I replaced the bushing in my shift linkage with a piece of urethane spring material I had laying around. I think it was purchased from MSC. It comes in different diameters, lengths and hardnesses. The material I have is red in color which I think dictates the hardness, it's 1 1/4" diameter and I beleive came in a 12" stick. I cut it to the desired width with a hack saw, shaped it with a die grinder and drilled a hole thru it. It seems to work fine and certanly got rid of most of the play in the shifter.
Paul
--- On Fri, 5/28/10, John Brown wrote:
> From: John Brown Subject: Re: [anzhonda600owners] Re: Transmission mount or rear mount
> Date: Friday, May 28, 2010, 7:13 PM
> Hi,
> I ordered it on-line, I believe it was about $40. DEVCON
> makes two
> different versions. _*FLEXANE 80:* _ Shore A, 87 durometer
> and _*FLEXANE
> 94:*_ Shore A, 97 durometer.
> I did a quick search on the web and came up with this
> source, but I am
> sure I've seen it in hardware stores.
> Here's a link for this product (the first one I found)
http://www.markingpendepot.com/browsepr ... iquid.html
> Hope this helps,
> John
> lyletrudell wrote:
> > Hi John, that is a clever way to fix it.
> > Where do you get the Devcon?
> > 80 is probably the durometer of the hardened
> material.
> > Maybe they make a different hardness?
> > I was also thinking that it might work on my gear
> shift linkage in the
> > car. The rubber bushing is hard and cracked.
> > Lyle
> "John"
> > > Hi Paul,
> > > I modified a rear mount using a fast drying,
> urethane casting
> > product called DEVCON FLEXANE 80, it's available in 1
> lb portions in
> > both liquid and putty versions.
> > > I removed the all the loose rubber, cleaned all
> the metal parts,
> > wrapped some plastic sheeting around the mount then
> poured in the
> > liquid while propping the bracket with four holes in a
> centered,
> > vertical position. It is much stiffer than the
> original mount, but
> > still maintains some flexibility.
> > > It works well for me.
> paul tate wrote:
> > > > Given that most of the rear mounts are close
> to 40 years old and
> > the rubber is probably separated or broken like mine.
> Has anyone had
> > any success repairing or modifying? A friend suggested
> modifying to
> > use donut style mounts similar to the sub frame
> mounts. Any thoughts?
