conversion of honda 600 to electric
CHEYENNE FLETCHER
Re: conversion of honda 600 to electric
Post by CHEYENNE FLETCHER »
I have a good body that needs a drive train very little rust, and a few dents but otherwise perfect for someone to restore instead of the East coast rust bucket. Cheap!!
> lyletrudell
> Tuesday, June 01, 2010 8:42
> [2cylinderhondas] Re: conversion
> Tom, don't want to argue about cost gas/electric or get into politics, not > the place for it.
> One thing I agree with is that there are better choices
> for an electric conversion than a Honda 600.
> On the east coast engines are
> available, west coast good body shells, lets get them together.
> I need a
> good body shell, have a good drivetrain.
> See we can get
> along!
> Lyle
> "Tom Rapini" wrote:
> > What Dale has put here in
> regard to the sedan I converted to electric is accurate.
> http://www.evalbum.com/325.html
> The
> wife drove it 3 miles to work and back today as she has almost every day for > the last 16 years.
> > In deference to those who think we should
> be preserving these cars, the last body I got was just a shell, stripped of > all parts of value. Seems to me its the engine parts that are precious. From > this newsgroup I get the impression that out west its not hard to come across > a rust-free body, but hard to find an engine worth rebuilding.
> > Regarding the 600 running "...cheaper than any electric car", it > costs about 2.6 cents per mile to run mine on electric. Of course the sun > makes most of my electricity, so cost is relative... relative as in what's the > "true" cost of running your 600 on gasoline that we fight wars for, clean up > massive spills from, and can partly blame for global climate change that will > probably forever change our children's future.
> > Sorry, a bit
> political, but I couldn't let it go unsaid.
> > Anyone serious
> about doing the conversion I would be glad to offer some advice, photos, and > sketches, but as I said to Dale, I think there are better choices for a > conversion these days than the old 600's.
> > Tom
> > From: goinhm@...
> > Sent: Monday, May 31, 2010 3:40 PM
> > Subject: Re:
> [2cylinderhondas] conversion of honda 600 to electric
> > Hi Paula,
> > Check with Tom
> in Ohio (tom@...). He monitors this newsgroup and has converted his Honda 600 > sedan to electric. Here is what he told me;
> > That's my
> converted Honda at
> > The $2000 cost is parts only, my hundreds of hours of labor were > free, I guess.
> > Low cost listed there is due to:
> > 1)
> surplus electric traction motor found for only around $300 > > 2) lead > acid batteries costing only about $70 each when I did it > > 3) controller > costing only about $800 when I did it > > 4) all other mechanical and > electrical parts being made by me
> > The 600 was a good choice
> when I first made this conversion in 1993. Very small and light with a sturdy > chassis that seems to handle the battery weight OK. 16,000 miles (and two > bodies) later we still use the car almost every day. However, with parts > becoming more scarce, plus the lighter, safer designed vehicles available > today, I think I would start with a different vehicle for the conversion if I > were starting now.
> > Tom
> > Converting
> your car to electric could become a major undertaking and it depends on how > you want to use the car. If you goal is to have a car you drive in your local > neighborhood and your top speed is going to be 25 mph, you could do the > conversion by obtaining a used golf cart and putting its drive system into > your car. If you are interested in a car which can be driven on the freeway > and has a range of 100 miles before recharge, you would be better off buying > an electric car instead of converting your Honda. For more information on > converting your car to electric, check out one of the electric car groups > (e.g.
> http://www.diyelectriccar.com/
> > If you are interested in a car which runs on an alternative energy > source, you might consider converting your Honda car to run on alcohol or > propane. Propane fuel has about the same energy content as gasoline and the > conversion involves replacing the carb, fuel tank, and adjusting the timing.
> The fuel system for the car can be 2 of those propane tanks used on a propane > grill. You fill them up just like you do for your grill.
> > Converting
> your car to alcohol (which has about half the energy content as gas) would > involve rejetting the carb, changing out the fuel system from the gas tank to > the carb (replacing all the "rubber" parts which used to handle gasoline > including the gaskets and o-rings in the carb and at the intake manifold). The > timing would also need to be readjusted. The downside of a car running on > alcohol (and you might want to run it on E85 instead of pure alcohol) is that > alcohol absorbs moisture very readily and if you are not using your car > frequently, the fuel may become spoiled from the moisture found in the air > (i.e. humidity variations). The upside of alcohol is that you could make the > alcohol yourself out of newspaper, junk mail, yard debris, food scraps, wood > scraps, anything which is organic. You are pretty much becoming a moonshiner > to produce alcohol fuel for your car.
