Oil filter bypass check valve!
misterpoopoohead
Re: Oil filter bypass check valve!
Post by misterpoopoohead »
Yep! It also sprays a lot with just the filler cap off! I unfortunately know from experience!
Kev Sent from my Verizon Wireless BlackBerry
goinhm@...
Sender:
Date:
Fri, 23 Jul 2010 19:08:25 EDT
ReplyTo:
Re: [anzhonda600owners] Re: Oil filter bypass check valve!
Hi Kev,
    Yes,  it shows how important it is to keep the oil level up on these cars.  And the 3.3 qts/min is at 2800 rpm ..... higher rpms mean higher flow rates.   When you add oil to your car,  it doesn't take more than a second it for it to get to the bottom. If you have ever left the valve cover off and started the engine,  you see a huge spray of oil which covers the underside of the hood even if it is propped up.
3.3 quarts per minute would mean the entire reservoir of oil is pumped through the engine once >every minute!
>Kev
Post by lyletrudell »
From the stories, it sounds like the pump is putting out some good pressure, 25-35 is plenty.
I just pulled the oil filter assembly apart.
The center tube has 6 flow holes to the center bore.
The top 4 are open all the time to let oil flow thru the filter into the main line.
The bottom 2 are blocked by a ball and spring check valve and are below the filter area.
When the oil filter gets plugged, the ball will un-seat and allow dirty oil to flow into the main line.
The one on my car pops at about 20-22psi.
Seems low, maybe the spring is worn or heat damaged and lost it's tension.
I would think 30-35psi would be right, before we start pumping dirty oil.
Anyone know the factory pop pressure?
Thanks
> Kev
> From: goinhm@...
> Sender:
> Date: Fri, 23 Jul 2010 19:08:25
> To: Reply-To:
> Subject: Re: [anzhonda600owners] Re: Oil filter bypass check valve!
> Hi Kev,
> >Kev
