More Parts Added
Re: More Parts Added
Miles;
Couldn't remember who it was, just that it was a error in the product.  Did you ever find a clear tube that will perform as required?
> Monday, October 17, 2011 9:10
> [2cylinderhondas] Re: More Parts Added
> As I recall I was Giving It Away with a rebuilt master cylinder. I got it > from an industrial supply hose retailer who told me it would work for brake > fluid. It was years later I noticed fluid *sweating* through my hose and > warned customers it was not a good match.
> > Bob;
> > That may be
> true, and it is not just this site I am speaking of. There were > > people > selling vinyl tubing to be used with brake fluid that was made for
> water. The seals pictured are not directional and there is no mention > of > > the material they are made of. If it were a substantiated company > such as > > Beck Arnley or WIX there would be no hesitation and I would > agree. But who > > knows? Oh they may run for a while but why would Honda > make them directional > > if it didn't have to? And, if the O rings are > made of Natural Rubber they > > will swell when used with oil and there > will be leaks. Anyone can take an > > old O ring and the application into > a manufacturer and get qualified and > > professional assistance as to the > product they need, and although they may > > not be able to sell you the > part. Normally they will tell you who in your > > area has them or can > order them.
> ]On
> Behalf Of robertjritter
> > Sent: Sunday, October 16, 2011 4:49 PM
> Subject: [2cylinderhondas] Re: More Parts Added
> > I have bought many parts from this site and have been very happy with > all > > the parts I have received and the custom service.
> > > I wouldn't go so far as to
> qualify these as good parts. Something off
> > the
> > > shelf for
> a different application may not work and cause more problems
> than
> > > you had to begin with. Natural Rubber works well with water > but not with > > > oil, there are a bunch of O rings out there made for > a different > > purpose.
> > > Many of the shaft seals sold by
> Honda are directional. None of the seals
> > > listed have that
> capacity. Often a seal is not all that is needed to
> > > correct the
> problem, the sealing surface may also need repair. It may > > fit
> > the housing but will it seal against the rotating shaft? You may > have > > > noticed the Fan Mount cushions on your engine swelling > because of oil > > > leaking onto them. If you replaced them with > Neoprene rubber they will > > > resist swelling and last much longer.
> The question - have they been
> > tested
> > > on a Honda 600
> engine? for how long and with what result? In a vehicle
> > or
> > just on a test stand?
> > > Bill
> > [mailto:
> ]On
> Behalf Of Mark P Hatten
> > > Sent: Saturday, October 15, 2011 5:27
> > Subject: RE: [2cylinderhondas] More Parts Added
> > > Awesome ! you've got some very
> much needed parts for great prices
> http://www.mphspecialties.com/
> > From: theenginebuilder@
> > > Date: Sat, 15 Oct 2011 22:18:32
> +0000
> > > Subject: [2cylinderhondas] More Parts Added
> > > More new parts added.
> http://www.honda600carparts.com
Post by feltonminicycle »
No, I just quit rebuilding master cylinders. That solved all my problems.
, wrote:
> Miles;
]On Behalf Of feltonminicycle
> Sent: Monday, October 17, 2011 9:10 PM
, wrote:
> > Bob;
> > That may be true, and it is not just this site I am speaking of. There
> were
> > people selling vinyl tubing to be used with brake fluid that was made
> for
> > water. The seals pictured are not directional and there is no mention of
> > the material they are made of. If it were a substantiated company such
> as
> > Beck Arnley or WIX there would be no hesitation and I would agree. But
> who
> > knows? Oh they may run for a while but why would Honda make them
> directional
> > if it didn't have to? And, if the O rings are made of Natural Rubber
> they
> > will swell when used with oil and there will be leaks. Anyone can take
> an
> > old O ring and the application into a manufacturer and get qualified and
> > professional assistance as to the product they need, and although they
> may
> > not be able to sell you the part. Normally they will tell you who in
> your
> > area has them or can order them.
> > [mailto:
]On Behalf Of robertjritter
> all
, wrote:
> > > I wouldn't go so far as to qualify these as good parts. Something off
> > the
> > > shelf for a different application may not work and cause more problems
> > than
> > > you had to begin with. Natural Rubber works well with water but not
> with
> > > oil, there are a bunch of O rings out there made for a different
> > purpose.
> > > Many of the shaft seals sold by Honda are directional. None of the
> seals
> > > listed have that capacity. Often a seal is not all that is needed to
> > > correct the problem, the sealing surface may also need repair. It may
> > fit
> > > the housing but will it seal against the rotating shaft? You may have
> > > noticed the Fan Mount cushions on your engine swelling because of oil
> > > leaking onto them. If you replaced them with Neoprene rubber they will
> > > resist swelling and last much longer. The question - have they been
> > tested
> > > on a Honda 600 engine? for how long and with what result? In a vehicle
> > or
> > > Bill
> > > [mailto:
]On Behalf Of Mark P Hatten
> > > Sent: Saturday, October 15, 2011 5:27 PM
> > > Awesome ! you've got some very much needed parts for great prices
> > > Date: Sat, 15 Oct 2011 22:18:32 +0000
Miles;
For what it’s worth, I thought you had a great product.  You did the home work found the correct replacement parts from existing supplies for that purpose.  There needs to be a watchdog on the parts coming to this group.  Professional manufacturers in the industry have responsibility for the parts they manufacture.   I am tired of having engines show up at my door with the wrong rubber seals in them because they (the owner) said some one told them it was ok at Home Depot.  Really.
For those who don't know I did some repro items that were very slow movers. Oil pump rods made of steel, later oil pump rods made of aluminum and sleeved in steel along with new pistons and press fit pins. A complete primary drive kit with driven hub that was turned down to accept a new specially fit oil pump rod/piston set but at $300.oo were not a fast mover.
I made and tested guide roller made of acetal plastic (Delrin) only to find it would not take the heat, photo available upon request, though it may be in the photos section.
I had a local machine shop make 100 flywheel tools which I sold for $15.00 with free postage. Made from 1" hex bar tool steel stock. The machinist got mad as he burned upi 10 carbide bits making them and said never again.
I wrote a newsletter for 4 years and had 80 subscribers USA & Canada 1993-1996. I had some interesting stories written by Mike OConnor and Bill Colford, Norm Hart, Chip Lord and others. Ads for cars/parts for sale, interchange parts, guess the part, etc. We communicated by telephone & fax, no emails or texts ! It was one on one with 2 parties involved. I ordered parts from Honda and would go pick them up myself. A new crankshaft assy was only $220.oo and we thought that was expensive !
, "William Colford" wrote:
> Miles;
> For what it's worth, I thought you had a great product. You did the home
> _____
] On Behalf Of feltonminicycle
> Sent: Tuesday, October 18, 2011 2:12 AM
> , wrote:
> > Miles;
> > [mailto:
> brake
> > Miles
> , wrote:
> > > Bob;
> > were
> > for
> > as
> > who
> > directional
> > they
> > an
> > may
> > your
> > > Bill
> > > [mailto:
> > all
> > > the
> > > than
> > with
> > > purpose.
> > seals
> > > fit
> > > tested
> > > or
> > > > Bill
> > > > From:
> > > > [mailto:
> > > > To:
> > > > To:
John Nadam
Post by John Nadam »
Miles.
  if I am not mistaken, you are based in Portland, OR ?
I ask because I did find such newsletters online, and found them quite interesting and useful.
Do you still work on 600s ?  I am about to start a restoration of a 72 Coupe, weather permitting.
I am curious if you (still) overhaul engines;  if so, you could email me with prices and such.
Thanks,   John   Bellevue, WA PS: I have also owner many 600s since early 70s.
       I have only 1 now, and parts in the basement, including 3 complete engines and enough parts to build at least 1 more.
       Many people have old parts - it is the new and rebuilt parts that we all need.
feltonminicycle To:
Wednesday, October 19, 2011 2:39 AM Subject:
TOM THIES
Post by TOM THIES »
John
Miles is not based in Portland Or.  Which I am sure he will tell you soon but Brian and Blaine Higginson are close.  B and B auto in Washougal Washington 1-XXX-XXX-XXXX.  Washougal is close to Portland and they rebuilt my motor 3 years ago.  Though I would have no problem sending it out to Miles for repair.  They were just closer.  If you ever come down to the north oregon coast let me know, we can talk cars.
Tom
> John Nadam
> Wednesday, October 19, 2011 9:40
> Re: [2cylinderhondas] Re: More
> Parts Added
> Miles.
> I ask because I did find such newsletters online, and found them > quite interesting and useful.
> Do you still work on 600s ?  I am about to start a restoration > of a 72 Coupe, weather permitting.
>   John
>   Bellevue, WA
> basement, including 3 complete engines and enough parts to build at least 1 > more.
> feltonminicycle
> [2cylinderhondas]
> For those who don't know I did some repro items that were very slow > movers. Oil pump rods made of steel, later oil pump rods made of aluminum and > sleeved in steel along with new pistons and press fit pins. A complete primary > drive kit with driven hub that was turned down to accept a new specially fit > oil pump rod/piston set but at $300.oo were not a fast mover.
> I made
> and tested guide roller made of acetal plastic (Delrin) only to find it would > not take the heat, photo available upon request, though it may be in the > photos section.
> which I sold for $15.00 with free postage. Made from 1" hex bar tool steel > stock. The machinist got mad as he burned upi 10 carbide bits making them and > said never again.
> subscribers USA & Canada 1993-1996. I had some interesting stories written > by Mike OConnor and Bill Colford, Norm Hart, Chip Lord and others. Ads for > cars/parts for sale, interchange parts, guess the part, etc. We communicated > by telephone & fax, no emails or texts ! It was one on one with 2 parties > involved. I ordered parts from Honda and would go pick them up myself. A new > crankshaft assy was only $220.oo and we thought that was expensive !
