> ONCE AGAIN you have written a very good article on the
> cooler.... i don't know why everyone doesn't have
> one!!!
> merry christmas
> harry
> --- Bill Colford wrote:
> > Hi Vaughn;
> > You can do this yourself, I have several filter
> > caps and
> center
> > bolts already modified I can provide along with
> > detailed instructions to
> > find the items you need and make it your self. The
> > kit I have was put
> > together by me, they are made up from a some what
> > long list of
> > manufacturers. The important thing is to keep the
> > street "L" brass
> > fittings, hoses and clamps as close to the engine as
> > possible. Harry
> > Lineback even added metal bands to protect the hoses
> > from being hit. I
> > drove my car without any protection for 8 years and
> > never had a problem.
> > Then there have been other owners that were not as
> > mindful and hit curbs and
> > parking lot stall stops causing the hose to be
> > pulled off. As the attached
> > picture shows they are really close to the engine
> > and literally up away from
> > everything.
> If your interested in more pictures and prices
> > please e-mail me at
> > billmyong@.... But don't get me wrong,
> > this is not a cheap
> > transition. The oil thermostat made by EMPI runs at
> > just over $80.00 alone.
> > The cooler with the VW remote filter and coils (when
> > listed) runs in the
> > $85.00 to $120.00 range. It would take a whole
> > bunch of Honda filters to
> > brake even if that is your only reason for
> > installing a oil cooler. The
> > real reason is that in the tests I have run (placing
> > a modified oil drain
> > plug on a Honda 600 and installing a temperature
> > gauge) I monitored engine
> > temperatures during many different driving
> > conditions. This was on a motor
> > that had over 50 K on the speedometer. normally
> > doing 65 on the freeways,
> > kept the Honda 600 running at about
> 165 degrees
> > (where it should be), but
> > once off the freeway and stopping at the first light
> > (a few hundred feet
> > from the off ramp) and temperatures would rise to
> > 230 and above. And, then
> > because traffic normally slowed to 25 or less the
> > engine kept that 230 and
> > in some instances went considerably higher. This
> > was not just a quick few
> > times down the freeway and into traffic, I used the
> > car as a daily driver
> > for almost a year, monitoring how it ran and if it
> > got higher in the summer
> > or if I started driving on ground streets and over
> > the same distance did the
> > temperature hit 230 or above in stop and go traffic
> > as it did coming off the
> > freeway. And it always did, although taking longer
> > the air traveling across
> > the engine and movement by the fan did not keep the
> > oil at the 165 degree
> > range.
> > I then added the oil cooler and measured everything > > before starting > > the test again. I drove it giving it full throttle > > from many a corner, and > > then I pulled the engine every 10K miles and > > measured for wear. I won't say > > there were not some things that had to be replaced.
> > After 45K miles into
> > the test the cam chain had to be replaced as it had
> > stretched almost 3/4in
> > from new. I also had re-used old transmission and
> > all it's bearings when
> > first putting the engine together and I had a
> > primary shaft bearing showing
> > some wear (they will start a side movement) which
> > was replaced as well as
> > the transmission bearing keepers. But the most
> > significant change in the
> > engine was that there was no tar (blackening from
> > over heated oil) inside
> > the engine. I opened
> the oil filters after each oil
> > change to see if there
> > were any metal chips or other foreign particles. I
> > didn't find anything,
> > and I was using a 20W50 oil manufactured for motor
> > cycles using the same oil
> > for both engine and transmission as the Honda 600
> > does. In fact, several
> > times I changed the filter every 3K miles and the
> > oil at 6 to 7 months.
> > The test ran for almost 50K miles and 4 engine pulls
> > and measuring key
> > points,
> > 1 - piston wear causing piston slap
> > 2 - piston ring wear
> > 3 - piston cylinder wear
> > 4 - oil pump wear
> > 5 - transmission lash and bearings
> > 6 - crank shaft end bearings and bearing
> cages
> > 7 - cam end cap housings and cam.
> > 8 - it the torque was maintained on the head studs > > and bolts > > 9 - rocker arms and shafts > > just to name a few.
> > The test stopped when I sold the car in 1997. Will
> > it add additional miles
> > to your Honda 600, I think so, and when I put a oil
> > cooler on the engine I
> > first only had the oil temp gauge on, it ran much
> > better. And, many of the
> > cars using an oil cooler are still on the road.
> > But if the metal is not there to begin with,
> > nothing will keep it
> > wearing more and eventually break. Too much Heat
> > causes wear, more oil and
> > keeping it at its optimal running temp along with
> > better filters can only
> > help. Did
> Honda have a poor design with the filter
> > they used, I don't think
> > so. However they didn't think people would still be
> > driving them 30 years
> > later either.
> > [mailto:
anzhonda600owners@yahoogroups.com]On Behalf
> > Of
> > howardsugarman@...
> > Sent: Saturday, December 24, 2005 8:17 AM
> > Subject: RE: [anzhonda600owners] New 600 owner
> > Hi Bill, So... how much will this oil cooler
> > retrofit
> > cost? it definite sound good. I am interested in
> > getting one, so... I don't have to pay for these
> > expensive NOS filter when went ever i want to change
> > the oil, i
> can walk into Autozone and pickup the
> > filter and oil and im done under 10 bucks. :) I just
> > recently got the car and havent even took the oil
> > filter out as of yet. From looking at the manual, it
> > looks like just a paper filter from like an ATV or
> > something like that. I am definitely interested in
> > the
> > COOLER AND OIL Retrofit kit.
> > Thanks
> > Vaughn
> > > Shoki;
> > > Being around aircraft like you are you know the
> > > value of a cool clean
> > > running engine. I have a oil cooler that moves
> > your
> > > oil filter to a remote
> > > filter next to the battery tray and with a PH8A
> > > filter adds a bit more than
> > > a quart of oil to your system. It also includes a
> > > oil thermostat to allow
> > > quick warm
> up's and then continued temperature
> > > monitoring. Also you can add
> > > an oil pressure and temp gauges giving you
> > > additional information. Send
> > > your e-mail address and I will send you pictures
> > of
> > > a recent installation in
> > > a sedan that also put in Mike O'Connor's 40 over
> > > pistons.
> > > Bill
> > > [mailto:
> > Behalf
> === message truncated ===
> Harry Lineback
> XXX-XXX-XXXX
Yahoo! DSL
Something to write home about. Just $16.99/mo. or less
