Fw: [2cylinderhondas] Remove rear wheel
cotton
Post by cotton »
This old man is getting dumber and blinder everyday.  I have line and parking cable loose but can't figure out how to remove the wheel cylinder,  Help.....    '72 N 600.  Thanks
Eddie Velasquez
Re: Fw: [2cylinderhondas] Remove rear wheel
Post by Eddie Velasquez »
if I rember, right it has 2 screws 1 on each side. take them out, take off the brake line and tap the wheel cylinder with a hammer, you will see it coming loose. I think a 73 civic wheel cylinder will fit it. good luck Eddie
> '72 N 600.  Thanks
cotton
Post by cotton »
Thanks Eddie.  Guess I need to do more cleaning and get better light as I didn't see any screws or bolts.  It will slide back and forth in the slot.
I'll check it out tomorrow.
> Eddie
> Velasquez
> Monday, April 14, 2008 8:26
> rear wheel
> if I rember, right it has 2 screws 1 on each side. take them out, take off > the brake line and tap the wheel cylinder with a hammer, you will see it > coming loose. I think a 73 civic wheel cylinder will fit it. good luck > Eddie > cotton cotteni@brazosnet. com
> > dumber and blinder everyday.  I have line and parking cable loose but > > can't figure out how to remove the wheel cylinder, > > Help.....    '72 N 600.  Thanks
> Checked by AVG.
> Version: 7.5.519 / Virus Database: 269.22.13/1377 - Release Date:
> 4/14/2008 9:26 AM
Love
Post by Love »
The one cup wheel cylinder in cars up to vin 1049184 has a retaining clip.  No bolts.  By sliding, only one piston is needed.  The 5/8 cups are common to the 93 Geo Metro.
Bruce D.
----- Original Message ---- From: cotton To: 2cylinderhondas@yahoogroups.com Sent: Monday, April 14, 2008 6:49:50 PM Subject: Re: Fw: [2cylinderhondas] Remove rear wheel
    Thanks Eddie.  Guess I need to do more cleaning and get better light as I didn't see any screws or bolts.  It will slide back and forth in the slot.  I'll check it out tomorrow.
> Eddie Velasquez
> Monday, April 14, 2008 8:26 PM
> if I rember, right it has 2 screws 1 on each side. take them out, take off the brake line and tap the wheel cylinder with a hammer, you will see it coming loose. I think a 73 civic wheel cylinder will fit it. good luck Eddie > cotton cotteni@brazosnet. com
> Checked by AVG.
> Version: 7.5.519 / Virus Database: 269.22.13/1377 - Release Date: 4/14/2008 9:26 AM
cotton
Post by cotton »
Thanks Bruce,  I'm sure this is not the last question I'll be asking.  Bear with me.
> Bruce
> Dewing
> Monday, April 14, 2008 9:47
> rear wheel
> The
> No bolts.  By sliding, only one piston is needed.  The 5/8 cups are > common to the 93 Geo Metro.
> Bruce
> D.
> From: cotton cotteni@brazosnet. com
> rear wheel
>     Thanks
> Eddie.  Guess I need to do more cleaning and get better light as I didn't > see any screws or bolts.  It will slide back and forth in the slot.
> > Eddie Velasquez
> > 2cylinderhondas@
> > yahoogroups. com
> > PM
> > Remove rear wheel
> > if I rember, right it has 2 screws 1 on each side. take them out, take > > off the brake line and tap the wheel cylinder with a hammer, you will see it > > coming loose. I think a 73 civic wheel cylinder will fit it. good luck > > Eddie > > cotton > cotteni@brazosnet.
> > com
> > > dumber and blinder everyday.  I have line and parking cable loose but > > > can't figure out how to remove the wheel cylinder, > > > Help.....    '72 N 600.  Thanks
> > Checked by AVG.
> > 4/14/2008 9:26 AM
> Checked by AVG.
> 4/14/2008 9:26 AM
Re: Fw: [2cylinderhondas] Remove brakes
Post by Miles »
The with dual piston wheel cylinders have 2 6x10 nuts on the back.
