Crankshaft repair
Re: Crankshaft repair
Post by lyletrudell »
Marshall, sorry I was wrong about the En31, it should be a good choice. I have never used it, so don't know much about the heat treating, or if a thin wall sleeve is prone to cracking when pressed on. Another good choice is E52100. Whatever is available in your area.
I have used A-2 and D-2 for sleeves because I use it for all kinds of tooling and I know alot about the materials.
But, it might not be the best, always willing to try something else.
When heat treating to the max hardness, cracking is a concern.
I have had A-2 sleeves crack when I pressed them on. Now I bring the Rc down to the 58-60 range.
Not sure what wall thickness you are trying to work with.
I like your idea of grinding an existing suitably sized bearing housing. I really know nothing about the Honda 600 crank bearing setup, but from what others say nothing else fits it.
You sound like your experienced in machining.
Will help if I can.
Good luck and keep us posted.
, "Marshall" wrote:
> Lyle, En31 is classed as a high carbon steel I thought. I will look into A-2 Many thanks for the added info relating to sleeving. I have access to all equipment required to machine & grind. I gave some thought to grinding an existing suitably sized bearing housing. Would you think that is worth consideration ? Nothing to lose really , exept the time involved ! Marshall.
, "lyletrudell" wrote:
> > Bill, I didn't get that far yet.
> > So the bearings are not available either? This is one tough car to rebuild!
> > The rollers should not be a problem.
> > But the cage will! I would hate to have to make them.
> > I am sure you guys have searched for other caged bearings.
> > Bill can you give me some info:
> > *Main crank Diameter
> > *ID of the outer sleeve
> > *roller dia, length & number of pins
> > *Cage length
> > I can check some of my sources.
> > Lyle
, wrote:
> > > Lyle;
> > > The lower end of the rod has many rollers (needle bearings) in an
> > > aluminum cage. What are you using to replace the bearing cage?
> > > Bill
> > > -----Original Message-----
> > > [mailto:
]On Behalf Of lyletrudell
> > > Sent: Saturday, May 08, 2010 10:30 PM
> > > Subject: [anzhonda600owners] Re: Crankshaft repair
> > > Hi Marshall, bearing steel is nothing more than a medium carbon steel. The
> > > sleeve can be made from any high carbom steel.
> > > A-2 is a good choice because it is an air hardening steel and can be
> > > machined easily. Heat treat and temper to 55-60Rc. Then maybe allow a .0015"
> > > press, and grind OD. Not sure what you have for equipment.
> > > Lyle
, "Marshall" wrote:
> > > > Blake, You are certainly correct about about the rod pins being part of
> > > the forging. Pins are not a problem...... obtainable loose from many
> > > suppliers. It's going to have to be a sleeving job. I am going to have a
> > > bash at machining my own sleeve to size from EN31 bearing steel & hope I get
> > > the heat treatment correct.
> > > > --- In
, blake neilson
> > > wrote:
> > > > > Those sound like good ideas, but in the case of the 600 finding repair
> > > parts (rollers in particular) would be the challenge.� As far as I know,
> > > Honda never sold any repair parts for the cranks.
> > > > > Also, you don't have separate rod pins.� The 600 crank looks a lot
> > > like a set of 4 flywheels/counterweights with each rod flanked by two of
> > > them.� The rod pins are a part of the forging of the inner two flywheels
> > > and so cannot be pressed out and separated as a single part.
> > > > > About 30 or so years ago I salvaged the best of two cranks. each
> > > having one bad rod.� A lot of work and time involved.� I might be a little
> > > hazy on some of the details such as which one of the flywheels included the
> > > rod pin but I'm quite sure of the fact that the pin cannot be completely
> > > separated.
> > > > > GNB
> > > > > --- On Fri, 5/7/10, lyletrudell wrote:
> > > > > From: lyletrudell
> > > > > Subject: [anzhonda600owners] Crankshaft repair
> > > > > To:
> > > > > Date: Friday, May 7, 2010, 7:59 AM
> > > > > I was reading from past posts that the crank is one of the weakest
> > > parts of the engine. Probable lack of oil or over heating.
> > > > > I have rebuilt many cranks, but not Honda 600's.
> > > > > A few ways to rebuild:
> > > > > *Polish and new rollers.
> > > > > *Grinding and sleeving.
> > > > > *Spray welding and regrinding.
> > > > > *Grind undersize & use oversize rollers.
> > > > > *Make new rod pins and press in.....
> > > > > I don't want to pull my engine apart, it's running fine, for now:)
> > > > > Does anybody have a complete "bad" crank assembly they can send me?
> > > > > I want to see if this is something that I could do.
> > > > > It sounds like we have a good supply of re-buildable cores out there.
> > > > > Then sort them into groups of problem areas and rebuild as required.
> > > > > Cheaper way to save our motors.
> > > > > Lyle
Check out the SKF needle bearing site.
http://www.skf.com/portal/skf/home/prod ... ink=1_5_56
> Will help if I can.
> Lyle
> > > *Cage length
> > > Lyle
, wrote:
> > > > Lyle;
> > > > Bill
> > > > From:
> > > > [mailto:
> > > > To:
> > > > Lyle
> > > > --- In
> > > > > --- In
, blake neilson
> > > > separated.
> > > > > > GNB
> > > > > > From: lyletrudell
> > > > > > To:
> > > > > > Lyle
