muffler
Re: muffler
Write Mike O'Connor at tmoc1990@...
. He has (had?) NOS coupe mufflers in the box! I got mine from him some time back.
Re: muffler
Hi Steve,
I read your story about changing the muffler and it sounded like the first time I tried to replace the tailpipe. The easiest way to remove exhaust system components which do not separate easily is to use an oxy-acetylene torch ( I wish I had a torch the first time I worked on the exhaust system). Heat the joint until it is cherry red and then the pieces separate very easily. I have seen this approach used at the muffler shops.
There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com .
Psssst...Have you heard the news?> Write Mike O'Connor at
> tmoc1990@aol. com
> got
> mine
> Steve
Re: muffler
Ah if only I had a torch. I suppose a cheap propane torch might have done it. Anyway I managed to get it together without demolishing anything with my BFH. Since then I have had to resort to having my whole exhaust system behind the heat exchanger fabricated, due to everything EXCEPT the muffler slowly disintegrating. I didn't include a resonator ahead of the muffler, sounds good anyway. Pictures to come.
> goinhm@...
> Thursday, September 11, 2008 2:19
> Re: [2cylinderhondas]
> muffler
> Hi Steve,
> I read your story about changing the muffler and it sounded > like the first time I tried to replace the tailpipe. The easiest way to > remove exhaust system components which do not separate easily is to use an > oxy-acetylene torch ( I wish I had a torch the first time I worked > on the exhaust system). Heat the joint until it is cherry red and then > the pieces separate very easily. I have seen this approach used at the > muffler shops.
> > tmoc1990@aol. com
> > got
> > mine
> > Steve
> There's a new fashion blog, plus the latest fall trends and hair > styles at StyleList.com > .
> Internal Virus Database is out of date.
> Checked by AVG -
> http://www.avg.com
> Version: 8.0.169 / Virus Database: 270.6.17/1655 -
> Release Date: 9/5/2008 7:05 PM
Re: muffler
Hi Steve,
I tried a propane torch and it did not generate enough heat quick enough. The oxy-acetylene heats it
quickly to a cherry red, starting to get orange, and then it comes apart easily. I have noticed Dennis offering
a complete exhaust system on this post.....but maybe you didn't realize you were going to be needing a complete replacement when you started fixing it up.
Psssst...Have you heard the news?> Ah if only I had a torch. I suppose a cheap propane torch might > have done it. Anyway I managed to get it together without demolishing > anything with my BFH. Since then I have had to resort to having my whole > exhaust system behind the heat exchanger fabricated, due to everything EXCEPT > the muffler slowly disintegrating. I didn't include a resonator ahead of > the muffler, sounds good anyway. Pictures to > come.
deanspradley69
muffler
can anyone tell me where i can get a muffler for a 600 sedan. or if there is a different one yhat i can replace the originalone with
Re: muffler
I used a muffler off a 650 Triumph.... sou nds great!
> deanspradley69
> Thursday, August 2, 2012 7:38 PM
> [2cylinderhondas] muffler
Re: muffler
Here's the one I used: Imco Brand, Part # CM-43. It is 6" diameter and is 12" long and has 1 1/2" inlet & outlet like the original. I had to make some brackets for it and the back pressure should be comparable. Honda 600s thrive on back pressure.
deanspradley69
Re: muffler
Thats for the info. Can you tell me if it sounds like the original or has a louder sound. I'm looking for one thats pretty quiet
Re: muffler
It sounds throaty not like a Vespa!
> deanspradley69
> Saturday, August 4, 2012 11:48 AM
> [2cylinderhondas] Re: muffler
