Ignition coil
iain
Ignition coil
Post by iain »
Where can I get a new ignition coil? Also, I read in the post about
using a replacements from a motorcycle.
Any info is helpful.
Thanks!
Joseph Corsinita
Re: Ignition coil
Post by Joseph Corsinita »
In a message dated 5/6/2006 2:36:25 PM Eastern Daylight Time, mrosner@... writes:
I use in my 72 Z a Harley Davidson Accel Super Coil w/ 8.8 Plug Wires
and never had a problem with it.
Re: Ignition coil
HI Mike;
If you go to the photo section of the ANZhondagroup site, there is a How To
change out the lines on your coil. This is often what is causing the
problem, and the directions are simple. Also, I have only found 1 coil that
was Bad.
