Some advice would be great!
Re: Some advice would be great!
Julian;
   Looking for spark:
Need to know things about the Honda 600.
- Both plugs need to be attached to the coil and grounded if out of the engine to complete the circuit and give a spark.  If either is not connected then there is no spark.
- Because the wires are screwed into the plug connecting ends (caps), these need to be looked at to ensure they are touching wire and not just insulation.
- Also the caps are manufactured with a small wire inside to grab the threads at the end of the plug is this wire is missing (and some are) then it will have a poor or no connection to the plug.
- You can check to see if your coil is good by using an OHM meter to touching both leads to see if they are connected.  If you have a reading at around 32 it is a good sign.  Do the same with the black and blue wires, they should also have a reading.   If either of these checks come up with no reading then the coil may be the problem.  But, using a needle push it into the base of the wires to see if there is a reading there, as many times the wire is broken at its base causing a disconnect.  There is a fix for the coil on the
anzhonda600owners group site.  In the 40 some years I have been working on old cars wires seem to be most of the problems.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Julian > Sent:
> Wednesday, March 09, 2011 11:46
> [2cylinderhondas] Re: Some advice would be great!
> Thanks for the timing info Dale.
> After doing a bunch of stuff over the
> past few days to see if the old z would start yesterday I finally tried to > start her up.
> And....!!!! It didn't start, So after asking my 12 year
> old brother a to turn the key so I could test for spark I found that there was > none.
> The spark plug was wet though, so I am getting gas!!
> I'm
> really hopping that once the no spark issue is solved that it might fire > up!!
> And I will check the timing now that I have some info on how to.
> Also when I originally manually turned the engine, before hand i > lubricated the top end, I assumed little to no oil would probably make it up > there.
> goinhm@... wrote:
> > Here are some things to try for an engine
> which will not start;
> > 1) squirt some motor oil in
> each cylinder (1/2 tablespoon is plenty) and
> > perform a compression
> test. A great reading would be 160 psi on each
> > cylinder
> > 2) turn over the engine until you see the points are closed. Remove a
> > spark plug, connect the plug wire back onto a new spark plug and hold > the > > threaded portion of the plug against the metal engine block, turn > the > > ignition switch on and crank over the engine. You should see a > strong spark > > jumping across the plug gap. Do the same thing for the > other spark plug. You > > may need a helper to crank over the engine or > you can use a remote starter.
> > 3) with a spark plug removed,
> turn over the engine and verify the piston
> > is at top dead center when
> the mark on the crank pulley is opposite the
> > "T" on the crankcase.
> This will verify someone did not get the pulley out of
> > phase by 180
> degrees.
> > 4) with the mark on the pulley opposite the "T" on
> the crankcase, look
> > at the driver side on the camshaft. You want to
> see the notch on the cam
> > centered in the driver side cam housing. If
> it isn't, your cam timing is
> > off.
> > If you have good
> compression, spark on the plugs, proper cam timing,
> > you are very
> close to getting the engine to run. Carb problems, fuel supply
> problems, or air leaks can also prevent it from running. BTW, turning
> over the engine by hand or with the starter motor doesn't really lubricate
> > the critical parts of the engine. The roller bearing design of the > crank > > can handle oil starvation for short periods of time. The cam > housing and > > pistons need oil to work properly. Remove the cam cover > and spray some motor > > oil at each of the rocker arms (the housing > where they pivot and where they > > contact the valves), where the rocker > arms contact the cam, and the cam > > housing where the cam rests. A > little oil in each cylinder will also help > > .... just a > little.
> > good luck,
> > Dale
> > I have some
> new points and condenser, and I checked and added a bunch of > > oil > because it was low. And manually turned over the engine a bunch of times
> > to move the oil around and get it lubricated before I tried to start > it > > with the ignition.
> > It did have spark a year ago.
> I Need to check the timing, is there any
> > write ups on the proper
> steps and instructions to do this?
> > I live in the little town
> of Walla Walla Wa, I don't think there is anyone
> > locally that knows
> much about these cars. Or from what i have gathered.
> > Thanks
> for all the help this far guys!
amareto23
Post by amareto23 »
Hello folks. it's been awhile since i've been here. The real cure for the
no and weak spark is to throw the points away. I've been able to put an
Crane xr700 electronic ford conversion kit on mine and i haven't been
under the hood in a very long time. You throw the points away. epoxy all
the rotor slots but 2 opposite each other and epoxy the rotor to the
point cam. It's at the right height and the pick up unit bolts to the
point plate and you only have to drill and tap one mount hole. And i used
the original coil with no problems. The only headache is that you have to
modify the points cover plate. Hope this is a help. ,Kingtrans in N.C.
Get Free Email with Video Mail & Video Chat!
http://www.juno.com/freeemail?refcd=JUTAGOUT1FREM0210
STEVEN
Post by STEVEN »
Here in Costa Rica it is sometimes (rarely) possible to adapt motorcycle parts available at the Honda bike dealership.
Recently we were able to successfully replace a faulty coil on a LN360 with a new coil from a modern Honda 400 motorcycle.
