Looking for a R/hH rear vent window
for a 1971 sedan. I need th whole window, frame, latch and all. Anybody
have one available?
Thank you
Ken
have one available?
Thank you
Ken
calicutty1
Re: Looking for a R/hH rear vent window
I believe I have one. It is a little dirty, the chrome bolt that goes
through the glass and holds the latch is corroded. If you are not looking
for something perfect and needs a little cleaning, shipping cost is all I
want. Let me know if you're interested and I'll dig it out. Bill
>From: "R" Reply-To:
>To:
>Subject: [2cylinderhondas] Looking for a R/hH rear vent window
>Date: Mon, 12 Dec 2005 16:54:21 -0000
>have one available?
>Thank you
>Ken
> SPONSORED LINKS
> Honda part
> Felton ca
> Po box
Car won't go above 15mph
Okay, so my car (n600) has been sitting for about a month without starting. It ran rough before this, so I'm not too surprised that I'm suddenly having problems.
it took a good 4 minutes to get it started. it finally started. I cruised around my neighborhood and I could not go above 15mph. Even in 1st and 2nd gear it seemed slower than normal.
My first guess is that it is something with the fuel delievery. Maybe my fuel filter is clogged or maybe the fuel lines themselves need replacing. This wouldnt' surprise me as I have a gas smell around my car.
Can anyone give recommendations on what to tackle? I'm going to replace the points, condenser, spark plugs, oil filter, and the fuel filter soon. If this doesn't fix it I'm going to have to replace all of the fuel lines as well, which I might as well do anyway just to be safe.
While I have you attention, can anyone tell me what size screw to use to put the fog light (or whatever those orange lights are on the grill) covers back on?
Matt
Yahoo! DSL Something to write home about. Just $16.99/mo. or less
Matt
discrete85
Re: Car won't go above 15mph
This may sound stupid, but is it running on both cylinder. If one of the plugs was fouled, (easy fix), or something else where it was only running on one cylinder that would cause it to only go about 15. Ask me how I know
Alan
Alan
Note: 1 image(s) originally linked in this post are no longer available (cid:002001c6140e$969ae8b0$AC0781A8@alan).> ----- Original Message -----
> Matthew Timion
> Saturday, January 07, 2006 5:59
> [2cylinderhondas] Car won't go
> above 15mph
> without starting. It ran rough before this, so I'm not too surprised > that I'm suddenly having problems.
> started. it finally started. I cruised around my neighborhood and > I could not go above 15mph. Even in 1st and 2nd gear it seemed slower > than normal.
> delievery. Maybe my fuel filter is clogged or maybe the fuel lines > themselves need replacing. This wouldnt' surprise me as I have a gas > smell around my car.
> tackle? I'm going to replace the points, condenser, spark plugs, oil > filter, and the fuel filter soon. If this doesn't fix it I'm going to > have to replace all of the fuel lines as well, which I might as well do anyway > just to be safe.
> size screw to use to put the fog light (or whatever those orange lights are on > the grill) covers back on?
> Matt
> Yahoo!
> DSL
Thanks for the idea Alan. hopefully I'll be able to change the plugs tomorrow. I have two just waiting to be put in.
ALAN FLORSHEIM wrote:
Note: 1 image(s) originally linked in this post are no longer available (cid:3763994370000000@...).
Yahoo! DSL Something to write home about. Just $16.99/mo. or less> This may sound stupid, but is it running on both cylinder. If one of the plugs was fouled, (easy fix), or something else where it was only running on one cylinder that would cause it to only go about 15. Ask me how I know
> Alan
> > Matthew Timion
> > Saturday, January 07, 2006 5:59 PM
> > [2cylinderhondas] Car won't go above 15mph
> > it took a good 4 minutes to get it started. it finally started. I cruised around my neighborhood and I could not go > > above 15mph. Even in 1st and 2nd gear it seemed slower than normal.
> > Matt
> > Yahoo! DSL
Well, even running on one cylinder it should max out at 35 MPH. I am wondering if you have a early carb and it diaphragm has gone out. Because without the diaphragm connected to the venturi piston your running at a little better than idle fuel volume.
Note: 1 image(s) originally linked in this post are no longer available (cid:220504808@08012006-024a).> -----Original Message-----
> Saturday, January 07, 2006 10:41
> change the plugs tomorrow. I have two just waiting to be put > in.
