No power under load? Engine, starts, idles and revs perfectly
Re: No power under load? Engine, starts, idles and revs perfectly
Post by Eric Geiger »
A tooth or 2 off could make total sense though.  Follow Bills instructions for checking timing via the manual and it would solve all your issues
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
On Apr 4, 2016, at 12:50 AM, Eric Geiger
egeiger@...
[anzhonda600owners] Sounds like timing to me.  But I'm no expert
> Eric Geiger
> PRG-Nocturne
> XXX-XXX-XXXX
> Egeiger@...
> On Apr 4, 2016, at 12:48 AM,
> promoter213@...
> [anzhonda600owners] anzhonda600owners@yahoogroups.com
> > Rubbers looks good. But I should check the hoses. Thanks Bryan.
> > I had thoughts that maybe the filter cabin was clogged so I removed it to have a better look, no obstruction. While the filter cabin was off I decided to rev the engine with no filter and  placed a mirror so I can see the inside of the carburetor and check > > if the piston is moving and picking up fuel.
> > To my surprise fuel was being spit out towards the air cabin as I pressed on the accelerator. My tiny mirror got wet.
> > I'm going to check on the timing tomorrow and update.
> > Sent from my iPhone
> > On Apr 3, 2016, at 8:03 PM, "Bryan O'Shaughnessy
> > bryanoshaughnessy@...
> > [anzhonda600owners]" > anzhonda600owners@yahoogroups.com
> > > wrote:
> > > Look at the boot that connects the carburetor to the cylinder head to see if it is leaking air in.  Check the fittings at the ends and also look for cracks in the rubber; it is probably forty years old so don't > > > be surprised if the rubber is cracked.  If not look for other broken vacuum hoses that draw off the carburetor.  Also check your air cleaner and the air-route into the carburetor.  Over time, it may have become clogged.  --Bryan O
> > > > From:
> > > > promoter213@...
> > > > [anzhonda600owners]" > > > anzhonda600owners@yahoogroups.com
> > > > To:
> > > > Sent:
> > > > Sunday, April 3, 2016 2:07 PM
> > > > Subject:
> > > > [anzhonda600owners] No power under load? Engine, starts, idles and revs perfectly
> > > > Flat land, slight incline the car moves and can build up speed shifting all the way to 4th gear.
> > > > Uphill or with a passenger it loses power?
> > > > Engine starts, idles and revs fine. But once I hit the streets it struggles under load. (hill or with passenger/s)
> > > > Any suggestions?
> > > > Thanks in advance
> > > > 71 sedan
I had a similar problem with the engine running great, flying down the freeway at 65 and it felt heavy, I replaced the center silencer and muffler now it screams, but because the center pipe is replaced with a straight line muffler it is a bit loud, but okay.
And its much better pickup and nice power at top end.
I would check them out.
Also, don't leave out the jets, these are the three jets located in the center of the later carb.  I use a set of dental root canal hand drills to open the holes.  The dental tools are really great because they are strong and will clean the gum and crud really well.
Al Mahder
Post by Al Mahder »
Check for a partially plugged (mouse nest) exhaust.
"Eric Geiger egeiger@... [anzhonda600owners]"
"anzhonda600owners@yahoogroups.com"
Sunday, April 3, 2016 11:53 PM
Re: [anzhonda600owners] No power under load? Engine, starts, idles and revs perfectly
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
mailto:egeiger@...
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
promoter213@...
> I had thoughts that maybe the filter cabin was clogged so I removed it to have a better look, no obstruction. While the filter cabin was off I decided to rev the engine with no filter and  placed a mirror so I can see the inside of the carburetor and check > if the piston is moving and picking up fuel.
> Sent from my iPhone
> mailto:bryanoshaughnessy@...
> [anzhonda600owners]" anzhonda600owners@yahoogroups.com
> > Look at the boot that connects the carburetor to the cylinder head to see if it is leaking air in.  Check the fittings at the ends and also look for cracks in the rubber; it is probably forty years old so don't > > be surprised if the rubber is cracked.  If not look for other broken vacuum hoses that draw off the carburetor.  Also check your air cleaner and the air-route into the carburetor.  Over time, it may have become clogged.  --Bryan O
> > > promoter213@...
