Carb
r savard
Re: Carb
Post by r savard »
Thank you much!
> "jbmkwaj@..."
> Thursday, March 8, 2012 9:58 PM
> Re: [anzhonda600owners] Re: Carb
> CV is constant velocity, same as your Honda stock carb. The Harley ( built by Keihen - just like the stock Honda carb ) carb looks more like the older style with the flat cover, but looks nice since they are painted black. These carbs are plentyful and all parts are still available, no I dont have any installed photos but I still have the set-up. No change to the throttle cable, but I did have to grind down the knob a bit on the choke cable to make it fit. This is a very easy retro fit and looks like a factory install when done.,  You can buy these for about $50.00
> From: r savard
> To: anzhonda600owners
> Sent: Thu, Mar 8, 2012 5:36 pm
> Subject: Re: [anzhonda600owners] Re: Carb
> CV harley carb? What is "CV"?
> > jbmkwaj@...
> > " > jbmkwaj@...
> > Thursday, March 8, 2012 1:46 PM
> > I have used a CV harley carb,( late 80's) they adapt very easy, even still used the original filter box.
> > It looks right at home, just had to make a change to the cable bracket and made an adapter out of exhaust pipe to mount. I am now back to the original carb,,,,but just for originality ...the HD carb works better.
> > From: pommecoing > pomier.cohen@...
> > To: anzhonda600owners > anzhonda600owners@yahoogroups.com
> > Sent: Thu, Mar 8, 2012 10:24 am
> > Subject: [anzhonda600owners] Re: Carb
> > Although you are right about the original carb, several persons actually did use other carbs on 600 sedans.
> > Have a look to this video : http://www.youtube.com/watch?v=gdT4wU1wdaE
> > , Fred Schieszer wrote:
> > > don't give up on the original carb, it's not that hard to clean up and tune. Make a new accel pump diaphragm from nitrile (cloth backed prevents extrusion) and clean and check needle valves. I always use an ultrasonic tank to get the gum and junk out!
> > > fjs
> > > Sent from my iPad
Re: Carb
What is the URL for the e-bay item?
Matthew Brecount
Re: Carb
Post by Matthew Brecount »
Just one question, I don't see any vacuum hose to the vacuum advance.  How does the timing advance?
Matt
To: anzhonda600owners@yahoogroups.com From: jbmkwaj@...
Date: Thu, 8 Mar 2012 23:24:14 -0500 Subject: Re: [anzhonda600owners] Re: Carb
Bill, check out e-bay, there are used for about 50 bucks and New for $129 or $150 I used the stock Honda cable bracket, but modified a bit, bolts right on and used about a two inch long ( if I remember right ) extention on the engine side. I considered making a kit and offering it for sale to 600 owners but just don't have to time right now.
John Mills
Re: Carb
Post by John Mills »
Yes, the is a vacuum port on the carb. On the HD it was used for th VOES switch.
Mike
Carb
Post by Mike »
I've also had carb issues. I'd like to have my Honda Z600 carb rebuilt. I've taken apart carbs before, and I've never put them back together successfully.
If I take my carb to a typical Honda Motocycle place, will they probably be able to rebuild the carb with the parts they have, or should I send it to a more specialized carb place?
thanks,
Mike.
John Mills
Re: Carb
It all depends on the mechanic. A typical Honda  (or any dealer mechanic) tech usually is trained to replace parts not repair them, you are better off sending to someone used to doing these or goldwing carbs.
ronny lucassen
Re: Carb
Post by ronny lucassen »
It is to far away for you but here in europe there are a few guys repairing these carbs very well. Motorcycles dealers to my opinion are also not capable of doing this, there are some screws that needs to be on the place they are!
Please can you send me a picture of your carbs: honda-ronny@...
> From: Mike
> To: anzhonda600owners Sent: Sun, Mar 11, 2012 1:26 pm
> Subject: [anzhonda600owners] Carb
> thanks,
> Mike.
Re: Carb
Hi Mike;
There are several people on the group that will rebuild your carb for you.  I have rebuilt carbs for people that had them rebuilt by so called rebuilders and they were little more than half a can of carb cleaner sprayed all over the outside.   I would send it to Tim Mings you can contact him at mercilessmings@...
, and he will do two things most won't, 1 complete the rebuild and turn it around in a few days , 2 he will test it on a Honda 600 to make sure it works.
    Two things I have found happening to a number of these carbs is the throttle shaft seals drying out and leaking, accelerator pumps being replaced with Honda carb air way diaphragms, that are not made for direct contact with fuel.  I tried them before just making my own and they held for a while but were leaking after a week or so.  Some used a diaphragm that didn't have a long enough shaft at it's center.  They didn't work because there was nothing to push up on by the accelerator linkage.  Others still had crud in the small fuel bowl inlet so they didn't leak, but there was no fuel getting to the accelerator pump.  And the needle wasn't adjusted properly or the screen on the end of the needle seat was full of crud.  All of which just didn't allow fuel to pass.  The object is to pull everything out and clean it all.  I have found dentists root canal drills to be the best when clearing crud form fuel passageways on the carb.
If you have trouble getting things back together, look at the parts manuals.
> Mike
> Sunday, March 11, 2012 12:26 PM
> [anzhonda600owners]
> Carb
> I've taken apart carbs before, and I've never put them back together > successfully.
> will they probably be able to rebuild the carb with the parts they have, or > should I send it to a more specialized carb > place?
> thanks,
> Mike.
Mike
Re: Carb
Post by Mike »
Thanks Bill. I agree that most mechanics are really just part replacers, not part rebuilders. Tim is a bit of a Honda 600 legend from what I've heard.
What's the rest of his email? Is it yahoo.com? or yahoogroups.com?
, wrote:
> Hi Mike;
> mercilessmings@..., and he will do two things most won't, 1 complete
> manuals.
]On Behalf Of Mike
> Sent: Sunday, March 11, 2012 12:26 PM
> successfully.
> thanks,
> Mike.
