Voltage Regulator
Robert James
Re: Voltage Regulator
Post by Robert James »
Thanks Miles. �You are correct. �I miswrote! �
On Sat, Nov 9, 2013 at 12:39 AM, Miles
> I think the wire to brushes is white with red
> stripe. White with black stripe goes to stator. Make sure you test your > rectifier, stator and rotor before you rewire the whole thing.
Dr. Whiting
Post by Dr. Whiting »
Voltage regulator repair wiring harness available here:
honda600carparts.com/new-products
also new Sedan taillight lenses.
bobs600honda
Post by bobs600honda »
Has anyone had any luck with the voltage regulator from RockAuto?
I notice the pin out has only 5 wires (missing the wht/grn) instead of 6 on the connector.
Can this missing wire be wired separately?
thanks for any info...
http://www.rockauto.com/catalog/x,carco ... S%2B1V1138
Here is the low down
All Vehicles
HONDA
1972
600
598cc L2
Electrical  > Voltage Regulator 1972 HONDA 600 598cc L2 : Electrical : Voltage Regulator Price Add to Cart AIRTEX / WELLS Part # 1V1138
That is to the Voltage Warning light in the instrument cluster.  It can be replaced with a voltage gauge.
