Well today has been a great day, got a lot done.
I haven't been able to get fuel to the carb. Fuel pump bench tested fine.
Disconnected 3 inch rubber fuel line between fuel tank and fuel line-blew
air through fuel line from tank to engine. It's clear and clean=good
Try to blow air backwards into fuel tank where fuel normally exits tank=air
won't go in. Complete blockage. I doubt there's a one-way valve there, is
there?
Removed fuel tank and removed fuel-level sensor. It was locked in
position. No it's clean and moves easily. Still can't get air to go into
fuel tank through exit line.
What to do now? Higher pressure air.....(always use a bigger hammer method)
If the fuel pick-up has garbage like the fuel-level sensor, it's probably
pretty blocked.
Any help is GREATLY appreciated.
Erik in Los Angeles
N600 - fuel tank pick-up clogged-how to clean?
Re: N600 - fuel tank pick-up clogged-how to clean?
Hi Erik;
Miles gave me a hint a while back. Use an old speedometer cable (one end
frayed a bit after being broken off) and chuck the other end on a drill.
Feed it into the outlet side of the tank and all the crud is removed. Not
quite that simple but it works.
Then go to www.hirschauto.com and get some of the tank seal stuff they have.
It really works well.