> > > [anzhonda600owners]" > > anzhonda600owners@yahoogroups.com
> > > mailto:anzhonda600owners@yahoogroups.com
> > > Sent:
> > > Any suggestions?
> > > Thanks in advance
> > > 71 sedan
rhamman70
Post by rhamman70 »
This is a real long shot but will give exactly the symptoms that you describe. If your carb has ever been apart check to be sure the float is installed right side up. It will install upside down, and if it is the car will start, idle and run normally until it needs a lot of fuel flow - high speed or high load - and then it will starve for fuel and lose power.
Don't ask how I know this or why it took me and a real Honda engine expert two years to figure this out. The upside is that you get really good fuel mileage. I got 52 mpg on a trip across Michigan to a car show, but the car absolutely would not go over 60 miles per hour or go up the slightest incline without slowing to 50 mph. Funny now, wasn't at the time.
lloyd hays
Re: No power under load? Engine, starts, idles and revs perfectly [2
Post by lloyd hays »
Well after a couple weeks messing with this,I rolled the timing chain 1 tooth....runs like a bat outta,well you know
On Monday, April 4, 2016 12:35 AM, "'Bill' billmyong@... [anzhonda600owners]" wrote:
[ Attachment(s) from Bill included below]
Scott Walters
Post by Scott Walters »
Running well, these things really don't lack for go if you're willing to rev it.
The level mark across the camshaft sprocket goes parallel to the
engine, not the ground, but the engine is slanted forward a bit. That
can easily throw you off a tooth if you're not expecting it. I had to
squint at it a while before I figured that out. Sounds like maybe you
had the same problem.
-scott
On 4/5/16, lloyd hays deerbut2000@... [anzhonda600owners]
billmyong@...
> � [Attachment(s) from Bill included below] Also, don't leave out the
> jets, these are the three jets located in the center of the later carb.� I
> use a set of dental root canal hand drills to open the holes.� The dental
> crud really well. �Bill
> Sent: Sunday, April 03, 2016 10:30 PM
> Subject: RE: [anzhonda600owners] No power under load? Engine, starts, idles
> and revs perfectly
> � I had a similar problem with the engine running great, flying down the
> muffler it is a bit loud, but okay. ��And its much better pickup and nice
> power at top end.�� I would check them out. Bill
> Sent: Sunday, April 03, 2016 9:53 PM
> Subject: Re: [anzhonda600owners] No power under load? Engine, starts, idles
> and revs perfectly
> � A tooth or 2 off could make total sense though. �Follow Bills instructions
> Eric Geiger PRG-Nocturne
XXX-XXX-XXXXEgeiger@...
egeiger@...
> � Sounds like timing to me. �But I'm no expert
> XXX-XXX-XXXX
Egeiger@...
promoter213@...
[anzhonda600owners]
> � Rubbers looks good. But I should check the hoses. Thanks Bryan.
> to rev the engine with no filter and �placed a mirror so I can see the
> inside of the carburetor and check if the piston is moving and picking up
> fuel.
> Sent from my iPhone
> � Look at the boot that connects the carburetor to the cylinder head to
> see if it is leaking air in.� Check the fittings at the ends and also look
> for cracks in the rubber; it is probably forty years old so don't be
> surprised if the rubber is cracked.� If not look for other broken vacuum
> hoses that draw off the carburetor.� Also check your air cleaner and the
> air-route into the carburetor.� Over time, it may have become clogged.
> --Bryan O
> From: "
promoter213@...
> Sent: Sunday, April 3, 2016 2:07 PM
> Subject: [anzhonda600owners] No power under load? Engine, starts, idles and
> revs perfectly
> � Flat land, slight incline the car moves and can build up speed
> Any suggestions?
