working on the 600 and have come to a problem, I need to remove the
cover for the Generator, its the copper conductor on the outside and
its a press fit, Im unsure If Im describing this correctly?? same
output shaft that the fan belt is attch. too... any ideas or where I
can appropriate one?
G
Need a special tool or something that will work
ranger13fox2
Re: Need a special tool or something that will work
It sounds like you are trying to remove the flywheel. If so, you do need a fine thread bolt which screws into the center of the flywheel/rotor winding shaft. In the past, I have noticed Miles selling the hardened bolt. If you are going to work on these cars, this special bolt is a must-have item.
City's Best 2008 .
Vote for your city's best dining and nightlife.> working on the 600 and have come to a problem, I need to remove the
> can appropriate
> one?
> G
City's Best 2008 .
gary cushman
Yea thats what it is, Im just not used to working on a part motorcycle part car engine, really a unique experience! Ill get with Miles about that bolt, cant find one locally, too many american cars here, nothing Japanese here that old, even the Honda dealer wanted a picture of it, they never heard of one!!
G
----- Original Message ---- From: "goinhm@..." To: 2cylinderhondas@yahoogroups.com Sent: Thursday, June 12, 2008 2:35:47 PM Subject: Re: [2cylinderhondas] Need a special tool or something that will work
City's Best 2008 .
G
Vote for your city's best dining and nightlife.> working on the 600 and have come to a problem, I need to remove the > cover for the Generator, its the copper conductor on the outside and > its a press fit, Im unsure If Im describing this correctly?? same > output shaft that the fan belt is attch. too... any ideas or where I > can appropriate one?
> G
City's Best 2008 .