The early sedans have dual opposing clips like Bruce says, you will
have to slide back the rubber dust boot to see them.
The Civic wheel cylinders are not a direct fit. The threads are wrong
pitch so you would have to install 10mm x 1.0mm thread pitch nuts or
make an adapter. Also, the 600's only have one bleeder in the rear,
so if you use the Civic cyls, you will have to make some adapters so
you can have 2 bleeders.
> From: Bruce Dewing
> Sent: Monday, April 14, 2008 9:47 PM
> Bruce D.
> From: cotton
> From: Eddie Velasquez
> Sent: Monday, April 14, 2008 8:26 PM
> Checked by AVG.
> Checked by AVG.
4/14/2008 9:26 AM
cotton
Post by cotton »
Thanks Guys,  I have the one piston type that has like two horse shoe type clips holding.  Got lucky on that one as cup is soft and not cracked, piston and cylinder is not pitted.
Cleaned up good and back together.  Thanks for y'alls help.  But I created another problem,  the little thing with the roller, kinda like a brake adjuster fell out and don't know where it goes.  Can't use other side for reference
as friend took it apart and doesn't remember.  If anyone has a diagram of the brakes I Sure would Appreciate it.   Google didn't help me.   Sorry unable to remove the other text mssgs.
> Wednesday, April 16, 2008 12:27
> brakes
> The
> early sedans have dual opposing clips like Bruce says, you will > have to > slide back the rubber dust boot to see them.
> "cotton" wrote:
> > Thanks Bruce, I'm
> > From: Bruce Dewing
> > Subject: Re: Fw:
> > The one
> retaining clip. No
> the 93 Geo Metro.
> > Bruce D.
> > From: cotton
> > Subject: Re: Fw:
> > Thanks
> > Subject: Re: Fw:
> > if I rember,
> Eddie
> I have line
> remove the wheel
> message.
> > Checked by AVG.
> > Checked by
> AVG.
> > Version: 7.5.519 / Virus Database: 269.22.13/1377 - Release > Date:
> 4/14/2008 9:26 AM
> Checked by AVG.
> Version: 7.5.524 / Virus Database: 269.22.13/1378 - Release Date:
> 4/15/2008 9:12 AM
mterrens
Post by mterrens »
The rear brakes diagram is on page 6-4 of the Coupe parts catalog.  Here's the catalog...
http://www.honda600coupe.com/Honda_600_ ... atalog.pdf
> cotton
> Wednesday, April 16, 2008 11:10
> brakes
> type that has like two horse shoe type clips holding.  Got lucky on that > one as cup is soft and not cracked, piston and cylinder is not pitted.
> Cleaned up good and back together.  Thanks for y'alls help.  But I > created another problem,  the little thing with the roller, kinda like a > brake adjuster fell out and don't know where it goes.  Can't use other > side for reference
> remember.  If anyone has a diagram of the brakes I Sure would Appreciate > it.   Google didn't help me.   Sorry unable to remove the > other text mssgs.
> > Miles
> > AM
> > Remove brakes
> > The Civic
> > wheel cylinders are not a direct fit. The threads are wrong > > pitch so you > > would have to install 10mm x 1.0mm thread pitch nuts or > > make an adapter.
> > so if you use the
> > you can have 2
> > bleeders.
> > Miles
> > "cotton" wrote:
> > > Thanks Bruce, I'm
> > > From: Bruce Dewing
> > > Subject: Re: Fw:
> > > The
> > one cup wheel cylinder in cars up to vin 1049184 has a > > retaining clip.
> > > Bruce D.
> > > From: cotton
> > > Subject: Re: Fw:
> > Thanks Eddie. Guess I need to do more cleaning and get > > better light as I > > didn't see any screws or bolts. It will slide back > > and forth in the > > slot. I'll check it out tomorrow.
> > yahoogroups. com
> > > cotton
> > > This old man is
> > 600. Thanks
> > > Checked by AVG.
> > > Checked
> > by AVG.