> Thanks in advance
> 71 sedan
> #yivXXX-XXX-XXXX #yivXXX-XXX-XXXX -- #yivXXX-XXX-XXXXygrp-mkp {border:1px solid
> #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXygrp-mkp hr {border:1px solid #d8d8d8;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXygrp-mkp #yivXXX-XXX-XXXXhd
> {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px
> 0;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp #yivXXX-XXX-XXXXads
> {margin-bottom:10px;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp .yivXXX-XXX-XXXXad
> {padding:0 0;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp .yivXXX-XXX-XXXXad p
> {margin:0;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp .yivXXX-XXX-XXXXad a
> {color:#0000ff;text-decoration:none;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXygrp-sponsor #yivXXX-XXX-XXXXygrp-lc
> {font-family:Arial;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-sponsor
> #yivXXX-XXX-XXXXygrp-lc #yivXXX-XXX-XXXXhd {margin:10px
> 0px;font-weight:700;font-size:78%;line-height:122%;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXygrp-sponsor #yivXXX-XXX-XXXXygrp-lc .yivXXX-XXX-XXXXad
> {margin-bottom:10px;padding:0 0;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactions
> {font-family:Verdana;font-size:11px;padding:10px 0;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXactivity
> {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXactivity span {font-weight:700;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXactivity span:first-child
> {text-transform:uppercase;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity span a
> {color:#5085b6;text-decoration:none;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity
> span span {color:#ff7900;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity span
> .yivXXX-XXX-XXXXunderline {text-decoration:underline;}#yivXXX-XXX-XXXX
> .yivXXX-XXX-XXXXattach
> {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px
> 0;width:400px;}#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach div a
> {text-decoration:none;}#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach img
> {border:none;padding-right:5px;}#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach label
> {display:block;margin-bottom:5px;}#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach label
> a {text-decoration:none;}#yivXXX-XXX-XXXX blockquote {margin:0 0 0
> 4px;}#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXbold
> {font-family:Arial;font-size:13px;font-weight:700;}#yivXXX-XXX-XXXX
> .yivXXX-XXX-XXXXbold a {text-decoration:none;}#yivXXX-XXX-XXXX
> dd.yivXXX-XXX-XXXXlast p a
> {font-family:Verdana;font-weight:700;}#yivXXX-XXX-XXXX dd.yivXXX-XXX-XXXXlast p
> span {margin-right:10px;font-family:Verdana;font-weight:700;}#yivXXX-XXX-XXXX
> dd.yivXXX-XXX-XXXXlast p span.yivXXX-XXX-XXXXyshortcuts
> {margin-right:0;}#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXattach-table div div a
> {text-decoration:none;}#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXattach-table
> {width:400px;}#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXfile-title a, #yivXXX-XXX-XXXX
> div.yivXXX-XXX-XXXXfile-title a:active, #yivXXX-XXX-XXXX
> div.yivXXX-XXX-XXXXfile-title a:hover, #yivXXX-XXX-XXXX
> div.yivXXX-XXX-XXXXfile-title a:visited {text-decoration:none;}#yivXXX-XXX-XXXX
> div.yivXXX-XXX-XXXXphoto-title a, #yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXphoto-title
> a:active, #yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXphoto-title a:hover,
> #yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXphoto-title a:visited
> {text-decoration:none;}#yivXXX-XXX-XXXX div#yivXXX-XXX-XXXXygrp-mlmsg
> #yivXXX-XXX-XXXXygrp-msg p a span.yivXXX-XXX-XXXXyshortcuts
> {font-family:Verdana;font-size:10px;font-weight:normal;}#yivXXX-XXX-XXXX
> .yivXXX-XXX-XXXXgreen {color:#628c2a;}#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXMsoNormal
> {margin:0 0 0 0;}#yivXXX-XXX-XXXX o {font-size:0;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXphotos div {float:left;width:72px;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXphotos div div {border:1px solid
> #666666;height:62px;overflow:hidden;width:62px;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXphotos div label
> {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXreco-category {font-size:77%;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXreco-desc {font-size:77%;}#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXreplbq
> {margin:4px;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-actbar div a:first-child
> {margin-right:2px;padding-right:5px;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg
> {font-size:13px;font-family:Arial, helvetica, clean,
> sans-serif;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg table
> {font-size:inherit;font:100%;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg
> select, #yivXXX-XXX-XXXX input, #yivXXX-XXX-XXXX textarea {font:99% Arial,
> Helvetica, clean, sans-serif;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg pre,
> #yivXXX-XXX-XXXX code {font:115% monospace;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXygrp-mlmsg * {line-height:1.22em;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXygrp-mlmsg #yivXXX-XXX-XXXXlogo
> {padding-bottom:10px;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-msg p a
> {font-family:Verdana;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-msg
> p#yivXXX-XXX-XXXXattach-count span
> {color:#1E66AE;font-weight:700;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-reco
> #yivXXX-XXX-XXXXreco-head {color:#ff7900;font-weight:700;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXygrp-reco {margin-bottom:20px;padding:0px;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXygrp-sponsor #yivXXX-XXX-XXXXov li a
> {font-size:130%;text-decoration:none;}#yivXXX-XXX-XXXX
> {font-size:77%;list-style-type:square;padding:6px 0;}#yivXXX-XXX-XXXX
> #yivXXX-XXX-XXXXygrp-sponsor #yivXXX-XXX-XXXXov ul {margin:0;padding:0 0 0
> 8px;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-text
> {font-family:Georgia;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-text p {margin:0 0
> 1em 0;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-text tt
> {font-size:120%;}#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-vital ul li:last-child
> {border-right:none !important;}#yivXXX-XXX-XXXX
Bryan O_Shaughnessy
Post by Bryan O_Shaughnessy »
I am surprised that there was no valve-damage.  The cam/valve arrangement has little slack in it; it's all pretty compact and efficient. I'd have expected a piston to crash into one of them.
