leaking master cylinder
Re: leaking master cylinder
Post by Eric Geiger »
ya ill get a dial caliper tomorrow and measure the inside bore.  as for any hoses leaking i highly doubt it i made sure it was pretty bone dry and didn't see any fluid anywhere else but inside the car.  i don't have any carpet in my car currently so its easy to see the fluid lek onto the bare metal on the floor boards.
Ya something is defi
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX  phone
XXX-XXX-XXXX  fax
XXX-XXX-XXXX  mobile
egeiger@...
www.prgnocturne.com
On Jul 2, 2012, at 10:27 PM, John Mills wrote:
> measure inside diameter of the thing, also take some brake clean and paper towels and clean and dry everything, Are you sure your lines and hoses are not leaking, what hose are you using is it weeping. Can you build > a bench tester and check the whole thing out on the bench?? it will take some spare fittings. Who does these for Bruce??are they bored after sleeved? pressed in as is? I'd be calling Bruce asking WTF.
> From: notrace07 notrace07@...
> To: anzhonda600owners anzhonda600owners@yahoogroups.com
> Sent: Mon, Jul 2, 2012 8:17 pm
> Subject: Re: [anzhonda600owners] leaking master cylinder
> Eric
> I bought my parts and resleeved MC from Bruce as well, that would be the only common thing we have going on this issue? I was looking at buying another rebuild kit and have a shop have a go at mine?? The shop knows nothing about Honda 600s but I don't > think this is a specialty type of thing???
>  Kurt
> On Jul 2, 2012, at 8:07 PM, John Mills jbmkwaj@...
> > Eric, if the seal closest to the driver is good, installed in the correct direction and the bore is good, is it possible the brass liner has been misinstalled??
> > From: eric.geiger > egeiger@...
> > To: anzhonda600owners > anzhonda600owners@yahoogroups.com
> > Sent: Mon, Jul 2, 2012 6:16 pm
> > Subject: [anzhonda600owners] leaking master cylinder
> > I posted this in the 2cylinder group as well but I'm looking for more help.
> > i rebuilt a master cylinder today. its a new brass sleeved 13/16 cylinder and has all new check valves and seals from
> > http://www.honda600carparts.com/
> > i put it all together and went to bleed the brakes and noticed fluid leaking into the car through the fire wall after pumping them up.
> > i have disassembled and checked the seals 3 times already and they all look perfect. i also checked to make sure they were installed facing the correct direction and they are when compared to a different 3/4 master cylinder i had laying around.
> > short of buying a new set of seals all over again does anyone have any suggestions??
> > i need to get tho car on the road this week so i can take it to a car show on tuesday the 10th!
> > PLEASE HELP!!
did you buy a new brass sleeved 13/16" MC and the 13/16" seals at the same time?   I wonder if we both got 3/4 seals by mistake??
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX  phone
XXX-XXX-XXXX  fax
XXX-XXX-XXXX  mobile
egeiger@...
www.prgnocturne.com
On Jul 2, 2012, at 10:17 PM, Eric
>  Kurt
> > PLEASE HELP!!
TOM THIES
Post by TOM THIES »
I hope Miles or Mike will ring in on the leaking MC.  Mike rebuilt mine and I know both know a lot and have been around here for a long time so maybe they can help out.
try this vid http://www.youtube.com/watch?v=O5pmTN6vXZ4
Tom
> Eric Geiger
> Monday, July 02, 2012 8:25 PM
> master cylinder
> i have to get ahold of the owner of the 600carparts website and see what he > says.   i cant figure it out for the life of me.
> has anyone rebuilt one of these themselves???
> For the last seal (closest to the firewall/brake pedal) how did you get > the seal over the enlarged part of the piston???  did you just soak it in > brake fluid and stretch it carefully?  or is there a special way to do > this.  thats the only thing i can possibly think of.