> > good luck,
> > hey was wondering if anyone knows about converting a honda 600 to > electric...i have four of the little jewels just sitting here going to waste > and thought maybe conversion is the answer...any help will be > appreciated...paula
promoter213
Post by promoter213 »
ha that's cute...i am a 56 yr old lady with no one to help me so if you wanna come help i will be glad for it...
Date: Wed, 2 Jun 2010 08:46:06 -0700
Subject: Re: [2cylinderhondas] Re: conversion of honda 600 to electric
Hey Allen. Get a service manual and re-assemble you car. They are simple to work on. 1 person can drop the motor in a few hours. Or you can rebuild the top end with it in the car. I trust you have recovered all the parts. It sucks that people are so flakey . What are the types of Hondas you have ? All N600 or are they Z coups??These things are like kittens to me I can't help but save every one I find. 3 so far. I have my eyes on 2 more I found during a Harley excursion I took a few weeks back. Arizona cars with pristine bodys.
> Allen Brown
> Honda600 group
> Wednesday, June 02, 2010 4:46
> RE: [2cylinderhondas] Re:
> wow what a wonderful and overwhelming series of
> responses... smile...thanks to all of you who commented... i guess i > am just frustrated.. .i bought all five of these in 2006 with all the hope > and enthusiasm of any proud new parent...but alas my dreams took a sad down > turn in a series of unfortunate events with the loss of my dad, my mother > moving in with me, the closing of my beloved bbq business and my own little > tiny heart attack (ie:"it was barely bad enough to call it a real heart attack > ms. allen")...ha. ..lets see what he says when he gets kicked awake by a > donkey throwing fits in his chest...but i digress...anyway i still love my > little cars i am just so ready to do something with them and my money has all > evaporated but not my love for the cars...after that guy took my best one > apart and then left it abandoned in someone else's garage it kinda took the > wind out of my sails - especially since i had advanced him a good deal of > money...(picture me here kicking my own butt)...when i graduated from high > school in 1973 this was THE car to have (well that or a 1966 mustang if you > could afford it) and i guess i have never given up the dream no matter how > tarnished or dim it might have grown...thanks again to all of you who > responded... you have given me much to think about...meanwhile 3 of my > little darlings languish out in a field and the 4th is in pieces in a garage > while i try to recoup and devise a plan...i am only hoping that the 5th one i > had is being taken care of by the guy i sold it to...again thanks and peace > out...paula
> jpro8071@yahoo. com
> Date: Tue, 1 Jun 2010 17:05:37 +0000
> electric
> It has been done.
> Here's the first one I'd seen from a
> while back:
> http://www.evalbum. com/325
> Only
> goes 45 or 50 mph, but it is older technology.
> Another on
> evalbum:
> http://www.evalbum. com/1238
> Look
> half way down on this page:
> http://mind- temple.com/ 600/humor. htm
> 72hp
> motor to be installed later? Believe me - 70+ horsepower is fun in these > little cars.
> The one thing I would say though - please try to save as
> many parts as you can when you do the conversion. Keep the motors dry, don't > let water into them. Someone on the list can use the parts!
> Allen Brown wrote:
> > hey
> was wondering if anyone knows about converting a honda 600 to electric...i > have four of the little jewels just sitting here going to waste and thought > maybe conversion is the answer...any help will be > appreciated. ..paula
> ____________ _________ _________ _________ _________ _________ _
> Hotmail has tools for the New Busy. Search, chat and e-mail from your > inbox.
> http://www.windowsl ive.com/campaign /thenewbusy? ocid=PID28326: :T:WLMTAGL: ON:WL:en- US:WM_HMP: 042010_1
> The New Busy is not the too busy. Combine all your e-mail accounts with > Hotmail.
> Get busy.
Hotmail: Powerful Free email with security by Microsoft.
Get it now.
bottom cop
Post by bottom cop »
EVA?  Could not find that one.  Did you or anyone else that you know of put together an instruction manual for this conversion.  Could you share the process?  Might even be worth selling the instructions.
Tue, 6/1/10, william esker
Subject: Re: [2cylinderhondas] conversion of honda 600 to electric To: 2cylinderhondas@yahoogroups.com Date: Tuesday, June 1, 2010, 10:55 PM
don't listen to all these guys, i converted one of my two 600's to electric after talking to tom. the other one i'm restoring. go ahead and do it. i got all my parts fromEVA, great guys. if i deceide  to i could back convert the car with little difficulty, the crank was shot anyway!   Bill --- On Mon, 5/31/10, Allen Brown wrote:
> From: Allen Brown
> Subject: [2cylinderhondas] conversion of honda 600 to electric > To: "electric conversion" , "Honda600 group" > Date: Monday, May 31, 2010, 5:48 AM
> hey was wondering if anyone knows about converting a honda 600 to electric...i have four of the little jewels just sitting here going to waste and thought maybe conversion is the answer...any help will be appreciated. ..paula
> Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox.
