Hi everyone I want to rebuild my N600 driver this year and want to
start bying the parts now. Is there a list out there of what I need?
And who has these parts. Included in the rebuild I want the 45hp
stuff too. Please help thanks Chris
Building new engine
riceburner006
Re: Building new engine
--- In 2cylinderhondas@yahoogroups.com, "Chris"
circlips,wristpins,base gasket for cylinder,cam housing gasket,head
gasket,cam holder gaskets,"O-rings" for intake manifold&cam chain
tensioner,timing chain and master link. Also fan cushion rubber
bushings,new bolts for fan housing,fresh oil & filter,"Copper HI-
Tack sealer",Silicone sealer or compatible for cam bearing gaskets,A
good manual,Don't rush,& call for help if necessary! riceburner006
I would find out if it needs bored first,then you'll need rings,> Hi everyone I want to rebuild my N600 driver this year and want to
Hi Chris;
The attached file should help, Check everything as you take the engine
apart, then change out as you see is needed. Some items may not need
changing out, others will. The list goes through almost every thing. More
importantly it is a record of what you did or didn't do. As for the rest of
the car, If you don't have a Polaroid camera, get one and take many
pictures. They will be invaluable on reassembly. Renew everything, now or
document it and do it later when you find the parts or have the time to do
it your self. If you think it should be done, then do it.
Hello Chris,
"Riceburner006" mentioned new fan cushion rubber bushings. If you need some, I have reproduction ones available.
I also have the big ugly sway bar bushings for the Sedan and the rubber bushings that hold the sway bar in the lower control arm.
Thanks!!!
Greg
"sixtyfivechevypickup"
Thanks!!!
Greg
> riceburner006
> Friday, June 20, 2003 10:29
> [2cylinderhondas] Re: Building
> new engine
> "Chris" cab4word@a
> > Hi everyone I want to rebuild my N600 driver this year and > want to > > start bying the parts now. Is there a list out there of what > I > need?
> the 45hp
> I would find out
> gasket,cam holder
> To
> to:
> Your
> Yahoo! Terms of Service