> When i first rebuilt it i left the last seal on as the original because i > was unsure of how to get it over the larger portion of the piston.  after > installation and during the brake bleeding process when it started leaking i > took it apart again and decided to take the old seal off and put the new one > on.  the old seal broke while trying to removing it and stretching it to > get it over the piston and then i carefully stretched the new (brake fluid > soaked) seal over the piston making sure not to damage it. it still leaked > when i bled the brakes again.  i took it apart 2 more times and checked > the direction of all the seals against an old 3/4 master i had laying around > and the directions all match.  when putting it back together i made sure > none of the seals folded over onto themselves but still the same result.
> very frustrating!!
> Eric J. Geiger
> PRG
> Nocturne
> XXX-XXX-XXXX
>  phone
> XXX-XXX-XXXX
>  fax
> XXX-XXX-XXXX
>  mobile
> egeiger@...
> www.prgnocturne.com
> > is good, installed in the correct direction and the bore is good, is it > > possible the brass liner has been > > misinstalled??
> > cylinder
> > I posted this in the 2cylinder group as well but I'm looking for more > > help.
> > i rebuilt a master cylinder today. its a new brass sleeved > > 13/16 cylinder and has all new check valves and seals from > > http://www.honda600carparts.com/ > > i put it all > > together and went to bleed the brakes and noticed fluid leaking into the car > > through the fire wall after pumping them up.
> > checked the seals 3 times already and they all look perfect. i also checked > > to make sure they were installed facing the correct direction and they are > > when compared to a different 3/4 master cylinder i had laying > > around.
> > short of buying a new set of seals all over again does anyone > > have any suggestions??
> > PLEASE
> > HELP!!
John Mills
Post by John Mills »
there ya go, thats a possibility or maybe some metric almost fits size?
Yes for 2 out of the 4 seals you unscrew it. 1 is on the very end and The very last seal though has to be pulled over the larger portion of the piston
This is how mine was atleast. The books I have online didn't add much help.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
On Jul 2, 2012, at 10:33 PM, "John Mills" wrote:
I have successfully rebuilt these, I do so many different types of vehicles I don't quite remember how the piston is on these. Isn't there a screw in the center of the piston you need to remove to dissasemble the piston. My books are in the garage - I'll look it up tomorrow.
John Mills
The last seal kit I got was from Miles, I don't know the details on how he puts the kits together or what they might be originally made for
ya ill be getting ahold of miles again in the morning.  need to get this car on the road by the weekend.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX  phone
XXX-XXX-XXXX  fax
XXX-XXX-XXXX  mobile
egeiger@...
www.prgnocturne.com
> From: Eric Geiger egeiger@...
> Sent: Mon, Jul 2, 2012 9:07 pm
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX phone
> XXX-XXX-XXXX fax
> XXX-XXX-XXXX mobile
> egeiger@...
> www.prgnocturne.com
> On Jul 2, 2012, at 10:33 PM, "John Mills" jbmkwaj@...
> > I have successfully rebuilt these, I do so many different types of vehicles I don't quite remember how the piston is on these. Isn't there a screw in the center of the > > piston you need to remove to dissasemble the piston. My books are in the garage - I'll look it up tomorrow.
> > From: Eric Geiger > egeiger@...
> > To: > anzhonda600owners@yahoogroups.com
> > Sent: Mon, Jul 2, 2012 8:25 pm
> > i have to get ahold of the owner of the 600carparts website and see what he says.   i cant figure it out for the life of me.
> > For the last seal (closest to the firewall/brake pedal) how did you get the seal over the enlarged part of the piston???  did you just soak it in brake fluid and stretch it carefully?  or is there a special way to do this.  thats the only thing i can possibly > > think of.
> > When i first rebuilt it i left the last seal on as the original because i was unsure of how to get it over the larger portion of the piston.  after installation and during the brake bleeding process when it started leaking i took it apart again and decided > > to take the old seal off and put the new one on.  the old seal broke while trying to removing it and stretching it to get it over the piston and then i carefully stretched the new (brake fluid soaked) seal over the piston making sure not to damage it. it still > > leaked when i bled the brakes again.  i took it apart 2 more times and checked the direction of all the seals against an old 3/4 master i had laying around and the directions all match.  when putting it back together i made sure none of the seals folded over > > onto themselves but still the same result.
> > very frustrating!!
> > Eric J. Geiger
> > PRG Nocturne
> > XXX-XXX-XXXX
> >  phone
> > XXX-XXX-XXXX
> >  fax
> > XXX-XXX-XXXX
> >  mobile
> > egeiger@...
> > www.prgnocturne.com
> > > From: eric.geiger > > egeiger@...
> > > To: anzhonda600owners > > anzhonda600owners@yahoogroups.com
> > > PLEASE HELP!!
Random Name
Post by Random Name »
Hey sorry I was at the movies, I still need to read all the emails and get caught up and I will take a look at the MC when I get home and give you the size. I replaced everything. The whole braking system is new or rebuilt how ever you want to say it. I believe it's the 3/4 MC, I will check when I get home tonight.
 Kurt
notrace07@...
Eric;
Who did the brass sleeving?
And, you can do a bench bleed to see if the master is working just by attaching the reservoir to the master and holding your fingers over the outlets.  I'm not aware of more than one piston set for the 13/16 master, but the 3/4 master has three different end pistons and without the correct width for the seal there can be all kinds of problems.
I normally clean the cylinders with lacquer thinner after cleaning and then lube the seals with brake cylinder assembly lube.  Also cleaning all the lines with denatured alcohol will protect everything from contamination.
I have gotten seals from different sources and what Miles sells is the best bet.   You also have to understand that check valve for the rear has larger and fewer holes that the front check valve.  Also one has a rubber spacer and the other a metal washer.  Because the seal has to seal around the piston and the cylinder there are all kinds of issues even causing them to be cut on a sharp non-flush brass sleeve or bleed back hole not de-burred .  Clean is all important with brakes but bad parts or good part being sold by some one who does not do their home work can be just as devastating.
> Eric
> Geiger
> Monday, July 02, 2012 9:14 PM
> ya ill be getting ahold of miles again in the morning.  need to get > this car on the road by the weekend.
> Eric J. Geiger
> PRG
> Nocturne
> XXX-XXX-XXXX
>  phone
> XXX-XXX-XXXX
>  fax
> XXX-XXX-XXXX
>  mobile
> egeiger@...
> www.prgnocturne.com
> > Miles, I don't know the details on how he puts the kits together or what > > they might be originally made for
> > From: Eric
> > cylinder
> > Yes for 2 out of the 4 seals you unscrew it. 1 is on the very end and > > The very last seal though has to be pulled over the larger portion of the > > piston
> > This is how mine was atleast. The books I have online didn't add much > > help.
> > Eric J. Geiger
> > PRG Nocturne
> > XXX-XXX-XXXX phone
> > XXX-XXX-XXXX fax
> > XXX-XXX-XXXX mobile
> > egeiger@...
> > www.prgnocturne.com
> > On Jul 2, 2012, at 10:33 PM, "John Mills" > jbmkwaj@...
> > > do so many different types of vehicles I don't quite remember how the > > > piston is on these. Isn't there a screw in the center of the piston you > > > need to remove to dissasemble the piston. My books are in the garage - > > > I'll look it up tomorrow.
> > > From: Eric
> > > Geiger > > egeiger@...
> > > Sent:
> > > master cylinder
> > > i have to get ahold of the owner of the 600carparts website and see > > > what he says.   i cant figure it out for the life of me.
> > > For the last seal (closest to the firewall/brake pedal) how did you > > > get the seal over the enlarged part of the piston???  did you just > > > soak it in brake fluid and stretch it carefully?  or is there a > > > special way to do this.  thats the only thing i can possibly think > > > of.
> > > When i first rebuilt it i left the last seal on as the original > > > because i was unsure of how to get it over the larger portion of the > > > piston.  after installation and during the brake bleeding process > > > when it started leaking i took it apart again and decided to take the old > > > seal off and put the new one on.  the old seal broke while trying to > > > removing it and stretching it to get it over the piston and then i > > > carefully stretched the new (brake fluid soaked) seal over the piston > > > making sure not to damage it. it still leaked when i bled the brakes > > > again.  i took it apart 2 more times and checked the direction of all > > > the seals against an old 3/4 master i had laying around and the directions > > > all match.  when putting it back together i made sure none of the > > > seals folded over onto themselves but still the same result.