> Learn more.
bottom cop
Anything for sale
> PLEASE, PLEASE, PLEASE tell us, at least a general location of, where you are whenever you start offering anything that would be difficult/expensive to ship.  It would make the process so much easier.
> For those that have Speedway gas stations in your area, I saw a TV commercial tonight for the frozen drinks they sell and they are using a great looking yellow (72?) coupe as part of it.  You will see it close to the end of the ad with a huge cup straped to the top.
bottom cop
Another option that was brought to my attention today was to use the running gears from one of those mini pickups and put a 600 body on top.
Tue, 6/1/10, bottom cop
> From: bottom cop
> Subject: Re: [2cylinderhondas] conversion of honda 600 to electric > To: 2cylinderhondas@yahoogroups.com > Date: Tuesday, June 1, 2010, 6:16 PM
> I've been considering putting the body of a 600 on a frame designed similar to the Legend cars.  They use an air cooled motor for racing but an old Legend builder and racer that I have been talking with said he would go with a water cooled motor for everday use.  Just have to find the right motorcycle engine and use rear wheel drive.  Google "Legend Cars" to see what I am talking about if you have never seen one.  They use a fiberglass body.  Wish someone was good with fiberglas that could build a complete 600 look-a-like.  What a way to honor the cars without destroying those that are left.
> --- On
> > From: Allen Brown
> > Subject: [2cylinderhondas] conversion of honda 600 to electric > > To: "electric conversion" , "Honda600 group" > > Date: Monday, May 31, 2010, 8:48 AM
> > hey was wondering if anyone knows about converting a honda 600 to electric...i have four of the little jewels just sitting here going to waste and thought maybe conversion is the answer...any help will be appreciated...paula
> > Learn more.
promoter213
they are all 4 coupes...
Date: Wed, 2 Jun 2010 20:02:24 -0500
Subject: RE: [2cylinderhondas] Re: conversion of honda 600 to electric
To: 2cylinderhondas@ yahoogroups. com From: cheyennefletch@ msn.com Date: Wed, 2 Jun 2010 08:46:06 -0700 Subject: Re: [2cylinderhondas] Re: conversion of honda 600 to electric
> Allen Brown
> Honda600 group
> jpro8071@yahoo. com
> electric
> It has been done.
> while back:
> Only
> Another on
> evalbum:
> Look
> 72hp
> Allen Brown wrote:
> > hey
> Get busy.
Get it now.
Hotmail: Trusted email with powerful SPAM protection.
Sign up now.
william esker
Post by william esker »
google : Electric Vehicles of America.bought motor, controller and contactors from them  lots of info on their site  Bill
Hi Paula;
    This is easy as making pie, really.  A few hours is a bit of an exaggeration, it normally takes me 35 minutes to pull a Honda 600 motor, and another hour or so to have the engine in parts and ready to reassemble.
    I have some pictures on the http://autos.groups.yahoo.com/group/anzhonda600owners/  site and in the photo albums titled "Removing your Honda 600 power plant" it gives some suggestions on how to proceed.  All you need is a length of wood hand rail, some rope and a come-a-long to hoist the front end of your Honda 600 off the engine/sub frame.  Then just pull it out from under the car and work on it.  Going back is just as easy.
Contact me if there are any questions.
In San Diego
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Allen Brown > Sent:
> Wednesday, June 02, 2010 8:42
> Honda600 group
> abconcessions@ hotmail.com
> -0500
> Subject: RE: [2cylinderhondas] Re: conversion of honda 600 to > electric
> -0700
> Subject: Re: [2cylinderhondas] Re: conversion of honda 600 to > electric
> Hey Allen. Get a service manual and re-assemble you car. They are simple > to work on. 1 person can drop the motor in a few hours. Or you can rebuild the > top end with it in the car. I trust you have recovered all the parts. It sucks > that people are so flakey . What are the types of Hondas you have ? All N600 > or are they Z coups??These things are like kittens to me I can't help but save > every one I find. 3 so far. I have my eyes on 2 more I found during a > Harley excursion I took a few weeks back. Arizona cars with pristine > bodys.
