in North Carolina, email tmoc1990@... or text XXX-XXX-XXXX
