stuck rear brake, part 3
Chas
Re: stuck rear brake, part 3
Post by Chas »
I also had that same issue with mine. I put the fasteners back on loose to keep tge drum from falling off. The, i drove the car slowly up and down the driveway, whick alllowed the weight of the car to break tge drum loose.
Chas
, "bobs600honda" wrote:
> Okay, got the tires off and left rear hub will not move.
> Any way to get the hub off without a hub puller?
> Thanks for any info.
> Bob
> > Think I may have a similar issue. As I was pulling in the driveway, the coupe suddenly acted as if the brake was full on! I mean, lots of resistance to moving forward, a lot! Its too late to start digging into wheels, etc., so it will have to wait until tomorrow afternoon.
> > I plan to put the car up on jacks and see how freely each wheel will move and go from there.
, "william colford" wrote:
> > > Hi Steven;
> > > It sounds like you have found the problem, Miles has the repair, and your idea of using any type of grease around a brake system is wrong. Clean everything with lacquer thinner, it leaves no residue. Flush your system with new brake fluid. If your going to resleeve your cylinders do them in Brass, stainless is to hard for the aluminum cylinders on your coupe and will crack them. You can also go another route. If you go to a brake repair shop not Midas you can use regular cups to replace the seals on your pistons. Then place a spring between the cups to hold them against the pistons that you modified. The way to modify your existing pistons is to just cut them flat. File them smooth and put them back into your resleeved (Brass) cylinders. One problem with the seal type brake cylinder piston seal use on the Honda 600 is that not only does the cylinder corrode but the sealing surface on the piston also corrodes. This is why some Honda 600 owners still have problems even after they have spent the time to resleeve their wheel cylinders only to find them still leaking.
> > > Bill
> > > From: Steven Michelsen
> > > Sent: Monday, April 21, 2003 4:25 PM
> > > Subject: [anzhonda600owners] stuck rear brake, part 3
> > > Sorry to bring this to you in installments. This should be it for tonight...
> > > I got the drum off, after much tapping with the mallet. I discovered that the right-hand boot on the cylinder was entirely shredded. The left hand side was intact. Stepping on the brake caused the piston to pop out through the shredded boot, and stay out. Working the handbrake cable behind the wheel eased the piston back in place. A half a can of brake cleaner later, the built up goo was removed from the pads, drum and everywhere else.
> > > So where do I stand? Certainly I can't leave it with a shredded boot (of course it may have been that way for a long time already). If I reassemble now will I continue to have the sticking problem? Other than cleaning up I didn't actually fix anything. I could attempt to create a boot by wrapping a sheet of rubber and wire-tieing the ends in the proper spots - temporary at best. If I do that should I add a bit of oil or grease inside the "boot" first?
> > > Steve
> > > Yahoo! Groups Sponsor
> > > To unsubscribe from this group, send an email to:
