Now ignition timing, camshaft duration, valve sealing surfaces can change vacuum.
Most vacuum pumps are tiny in comparison to a 600cc engine, yet they produce nearly 30in.
I have problems with my booster occasionally If I pump the brakes coming to a stop. But I don't think it is a problem, the motor just cant draw the vacuum fast enough.
I have seen a few n360s with more traditional boosters mounted on the firewall (they are tiny). But I don't know if they could retrofit on to the american car. If you can find a re-builder for a factory booster I would recommend spending the extra cash for the original part.
Good luck, Bryan
, "feltonminicycle" wrote:
> Probably wont work because a Honda 600 draws such a low vacuum less than 10 a real car pulls like 30 ?
, Jerry wrote:
> > Anyone ever think of using the british remote mount boosters? Looks like you would just need to change a few fitting at the booster its self but they are available brand new and readily available.
> > From: honda600wiz
> > Sent: Thursday, August 26, 2010 3:28 AM
> > Subject: [2cylinderhondas] Re: booster on ebay
> > I send my brake boosters to Karps in California to be rebuilt, not cheap for a rebuild however. Not sure if he could offer a kit as there are three different styles of boosters for the N600 and one for the Z600. Intenal parts could be interchangeable between the boosters also, Miles will know the answer to that question.
, dean m wrote:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... OTORS:1123
> > > --- On Wed, 8/25/10, lyletrudell wrote:
> > > From: lyletrudell
> > > Subject: [2cylinderhondas] brake booster parts and restoring a Honda!
> > > Date: Wednesday, August 25, 2010, 6:23 PM
> > > It's only our braking system!
> > > Nothing to worry about.
> > [The entire original message is not included]