> > > Version: 7.5.519 / Virus Database: 269.22.13/1377 - Release > > Date:
> > 4/14/2008 9:26 AM
> > Checked by AVG.
> > 4/15/2008 9:12 AM
> Internal Virus Database is out-of-date.
> Checked by AVG.
> Version:
> 7.5.519 / Virus Database: 269.22.7/1361 - Release Date: 4/5/2008 7:53 > AM
mterrens
Post by mterrens »
Also, the rear brake adjuster is shown on page 119 & 120 of the Coupe shop manual.  Here is the manual..
http://www.honda600coupe.com/Honda_600_ ... Manual.pdf
> cotton
> brakes
> > Miles
> > AM
> > Remove brakes
> > The Civic
> > so if you use the
> > you can have 2
> > bleeders.
> > Miles
> > "cotton" wrote:
> > > Thanks Bruce, I'm
> > > From: Bruce Dewing
> > > Subject: Re: Fw:
> > > The
> > > Bruce D.
> > > From: cotton
> > > Subject: Re: Fw:
> > yahoogroups. com
> > > cotton
> > > This old man is
> > 600. Thanks
> > > Checked by AVG.
> > > Checked
> > by AVG.
> > 4/14/2008 9:26 AM
> > Checked by AVG.
> > 4/15/2008 9:12 AM
> Checked by AVG.
> Version:
cotton
Post by cotton »
Steven,  Sure appreciate these two.  I'm sure they are going to be a big help.
> Steven
> Michelsen
> Wednesday, April 16, 2008 10:38
> brakes
> manual..
> http://www.honda600 coupe.com/ Honda_600_ Coupe_Shop_ Manual.pdf
> Steve
> > cotton
> > AM
> > Remove brakes
> > piston type that has like two horse shoe type clips holding.  Got lucky > > on that one as cup is soft and not cracked, piston and cylinder is not > > pitted.  Cleaned up good and back together.  Thanks for y'alls > > help.  But I created another problem,  the little thing with the > > roller, kinda like a brake adjuster fell out and don't know where it > > goes.  Can't use other side for reference
> > remember.  If anyone has a diagram of the brakes I Sure would > > Appreciate it.   Google didn't help me.   Sorry unable > > to remove the other text mssgs.
> > > Miles
> > > Sent:
> > > AM
> > > Remove brakes
> > > The Civic
> > > wheel cylinders are not a direct fit. The threads are wrong > > > pitch so > > > you would have to install 10mm x 1.0mm thread pitch nuts or > > > make an > > > adapter. Also, the 600's only have one bleeder in the rear, > > > so if you > > > use the Civic cyls, you will have to make some adapters so > > > you can > > > have 2 bleeders.
> > > Miles
> > > "cotton" wrote:
> > > > Thanks Bruce, I'm
> > > asking. Bear with
> > > me.
> > > > From: Bruce
> > > Dewing
> > > > To:
> > > > Subject: Re: Fw:
> > > > The
> > > one cup wheel cylinder in cars up to vin 1049184 has a > > > retaining clip.
> > > The 5/8 cups are
> > > > Bruce D.
> > > > From:
> > > cotton
> > > > To:
> > > > Subject: Re: Fw:
> > > Thanks Eddie. Guess I need to do more cleaning and get > > > better light as > > > I didn't see any screws or bolts. It will slide back > > > and forth in the > > > slot. I'll check it out tomorrow.
> > > yahoogroups. com
> > > > cotton
> > > wrote:
> > > > This old man is
> > > '72 N 600. Thanks
> > > > Checked
> > > by AVG.
> > > Release
> > > > Checked
> > > by AVG.
> > > Release Date:
> > > 4/14/2008 9:26 AM
> > > Checked by AVG.
> > > 4/15/2008 9:12 AM
> > Checked by AVG.
> > Version: 7.5.519 / Virus Database: 269.22.7/1361 - Release Date:
> > 4/5/2008 7:53 AM
> Checked by AVG.
> Version: 7.5.524 / Virus Database: 269.23.0/1381 - Release Date: 4/16/2008 > 9:34 AM
