Cylinders w/pistions and rods....
ranger13fox2
Post by ranger13fox2 »
tried to get my engine apart, still cant get the pistons out of the
cylinders, both are froze in really bad, tried that "special" un
freezing liquid that supposed to help, didnt do a dang thang!!! so now
my options are to replace the cylinders, pistions and rods, and look
for a replacement...any ideas????
G
cotton
Re: Cylinders w/pistions and rods....
Post by cotton »
I don't know about frozen pistons or what you were using but I have had
PB Blaster unfreeze some impossible things.  Saturate it good and then every time you come by it give it several taps and squirt it again.  Do this two or the days if need be.  Good Luck
Cotton      N. Central Texas
> ranger13fox2
> Monday, August 18, 2008 6:31
> [2cylinderhondas] Cylinders
> for a replacement. ..any ideas????
> G
PETER WATKINS
Post by PETER WATKINS »
Hi Coka cola is good for freeing pistons, its not a joke it does work.
> Message Received: Aug 18 2008, 01:28 PM
> From: "cotton"
> Cc:
> Subject: Re: [2cylinderhondas] Cylinders w/pistions and rods....
>              Cotton
>      N. Central Texas
> > ranger13fox2
> > Monday, August 18, 2008 6:31 AM
> > tried to get my engine apart, still cant get the pistons out of the > > cylinders, both are froze in really bad, tried that "special" un > > freezing liquid that supposed to help, didnt do a dang thang!!! so now > > my options are to replace the cylinders, pistions and rods, and look > > for a replacement. ..any ideas????
> > G
Dan Kent
Post by Dan Kent »
Marvels Mystery oil works wonders give it a try before you give up. Napa auto supply? I think.
www.marvelmystery oil .com/
--- On Mon, 8/18/08, ranger13fox2 wrote:
Subject: [2cylinderhondas] Cylinders w/pistions and rods....
Date: Monday, August 18, 2008, 7:31 AM
tried to get my engine apart, still cant get the pistons out of the cylinders, both are froze in really bad, tried that "special" un freezing liquid that supposed to help, didnt do a dang thang!!! so now my options are to replace the cylinders, pistions and rods, and look for a replacement. ..any ideas????
G
gary cushman
Post by gary cushman »
and everyone probably thinks your in the zone....yea that usually will work, but not this time, I have used heat, in the oven at 350 degrees for 2 hours, some other specialized soaking agent that only made a hella mess, Im not at ends wit, but just asking....Ill have to get ingenious here, maybe Ill have flash backs working on military vehicles...
                                                             G
----- Original Message ---- From: PETER WATKINS To: 2cylinderhondas@yahoogroups.com Sent: Monday, August 18, 2008 4:16:56 PM Subject: Re: [2cylinderhondas] Cylinders w/pistions and rods....
> From: "cotton"
> Cc:
>              Cotton
>      N. Central Texas
> > ranger13fox2
> > G
tunsys
Post by tunsys »
I had a motor seized at top dead center. I thought I would never get it broken loose.
When the crank shaft is at the top of the stroke it is very difficult to get a stuck piston
loose you are pushing against the corrosion, and a centered rod. If all else fails, you can
pour some muratic acid on the pistons, in a day or so, they will just dissolve. It is some
nasty stuff though.
Bryan
> G
gary cushman
Well that is one that I havent tried yet, I have heard of it years ago, but gettin older aint a benefit in the mind department, I will check that out,  in the mean time I am still looking for new pistons and rings main bearing, know of anyone? the pistons in her now, the skirts are both cracked
                                                               G
----- Original Message ---- From: tunsys To: 2cylinderhondas@yahoogroups.com Sent: Monday, August 18, 2008 9:25:07 PM Subject: [2cylinderhondas] Re: Cylinders w/pistions and rods....
When the crank shaft is at the top of the stroke it is very difficult to get a stuck piston loose you are pushing against the corrosion, and a centered rod. If all else fails, you can pour some muratic acid on the pistons, in a day or so, they will just dissolve. It is some nasty stuff though.
Bryan
> tried to get my engine apart, still cant get the pistons out of the > cylinders, both are froze in really bad, tried that "special" un > freezing liquid that supposed to help, didnt do a dang thang!!! so now > my options are to replace the cylinders, pistions and rods, and look > for a replacement. ..any ideas????
> G
Robert Mielke
Post by Robert Mielke »
Message
I've not done this, but my father soaked an old (20's era) motorcycle engine in a tub of kerosene for nearly 6 months. Everyweek he would remove it scape and clean it, tap, bump, pound and try to turn bolts and nuts, but he got it apart. I know that luxury of time may not be available to everyone nor be certain of success.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > gary cushman > Sent:
> Tuesday, August 19, 2008 9:00
>   Well that is one that I havent tried yet, I have heard of it years > ago, but gettin older aint a benefit in the mind department, I will check that > out,  in the mean time I am still looking for new pistons and rings main > bearing, know of anyone? the pistons in her now, the skirts are both cracked
> G
> From: tunsys
> 9:25:07 PM
> rods....
> I had a motor seized at top dead center. I thought I would never get it > broken loose.
> When the crank shaft is at the top of the stroke it is very > difficult to get a stuck piston > loose you are pushing against the > corrosion, and a centered rod. If all else fails, you can > pour some > muratic acid on the pistons, in a day or so, they will just dissolve. It is > some > nasty stuff though.
> Bryan
> 2cylinderhondas@
> yahoogroups. com
> , "ranger13fox2"
> pistons out of the
> that "special" un
> ideas????
> > G
zayjspeed
Post by zayjspeed »
--- In 2cylinderhondas@yahoogroups.com, "tunsys" wrote:
>Oh Yea that will do it! be sure not to get any acid on any thing
but the top of the piston if you do have a paint brush in a mixture
of baking soda & water ready to stop un wanted affect.Use a turky
baster or eye dropper to apply. Keep this out side and hold your
breath when giving application or close inspection
these vapors can melt the little hair in your lungs! I do this a lot
on bad gas tanks in the "M" world. Do this in a plastic pan like a
cement/ mortor pan home depot sells the stuff
:::::::::::::::::::::::::::::::::::::Zay
> nasty stuff though.
> Bryan
, "ranger13fox2"
> > G
zayjspeed
Post by zayjspeed »
--- In 2cylinderhondas@yahoogroups.com, gary cushman
>You can drill some holes through the top of the piston @ 11:00~1:00
or 5:00~7:00 point with an 1/8" drill in a line so you can work a 32
t hack sawblade through and cut to the edge of the piston to make a
relif. you can get long drill bits and a blade holder handle @ tool
supply if you have a bench grinder you can grind the hack saw blade
on the dull side to a knife point to work into piston. Be care full
with sleve/fins/ rods. if the Cyl is off of block build box out of
2X12 make it so base of cyl sits on edge of it and the rest hangs
inside. OR TAKE TO MACHINE SHOP THEY HAVE "E.D.M." "END MILL" and
other nice tools to make very short work of this , SAFE & SURE!
> �� and everyone probably thinks your in the zone....yea that
> ������������������������������������������������������������ G
> From: PETER WATKINS
> From: "cotton"
> Cc:
> ���� I don't know about frozen pistons or what you were using but I have had
> PB Blaster unfreeze some impossible things.� Saturate it good and
again.� Do this two or the days if need be.� Good Luck
> ������������ Cotton
> ���� N. Central Texas�
> From: ranger13fox2
> Sent: Monday, August 18, 2008 6:31 AM
> G