> "lloyd hays deerbut2000@... [anzhonda600owners]"
> Tuesday, April 5, 2016 5:03 PM
> Attachment(s)
> the jets, these are the three jets located in the center of the later > carb.  I use a set of dental root canal hand drills to open the > holes.  The dental tools are really great because they are strong and will > clean the gum and crud really well.
> Sunday, April 03,
> 2016 10:30 PM
> RE: [anzhonda600owners] No power under load? Engine, starts, idles and revs > perfectly
> with the engine running great, flying down the freeway at 65 and it felt heavy, > I replaced the center silencer and muffler now it screams, but because the > center pipe is replaced with a straight line muffler it is a bit loud, but okay.
> end.
> Sunday, April 03,
> 2016 9:53 PM
> Re: [anzhonda600owners] No power under load? Engine, starts, idles and revs > perfectly
> A tooth or 2 off could make total sense though.  Follow Bills > instructions for checking timing via the manual and it would solve all your > issues > ------------------------------------------
> Eric Geiger
> PRG-Nocturne
> XXX-XXX-XXXX
> Egeiger@...
> egeiger@...
> > expert
> > Eric Geiger
> > PRG-Nocturne
> > XXX-XXX-XXXX
> > Egeiger@...
> > promoter213@...
> > [anzhonda600owners] > anzhonda600owners@yahoogroups.com
> > > I had thoughts that maybe the filter cabin was clogged so I removed it > > > to have a better look, no obstruction. While the filter cabin was off I > > > decided to rev the engine with no filter and  placed a mirror so I can > > > see the inside of the carburetor and check if the piston is moving and > > > picking up fuel.
> > > To my surprise fuel was being spit out towards the air cabin as I > > > pressed on the accelerator. My tiny mirror got wet.
> > > Sent from my iPhone
> > > > connects the carburetor to the cylinder head to see if it is leaking air > > > > in.  Check the fittings at the ends and also look for cracks in the > > > > rubber; it is probably forty years old so don't be surprised if the rubber > > > > is cracked.  If not look for other broken vacuum hoses that draw off > > > > the carburetor.  Also check your air cleaner and the air-route into > > > > the carburetor.  Over time, it may have become clogged.  --Bryan > > > > O
> > > > > From:
> > > > > promoter213@...
> > > > > [anzhonda600owners]" > > > > anzhonda600owners@yahoogroups.com
> > > > > To:
> > > > > Sent:
> > > > > Sunday, April 3,
> > > > > 2016 2:07 PM
> > > > > Subject:
> > > > > [anzhonda600owners] No power under load? Engine, starts, idles and revs > > > > > perfectly
> > > > > power?
> > > > > But once I hit the streets it struggles under load. (hill or with > > > > > passenger/s) > > > > > Any suggestions?
> > > > > Thanks in advance
> > > > > 71 sedan
It's already been said, but again, why was it a tooth off?  A stretched cam chain can mimic a tooth off, and maybe its now advanced?
But if the chain is stretched then it could fail.
On the subject of impacting valves into the pistons, I have seen cams with two teeth off but the rockers were out of adjustment too so they never opened as they should have.
Lots of moving parts in the valve train that can cause a catastrophic event.
Unidentified ware is the biggest reason.