> > Allen Brown
> > Honda600 group
> > AM
> > responses... smile...thanks to all of you who commented... i guess i > > am just frustrated.. .i bought all five of these in 2006 with all the > > hope and enthusiasm of any proud new parent...but alas my dreams took a sad > > down turn in a series of unfortunate events with the loss of my dad, my > > mother moving in with me, the closing of my beloved bbq business and my own > > little tiny heart attack (ie:"it was barely bad enough to call it a real > > heart attack ms. allen")...ha. ..lets see what he says when he gets > > kicked awake by a donkey throwing fits in his chest...but i digress...anyway > > i still love my little cars i am just so ready to do something with them and > > my money has all evaporated but not my love for the cars...after that guy > > took my best one apart and then left it abandoned in someone else's garage > > it kinda took the wind out of my sails - especially since i had advanced him > > a good deal of money...(picture me here kicking my own butt)...when i > > graduated from high school in 1973 this was THE car to have (well that or a > > 1966 mustang if you could afford it) and i guess i have never given up the > > dream no matter how tarnished or dim it might have grown...thanks again to > > all of you who responded... you have given me much to think > > about...meanwhile 3 of my little darlings languish out in a field and the > > 4th is in pieces in a garage while i try to recoup and devise a plan...i am > > only hoping that the 5th one i had is being taken care of by the guy i sold > > it to...again thanks and peace out...paula
> > jpro8071@yahoo. com
> > electric
> > It has been done.
> > seen from a while back:
> > Only
> > Another on
> > evalbum:
> > Look
> > 72hp
> > motor to be installed later? Believe me - 70+ horsepower is fun in these > > little cars.
> > The one thing I would say though - please try to save as > > many parts as you can when you do the conversion. Keep the motors dry, don't > > let water into them. Someone on the list can use the parts!
> > Allen Brown wrote:
> > hey was wondering if anyone knows about converting a honda 600 to > > electric...i have four of the little jewels just sitting here going to waste > > and thought maybe conversion is the answer...any help will be > > appreciated. ..paula
> > Hotmail has tools for the New Busy. Search, chat and e-mail from your > > inbox.
> > The New Busy is not the too busy. Combine all your e-mail accounts with > > Hotmail.
> > Get
> > busy.
> Get it now.
> Sign up
> now.
promoter213
hey bill...well i've made pie so i guess i can rebuild a honda engine...ha...seriously thanks to everyone for your words of encouragement...i have been so depressed over the turn of events with my 4 little ones and have felt so isolated when it comes to being able to get anything done with them...it helps to know all of you are out there...thanks again...paula
To: anzhonda600owners@yahoogroups.com; 2cylinderhondas@yahoogroups.com
Dan Vann
Re: Anything for sale
Post by Dan Vann »
Ya can't fix stupid !
....but please allow me to demonstrate the proper way to advertise a Honda 600 For Sale... or at least get the ball rolling !?
 This car is located near Charlotte NC , Rt.#16, about 15 minutes from I-485
Anyhoo.....  here's a video of the car
http://www.youtube.com/watch?v=52tROGtlbJA
I've been over every inch of this car and she's ready to go!
rebuilt all brakes, seals, pads/shoes, SS hoses, functional brake booster , cleaned carb w/ new accelerator pump diaphram, gas tank clean and clear. Mechanically sound all original 1970, matching numbers, w/ 57k miles. Last registered/inspected 1980/81. Glass in great shape, interior excellent but not perfect, paint makes it a good "20 footer" but has some scratches on hood by the hood latch. Rolls and drives but I recommend new tires for highway use, needs carpet or I can install for an extra $200, no radio and antenna needs replacing. Also needs windshield spray nozzel.
Tuned w/ new points/plugs/condensor......and voltage regulator.
All lights in working order, horn, indicators, and that annoying buzzer!
I have receipt from original owner dated 1979 when head work was performed and only 2000 miles on the car since that work was performed! It has a Mike O'Connor rebuilt mastercylinder and it has NEW swaybar bushings and brackets.
This car is ready as is..... or ready to be taken to the next step!
I just don't have the time or money to to max this puppy out the way I'd like to - that and my wife says 3 Sedans is enough! ;)
I'm asking $3000 but would consider other serious cash offers.
 Since this writing, the carb has been updated and I have a set of 4 NEW mounted Silvertown bias ply tubed tires or a set of mounted USED (8k miles) Yokohama available (price negotiable) and installed a N45(?) battery, taken from my 72' Sedan
Tire kickers abound.... so spare me the BS!
Money talks and you know what walks....
I'll be delivering another Sedan this weekend so unable to respond to queries....
and yes, that means I have a trailer designed to haul these puppies and can provide transport within a reasonable distance - for a reasonable fee!
Dan, cell- XXX-XXX-XXXX  and may or may not have reception for the next few days
Wed, 6/2/10, bottom cop
Subject: [2cylinderhondas] Anything for sale
Date: Wednesday, June 2, 2010, 10:38 PM