> > > very frustrating!!
> > > Eric J.
> > > Geiger
> > > PRG
> > > Nocturne
> > > XXX-XXX-XXXX
> > >  phone
> > > XXX-XXX-XXXX
> > >  fax
> > > XXX-XXX-XXXX
> > >  mobile
> > > egeiger@...
> > > www.prgnocturne.com
> > > > driver is good, installed in the correct direction and the bore is good, > > > > is it possible the brass liner has been > > > > misinstalled??
> > > > From:
> > > > eric.geiger > > > egeiger@...
> > > > To:
> > > > anzhonda600owners > > > anzhonda600owners@yahoogroups.com
> > > > Sent:
> > > > cylinder
> > > > I posted this in the 2cylinder group as well but I'm looking for > > > > more help.
> > > > sleeved 13/16 cylinder and has all new check valves and seals from > > > > http://www.honda600carparts.com/ > > > > i put it all > > > > together and went to bleed the brakes and noticed fluid leaking into the > > > > car through the fire wall after pumping them up.
> > > > i have
> > > > disassembled and checked the seals 3 times already and they all look > > > > perfect. i also checked to make sure they were installed facing the > > > > correct direction and they are when compared to a different 3/4 master > > > > cylinder i had laying around.
> > > > i need to get
> > > > tho car on the road this week so i can take it to a car show on tuesday > > > > the 10th!
> > > > PLEASE HELP!!
Everything was purchased through Bruce online at
honda600carparts.com .
The kit came with 2 new check valves but both were identical.  I used my plastic washer from the original cylinder along with the new springs supplied for one and a supplied metal washer for the other.
It will build pressure but always would leak before enough would build causing us to stop bleeding the system and pull the master back out.
I've been in contact with Bruce
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
On Jul 3, 2012, at 2:00 AM, "
billmyong@...
" wrote:
Eric;
> Eric Geiger
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX
>  phone
> XXX-XXX-XXXX
>  fax
> XXX-XXX-XXXX
>  mobile
> egeiger@...
> www.prgnocturne.com
> > Eric J. Geiger
> > PRG Nocturne
> > XXX-XXX-XXXX phone
> > XXX-XXX-XXXX fax
> > XXX-XXX-XXXX mobile
> > egeiger@...
> > www.prgnocturne.com
> > > wrote:
> > > I have successfully rebuilt these, I do so many different types of vehicles I don't quite remember how the piston is on these. Isn't there a screw in the center of the > > > piston you need to remove to dissasemble the piston. My books are in the garage - I'll look it up tomorrow.
> > > From: Eric Geiger > > egeiger@...
> > > To: > > anzhonda600owners@yahoogroups.com
> > > For the last seal (closest to the firewall/brake pedal) how did you get the seal over the enlarged part of the piston???  did you just soak it in brake fluid and stretch it carefully?  or is there a special way to do this.  thats the only thing i can possibly > > > think of.
> > > When i first rebuilt it i left the last seal on as the original because i was unsure of how to get it over the larger portion of the piston.  after installation and during the brake bleeding process when it started leaking i took it apart again and decided > > > to take the old seal off and put the new one on.  the old seal broke while trying to removing it and stretching it to get it over the piston and then i carefully stretched the new (brake fluid soaked) seal over the piston making sure not to damage it. it still > > > leaked when i bled the brakes again.  i took it apart 2 more times and checked the direction of all the seals against an old 3/4 master i had laying around and the directions all match.  when putting it back together i made sure none of the seals folded over > > > onto themselves but still the same result.
> > > very frustrating!!
> > > Eric J. Geiger
> > > PRG Nocturne
> > > XXX-XXX-XXXX
> > >  phone
> > > XXX-XXX-XXXX
> > >  fax
> > > XXX-XXX-XXXX
> > >  mobile
> > > egeiger@...
> > > www.prgnocturne.com
> > > > From: eric.geiger > > > egeiger@...
> > > > To: anzhonda600owners > > > anzhonda600owners@yahoogroups.com
> > > > PLEASE HELP!!
