, brucerb@... wrote:
> what if the car dies when the positive cable is removed? Bruce
> From: goinhm@...
> Sent: Thursday, March 19, 2009 12:59:10 PM GMT -08:00 US/Canada Pacific
> Subject: Re: [2cylinderhondas] mag needle???
> Hi Jeremy,
> Well, there's a business to avoid in the future. These cars do not have a magneto... they have an alternator. Give us some more info....here are a couple questions which need answering;
> 1) measure your car battery voltage and tell us the reading
> 2) start your engine and turn off all the accessories (lights, radio, heater), remove the positive battery terminal. Does the engine continue running? If yes, proceed to (3) below.
> 3) With the engine running and the positive battery terminal removed, measure the voltage between the battery cable (not the battery but the cable coming from the engine compartment) and the engine casing.
> Tell us the voltage reading.
> If your car battery is discharging, I suspect you have a problem with the voltage regulator or the alternator or one of the wiring connectors. You could also have a problem with the rectifier but those rarely go bad unless they have been abused.
> Big electrical problems in NY.
> I brought my Honda 600to an electrical place and they said it is discharging.
> Something about a mag needle??
> Any ideas??
> Jeremy
> Hi Jeremy,
> Any ideas??
> Jeremy
> Feeling the pinch at the grocery store? Make meals for under $10 .