> ALAN FLORSHEIM
> > This may sound stupid, but is it running on both cylinder. If one of > > the plugs was fouled, (easy fix), or something else where it was only > > running on one cylinder that would cause it to only go about 15. Ask me how > > I know
> > Alan
> > > Matthew
> > > Timion
> > > Sent:
> > > month without starting. It ran rough before this, so I'm not too > > > surprised that I'm suddenly having problems.
> > > it took a good 4
> > > minutes to get it started. it finally started. I cruised > > > around my neighborhood and I could not go above 15mph. Even in 1st > > > and 2nd gear it seemed slower than normal.
> > > it is something with the fuel delievery. Maybe my fuel filter is > > > clogged or maybe the fuel lines themselves need replacing. This > > > wouldnt' surprise me as I have a gas smell around my car.
> > > Can anyone give recommendations on what to tackle? I'm going > > > to replace the points, condenser, spark plugs, oil filter, and the fuel > > > filter soon. If this doesn't fix it I'm going to have to replace all > > > of the fuel lines as well, which I might as well do anyway just to be > > > safe.
> > > While I have you attention, can anyone tell me what size > > > screw to use to put the fog light (or whatever those orange lights are on > > > the grill) covers back on?
> > > Matt
> > > Yahoo!
> > > DSL
> Yahoo!
> DSL
howardsugarman
I had this same problem a few months ago and i lightly
tapped the side of he carburator and i think the
diaphram click back in place and it's running fine at
the moment.
--- Bill Colford wrote:
Just $16.99/mo. or less.
dsl.yahoo.com
the moment.
--------------------------------------------------------------------------> Well, even running on one cylinder it should max out
> at 35 MPH. I am
]On Behalf Of
> Matthew Timion
> Sent: Saturday, January 07, 2006 10:41 PM
> Subject: Re: [2cylinderhondas] Car won't go above
> 15mph
> to change the plugs
> Alan
> From: Matthew Timion
> Sent: Saturday, January 07, 2006 5:59 PM
> Subject: [2cylinderhondas] Car won't go above
> 15mph
> surprised that I'm
> around my car.
> to be safe.
> covers back on?
> Matt
----------------------------------------------------------------------------> Yahoo! DSL Something to write home about. Just
> $16.99/mo. or less
> $16.99/mo. or less
> SPONSORED LINKS Honda part Felton ca Po box
Yahoo! DSL � Something to write home about.> --
dsl.yahoo.com
dustyspath
Hi Matt.
I just woke up and yours is the first message on my screen, so I don't know what the others have said... but I feel its a Vacuum Advance kind of thing. How does it rev? Does it spin up?
> My first guess is that it is something with the fuel delievery. Maybe my fuel filter is clogged or maybe the fuel lines themselves > need replacing. This wouldnt' surprise me as I have a gas smell around my car.
> Matt
> Yahoo! DSL
'88 Plymouth Sundance 2.2l
Used-to-drive: Chrysler Simca 1204
Yahoo! DSL
The previous owner had a rebuilt carb from Mike O'Connor... he said that he was sent the later version.
Bill Colford wrote:
Note: 1 image(s) originally linked in this post are no longer available (cid:3769398376000000@...).
Bill Colford wrote:
Yahoo! DSL Something to write home about. Just $16.99/mo. or less> Well, even running on one cylinder it should max out at 35 MPH. I am wondering if you have a early carb and it diaphragm has gone out. Because without the diaphragm connected to the venturi piston your running at a little better than idle fuel volume.
> > 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > > On Behalf Of > > Matthew Timion > > Sent:
> > Re: [2cylinderhondas] Car won't go above 15mph
> > ALAN FLORSHEIM
> > > Alan
> > > > From:
> > > > Matthew Timion
> > > > To:
> > > > Sent:
> > > > Subject:
> > > > Can anyone give recommendations on what to tackle? I'm going to replace the points, condenser, spark plugs, oil > > > > filter, and the fuel filter soon. If this doesn't fix it I'm going to have to replace all of the fuel lines as well, which I might as well do anyway just to be safe.
> > > > Matt
> > > > Yahoo! DSL
> > Yahoo! DSL
This could very well be it too. The vacuum advance is all the way advanced on this car. SInce I don't know too much about carbed cars yet I'm still trying to figure it out.
I'm planning on replacing the points and condenser today, so I'll adjust the vacuum advance as well.
Marshall Montchalin wrote:
Ring in the New Year with Photo Calendars. Add photos, events, holidays, whatever.
Yahoo! Photos> Hi Matt.
> Marshall
> Matthew Timion
> > Matt
> > Yahoo! DSL
> Yahoo! DSL
