accelerator pump
Darkmond
accelerator pump
Post by Darkmond »
been looking for an accelerator pump for some time now. Will also take a rebuilt carb if need be.
Robert Freeman
Re: accelerator pump
Post by Robert Freeman »
I have had great luck just putting in a new diaphram. You just grind off the old penned end, drill and tap it for a 4-40 screw, cut a new diaphram out of sheet diaphram material, and screw it together using thread locker. I have not had any failures. I have been doing this for years.
> awhiteman112
> Thursday, September 17, 2009 9:57
> [2cylinderhondas] accelerator
> pump
> been looking for an accelerator pump for some time now. Will also take a > rebuilt carb if need be.
kuranhonda
Post by kuranhonda »
I went into a carb specialist years back and he matched up something from a Harley Davidson that looked a little different but worked fine.
The diaphragm material must be resistant to the Alcohol based fuels we are forced to purchase these days.  It may be why you have been making them for years.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > robert freeman > Sent:
> Thursday, September 17, 2009 5:01
> [2cylinderhondas] accelerator pump
> diaphram. You just grind off the old penned end, drill and tap it for a 4-40 > screw, cut a new diaphram out of sheet diaphram material, and screw it > together using thread locker. I have not had any failures. I have been doing > this for years.
> > awhiteman112
> > AM
> > pump
> > been looking for an accelerator pump for some time now. Will also take a > > rebuilt carb if need be.
Robert Freeman
You are right! Also, carb cleaners do their dirty work.
> billmyong@...
> Anzhonda600owners
> Saturday, September 19, 2009 11:59
> RE: [2cylinderhondas]
> accelerator pump
> The
> diaphragm material must be resistant to the Alcohol based fuels we are forced > to purchase these days.  It may be why you have been making them for > years.
> > On Behalf Of
> > robert
> > freeman
> > Thursday, September 17, 2009 5:01 PM
> > Re: [2cylinderhondas] accelerator
> > pump
> > diaphram. You just grind off the old penned end, drill and tap it for a 4-40 > > screw, cut a new diaphram out of sheet diaphram material, and screw it > > together using thread locker. I have not had any failures. I have been doing > > this for years.
> > > awhiteman112
> > > Sent:
> > > 9:57 AM
> > > [2cylinderhondas]
> > > accelerator pump
> > > been looking for an accelerator pump for some time now. Will also take > > > a rebuilt carb if need be.
